Any spot welder experts about?
frank brown14/12/2015 18:49:16
436 forum posts
5 photos
I got an old spot welding transformer from a mate decades ago and decided to use now. The reason was to connect to stainless steel tabs on rechargeable ni-cad batteries in order to re-use them.
The transformer is about 7" square and 9" long with the output being a couple of 1/2" copper bars about 15" long.It is all painted light green. The mains connection are on a paxolin panel. four terminals, "C" which I took for common (neutral), then .16 ohms to "H", or .255 ohms to "M", or .265 ohms to "L" .
Using the C to L connections , I got 3.5V out and enough current to heat red hot and remove a fair section of a .005" X .25" stainless steel tab.. Despite this I think i might have a good joint.
So C to L , highest primary resistance, highest number of turns, so lowest output voltage. But still an excessive current. Anny suggestions for reducing the output current?
As the kit did not blow the 13A mains fuse during my brief experiment, I presume the transformer has got a bit of leakage inductance built it to limit the current.
All suggestions welcome.
Frank
Mike Poole14/12/2015 19:34:34
3676 forum posts
82 photos
Introducing more resistance into the secondary circuit will limit the current but will generate heat, in the car industry water cooling is used to keep things from self destruction and stop the resistance rising which will affect weld quality. From the 70's to 90's control of the primary was effected with SCR control but with ignitrons before that. The firing angle of each half cycle could be delayed to control the primary current and thus the secondary current. The secondary circuit of a weld gun is constructed from aluminium and copper to minimise losses, if you put a big bar of steel in your circuit it might limit your current enough.
peter walton16/12/2015 22:28:18
84 forum posts
The tabs on NiCad batteries are spot welded using a capacitive discharge welder.
Do a search on google!
Plenty of info for self build
peter
frank brown17/12/2015 19:10:21
436 forum posts
5 photos
I have tried that.. The problem is that I have a transformer which is a proper spot welding transformer which could be rated as high as 5 kW, not a 800W micro wave transformer with a home wound secondary. Also they have no way of controlling the current, as they don't have that much to start with.
Have you any figures for the Coulomb rating of the capacitor type ( 1/2 C V^2)?
Frank
Mike Lightfoot17/12/2015 20:37:39
76 forum posts
24 photos
Good evening, I have somewhere a drawing and the spec for a tab welder if anyone is interested I will try and dig it out might take a day or so let me know ( it is as suggested a capacitive discharge welder)
ASF17/12/2015 20:59:49
131 forum posts
12 photos
I have made a few new battery packs up and it rejuvenated the power tools no end!
I did try to reuse the tabs, but found that,because new batteries were more powerful, it caused the old tabs to heat up.
So to fix this issue, I used copper pipe cut down the length, flattened then cut into little strips. Polished them up and soldered the tabs with a 100 watt iron.
The soldering is simple. The hard part is keeping all the batteries in the shape of the plastic pack.
frank brown18/12/2015 20:08:47
436 forum posts
5 photos
yes I have done that in the past too. I think the solderable tabs are nickel plated steel, which will solder with difficulty, they (or at least my ones are a bit thicker .007"?). But with the stainless tabs I have had no luck at all, hence my feeble attempts at getting a spot welder to work. So far no series resistor in primary is too much current, 100 ohms too much resistance.
Today I spent wrestling with the transformer and its 1/2" output bus bars and building a cover over the fire element resistor which is now 50 ohms and is still too high.
I found a number on the transformer :- BTX 7235A 55 P1 Ring any bells
Frank
ASF18/12/2015 20:35:41
131 forum posts
12 photos
well i also found that stainless was hard to solder. That is why i used copper pipe. I ripped the lightweight tabs off, rubbed the battery on some emery and they soldered easy.
cant help with the way you are trying to do it though
Ian P18/12/2015 20:49:09
2747 forum posts
123 photos
Posted by frank brown on 18/12/2015 20:08:47:
Frank
Frank
I cannot claim to be an expert on spot welding but I think putting resistance in the output of the transformer is the wrong approach. Resistance welding (which I think is the correct terminology) looks very simple but there are a lot of factors that affect the weld quality. (type of material, electrode mechanical pressure, length of current pulse etc)
All the spot welders I have come across have a control circuit on the primary side, mostly its some sort of timer and the current is fixed at maximum by the design. If your welder was capable of 1000 Amps it could still weld very thin steel shim as long as the current pulse was very short, but mechanical relays and timers would not be precise enough to give repeatable pulses for thin material. I have used 'SSR' (Solid State Relay) modules in conjunction with a 555 timer IC to vary the weld time (switches the primary side of the transformer) but whilst I can weld 0.5mm SS sheet I doubt it would give consistent results on thin battery tabs. If your transformer is the type used for car bodywork repairing (mine was) it is out of proportion for what you want to do.
It might be worth experimenting though with resistance on the primary side of the transformer, 100W lightbulb or a fan heater element for example.
Ian P
Ian P18/12/2015 20:49:10
2747 forum posts
123 photos
Frank
Frank
Ian P
Neil Wyatt18/12/2015 20:49:48
19226 forum posts
749 photos
86 articles
You probably need a MUCH smaller resistor.
You could try experimenting with an old-style electric fire bar with a big croc clip as a rheostat ((I love that word).
Ian P18/12/2015 21:07:26
2747 forum posts
123 photos
Posted by Neil Wyatt on 18/12/2015 20:49:48:
It needs to be small in Ohmic value but capable of passing a very high current.
Think about the cross sectional area of the heater element wire in relation to the battery tab (let alone the copper bar the secondary 'winding' is made of, the element wire will be a good fuse!
Ian P
John Haine18/12/2015 23:12:27
5563 forum posts
322 photos
The ideal approach would be a variac to adjust the voltage driving the primary. A thyristor speed control might also do the job. A resistor in the secondary would have to be rather low and hard to control.
Neil Wyatt19/12/2015 09:34:48
19226 forum posts
749 photos
86 articles
Posted by Ian Phillips on 18/12/2015 21:07:26:
Ian P
Indeed, but the heater will cope with a massive overload for a second or so, unlike a fuse it is designed to run red hot for hours on end. It's worth a try, and you can always use multiple strands of the wire (I used three to make a shunt for an ammeter once).
Edited By Neil Wyatt on 19/12/2015 09:35:33
Ian S C19/12/2015 09:46:44
7468 forum posts
230 photos
There is a thread on Google; I was looking through a number of sites for ideas on making a spot welder from a Micro wave oven transformer, there was one with the two electrodes parallel for welding tabs on, it mentioned a resistor, fairly low value, high wattage.
Ian S C
Neil Wyatt19/12/2015 09:56:20
19226 forum posts
749 photos
86 articles
This is a nice simple design,
www.philpem.me.uk/elec/welder/
www.philpem.me.uk/elec/welder/images/schematic.png
You need about 0.6 farads of capacitance, apparently 'I've heard from a few people who have managed to build welders based on the one-farad car-audio capacitors, after removing the blinking-lights display circuitry from the top of them.'
Also useful safety advice.
Clive Hartland19/12/2015 10:06:41
2929 forum posts
41 photos
I have never had any trouble soldering tabs to Ni cads, Using a solder with a flux core. Pre-solder the joint and then apply heat to do the joint. Part of my work was re-celling Ni cad battery packs, sometimes 10 a day , charging and discharging before going back to customer. As said the joint surfaces were cleaned with emery and quickly tinned.
If you are really having trouble buy some flux for stainless steel but beware as it extremely dangerous and do not get it on your bare skin nor breathe the fumes.
