Member postings for Mike Lightfoot
Here is a list of all the postings Mike Lightfoot has made in our forums. Click on a thread name to jump to the thread.
Thread: What are these off
09/08/2019 21:32:07
Not done it yet, thanks i didnt know that one
Thread: Safety Glasses
09/08/2019 20:44:30
I also use varifocal safety specs from spec savers £250 ish but wouldnt be without them
09/08/2019 20:35:07
My only other observations are even with a cabinet like that swmbo would not have the lathe in the lounge they were only allowed in for the picture, knowing Dad he just bought them because they looked nice he had two dividing heads so wouldnt really need them for indexing
thanks for looking
09/08/2019 20:30:54
image.jpgimage.jpgFirst of all thank you all for your time, some more info, the larger inside bore is 1.04” the smaller is .85” .5 width
two pictures here of 64 and 24 tooth wheels and dia the first 64/4.123 is 15.5 second 24/1.615 is 14.8 since to calculate dp i believe they should be measured at the pcd and not the od would that be right for 15 DP?
08/08/2019 22:57:10
Emgee, thanks will do that first thing tomorrow
08/08/2019 22:23:35
  • Good evening just found these i believe they are change wheels but dont match any machine dad had so does anyone have any idea
  • cheers
Thread: Toolholders & Inserts
16/11/2018 20:51:54
Stephen its just come to me the company i delt with were in the stages of merging with Lloyd Jones so give them a call
16/11/2018 19:36:49
Stephen, I too have some old sumitomo tools and quite right they are odd sizes i did however find a source i seem to remember liverpool or wigan way ill see if i can did the info out over the weekend.
Thread: For discussing the merits of alternative 3D CAD programs.
28/10/2018 11:59:02
Ok enough I for one as a complete novice in this field welcome the opportunity to try a package with some tuition at only the cost of a magazine subsription which i pay anyway
Thread: best pressure gauge?
01/06/2018 19:28:06
Thats fine but why replace it, when you have the boiler test the inspector should mark Max working pressure on it you could scale it down from that ?
Thread: In praise of Oldtimers
17/11/2017 21:41:40
Never do today what you can put off till tomorrow
Thread: heating manifold
18/09/2017 17:51:17
Clogs, Hi we have a large log burner heating a largish hot water tank as a back up i have an electric heater to heat the water it powers a wet underfloor downstairs radiators upstairs and provides domestic hot water. It works like this the big tank is called a heat store, it is sort of oppositte a normal central heating so the tank contains the hot water directly connected to the heaters and underfloor and the electric heater the domestic hot water is mains fed through a high efficiency heat exchanger in the tank there are 3 pumps one in line with the electric heater to push that water through and into the tank, one to circulate hot water to the underfloor ( which also has its own pump) and one to circulate through the radiators, i guess i am using the tank as a manifold although the underfloor zones are on a seperate one, all works well.
Thread: Is Knurling a health hazard?
17/05/2017 09:31:42
All this reminds me of an old joke doing the rounds when i was in the RAF " air force officer and army officer taking a pee air force officer goes to walk straight out, army officer says we were taught to wash our hands after taking a pee at Sandhurst, air force officer replies at Cranwell we were taught not to piss on our hands in the first place"
Thread: Is this what we have been waiting for.
26/04/2017 21:33:24
Siemens are already 3D printing parts for gas turbine engines only at the testing stage i think
Thread: Machinery's Handbook
28/02/2017 15:55:40
Machinery's Handbook is up to 30 edition and still currently available ( just treated myself) my old man bought me a 21 edition ages ago, its just a gold mine
Edited By Mike Lightfoot on 28/02/2017 15:56:14
Thread: Etching a brass plate for a 5" loco
20/02/2017 20:11:17
Whilst i have not tried it i understand if you print it out on a laser printer you can iron it onto the brass and the print will transfer and is etch resist.
Thread: building the burrel showmans engine thetford town
06/01/2017 20:27:13
Michael had a quick look but my lap top is not that well protected so a little reluctant will look to update and try again thanks
03/01/2017 22:03:01
Cheers Derek will let you know hopefully someone out there .....
03/01/2017 21:08:52
hi does anyone have a spare ( or one that could be copied ) copy of Alan marshals book "building the burrel showmans traction engine thetford town" isbn0954475836 and 9780954475833 two volumes, I have just inherited Dads part finished beast, i believe alan also did it on disc. I have tried all the usual and e mailed the author from his web site all to no avail, thanks in advance. Mike
Thread: Dead weight tester
08/12/2016 18:27:30
Nigel thanks will reinforce that info though our tester should be aware Cheers Mike
