Myford
Thread file indicator
kevin large03/11/2015 22:36:22
143 forum posts
Hi I've just acquired a myford ml7 tri lever just got it set up and noticed the thread dial indicator turns when the lead screw is turning but when I engage the half nut it stops is this how it should be I've not ryed screw cutting yet but looks quite complicated to set up any tips on this would be good
Thanks in advance
NJH03/11/2015 22:50:28
2314 forum posts
139 photos
Relax Kevin
That's how it is supposed to work! The indicator rotates and tells you when to engage the clasp nut.
I' m away from the workshop & my data at the moment but will post tomorrow if no body can give you the detailed info. in the meantime.
Norman
Edited By NJH on 03/11/2015 22:52:58
DMB04/11/2015 00:27:22
1585 forum posts
Hi Kevin,
I have an MLS-7 with a threading indicator. I have slacked-off the clamp nut and swivelled it round a bit so gear @ bottom of fitting doesn`t engage leadscrew under normal useage, i.e., when not screwcutting. The idea is that if thread being cut is a multiple of leadscrew thread, in this case, 8tpi, then you can re-engage the clasp nut @ any of the 4 divs, This only applies to Imperial not Metric threads. HTH.
John.
Lambton04/11/2015 05:24:45
694 forum posts
Kevin,
Please get yourself an official Myford handbook for your lathe as they are very informative and tell you almost all you need to know. You can download a pdf from the net or buy one from new Myford.
Also useful is "Myford series 7 manual" by Ian Bradley which is currently in publication.
Martin Kyte04/11/2015 08:25:52
3445 forum posts
62 photos
Why would you wish to dis-engage the screw thread indicator DMB ?
Martin
NJH04/11/2015 10:18:09
2314 forum posts
139 photos
Hi Kevin
I suggest that you sign up with Yahoo groups where there is a group devoted to Myford lathes. The group is HERE
You will find the info. that you seek but I endorse "Lambton's" advice that you buy the Bradley's Myford Series 7 Manual - lots of useful and relevant information ( Loads of copies available from Amazon from about £4)
Norman
old Al04/11/2015 10:47:08
187 forum posts
Martin
You disengage the screw thread indicator to save wear. The same reason to disengage the gearbox when not in use.
Screwcutting can be very frustrating and great fun. But i would suggest getting someone to show you how its done first. reading books make it look so difficult.
Muzzer04/11/2015 10:51:34
2904 forum posts
448 photos
Check out a few Youtube videos. Almost as good as finding someone to show you.
Ian S C04/11/2015 11:17:31
7468 forum posts
230 photos
Check out Youtube Vidios, or be like me, just get stuck in and do it, and it worked, the tool I used was a bit off an old square file( I think it's still in the lathe tool draw). I chose a large thread for a first, 3/4" BSW,(10tpi), a smaller, fine thread is easier.
Ian S C
Edited By Ian S C on 04/11/2015 11:22:37
Martin Kyte04/11/2015 11:35:07
3445 forum posts
62 photos
I cannot see that the wear caused by what is effectively a rack and pinion driving a freely moving indicator spindle is going to be significant. I can fully understand disengaging the gearbox as the loading is many times more significant. In fact if you stick the tumbler gears in neutral the leadscrew doesn't turn and the thread indicator only moves when you track the saddle. Any significant wear is going to come from the saddle handwheel pinion gear. So that why I leave the dial indicator permanently engaged.
Martin
kevin large04/11/2015 11:57:12
143 forum posts
Thanks for the replies I have the myford manual but not sure which is the idle gear is metric 1.5 21 50 45 35idle 40
Lambton04/11/2015 17:37:05
694 forum posts
If anyone must keep their thread dial indicator permanently engaged then ensure it's spindle is lubricated from time to time using the small oiler in the centre of the dial. Better to disengage it when not in use as it serves no purpose to keep it engaged when not screw cutting.
Mike Poole04/11/2015 18:18:37
3676 forum posts
82 photos
The thread indicator is usually mounted with fibre washers and adjusted to be a firm push to engage or disengage as required.
John Haine04/11/2015 19:41:28
5563 forum posts
322 photos
Kevin, I don't understand what you're asking in your last post, please could you clarify? Myford "metric" lathes are identical to the imperial ones except that the cross and top slide feed screws are 2 mm pitch. The leadscrew remains 8 tpi.
kevin large04/11/2015 21:00:52
143 forum posts
Sorry it's an imperial lathe but I want to set to cut metric 1.5 pitch thread but looking at the book it doesn't state which is the idler gear
Roderick Jenkins04/11/2015 21:15:22
2376 forum posts
800 photos
Kevin,
Perhaps it's more explicit in my S7 manual:
21 driver
50 driven paired with 45 driver on 1st stud
35 as idler on 2nd stud
40 driven on lead screw
HTH
Rod
DMB04/11/2015 23:21:39
1585 forum posts
Martin,
If you read various posts above, people like Lambton have answered your question.
