ML7 Clutch
Roy James 221/09/2015 17:04:04
15 forum posts
9 photos
Hello all,
I have the drawings for the ML7 clutch from issue 5 1991, which I would like to
adapt to my old, (very old ML2), can someone inform me of the material used
between the two cones ? I have been unable to access the article in question.
james
Gray6221/09/2015 17:56:01
1058 forum posts
16 photos
Hi James, the conical face of the clutch was covered with leather.
Graeme
Roy James 221/09/2015 18:29:23
15 forum posts
9 photos
Graeme W, Thank you, overall, quite thick stuff at over 1/8"..
james
Neil Wyatt21/09/2015 18:37:30
19226 forum posts
749 photos
86 articles
I'm sure some people have used cast iron on cast iron.
Gray6221/09/2015 18:42:39
1058 forum posts
16 photos
Quite true Neil, in fact the cone clutch on my Studer cylindrical grinder is CI on CI and works very well
Michael Gilligan21/09/2015 18:53:34
23121 forum posts
1360 photos
Posted by Roy James 2 on 21/09/2015 18:29:23:
james
The author specifically mentions 'old leather belting'
I suspect that this was machine belting [rather than what holds your trousers up].
Roy James 222/09/2015 20:43:08
15 forum posts
9 photos
Thanks to you all,
I have a couple more questions regarding said clutch, can I use copper as a bearing (5) on the counter shaft
pulley, it's only 6" dia, (unit all made many moons ago). I am considering casting the cones in ali, is there a reason
why parts 3&4 are separate, could they be made as one ? ( Bit daunting having to cut threads ).
james
daveb22/09/2015 22:58:07
631 forum posts
14 photos
Copper isn't ideal but why bother? Porous bronze bushes are not too expensive.
Robbo23/09/2015 23:44:33
1504 forum posts
142 photos
James,
Parts 3 & 4 are separate as there was at the time a perceived difficulty in buying alloy of the required diameter in the necessary thickness. So the part was made in 2pieces. Nowadays material should be available to make it from a single piece.
Robbo24/09/2015 14:21:05
1504 forum posts
142 photos
James,
I have sent you a message about the clutch, check your inbox, top green bar on screen, second icon from left.
john fletcher 124/09/2015 17:02:05
893 forum posts
I made the clutch for my ML7 and it worked well in the end. I did use bit of soft leather belting, initially the clutch slipped badly, then some one suggested I get a block of rosin as used by violinists. I crushed the rosin into chips then into a powder. I ran the lathe and opened up the clutch and sprinkled in the powder, did it a couple of times and the problem was solved. I still have the magazine and drawing somewhere. John
Neil Wyatt24/09/2015 19:41:06
19226 forum posts
749 photos
86 articles
Leaded copper is actually used as a bearing material, comparable to babbitt metal, but its main limitation is that it wears easily. I would avoid it as constant lubrication would be critical..
Roy James 214/10/2015 19:43:42
15 forum posts
9 photos
I am going to the Midlands Exhibition, I would like to buy a 4", 4 jaw adjustable chuck for the old Myford ML2, can anyone recommend one of the many sold by the like of Chronas etc? Would also need a back plate. Is it easy
to fit?
Have to cut the keyway in the shaft of the clutch mod, I have no miller, nor verticle slide, how to do it?
james
David Clark 114/10/2015 20:55:27
3357 forum posts
112 photos
10 articles
It is easy to fit. Just turn it on the lathe you are using the chuck on so it is true. Hold the shaft in the chuck supported by a centre, use the back gear to stop the shaft from rotating. Cut the slot with a lathe tool ground to fit used on its side and rack the carriage back and forth to form the groove.
