Member postings for Roy James 2
Here is a list of all the postings Roy James 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: 4" independent lathe chuck recommendations and holding capacity
06/07/2016 23:23:24
Carl.
I have a small Myford M type Lathe with the small 7/8" 9 or 12 TPI thread,( not sure which ) I'm going through the same process as you, requiring a larger chuck, I would think twice if I were you about the 6" chuck, mainly because of the weight you would impose on the smaller mandrel.
A 4" lightweight one will be my choice
Michael G.
What sort of insert are you thinking of,a reducer from a myford thread to the 1" thread on Carl's lathe ?
James
Thread: Myford ML4(?)- Headstock bearing replacement
29/10/2015 21:04:03
James.
Could you identify your lathe type from the link that Neil gave you, it would help.? Mine has thrust bearings fitted.
james
Thread: ML7 Clutch
14/10/2015 19:43:42
I am going to the Midlands Exhibition, I would like to buy a 4", 4 jaw adjustable chuck for the old Myford ML2, can anyone recommend one of the many sold by the like of Chronas etc? Would also need a back plate. Is it easy
to fit?
Have to cut the keyway in the shaft of the clutch mod, I have no miller, nor verticle slide, how to do it?
james
Thread: Can Motor be used with VFD?
11/10/2015 23:48:38
John,
Start and run windings are connected behind slip ring ( 4 connections),when motor starts centrifugal switch open
circuits the start winding. No caps anywhere. There is an advert for this type of motor in 1932 in the files of BTH.
( Im19320714 MEE-BTH.jpg ).
james
11/10/2015 22:32:36
Ian P.
The purpose of the ring of small holes is to fit balancing weights, as there are a couple on both the slip ring and on the cooling fan, when running it's as sweet as a nut.. This is the first time I have taken it apart since I
fitted it 35 odd years ago, thank you all for the interest you have shown in such a curiosity..
james
11/10/2015 20:30:00
Phil.
Sorry I did not post photo of nameplate, it's a B.T.H. Rugby machine. Type BA147. Form DB1 , 1/4 HP,
2.3 amps at 1425 RPM . Continuous rating, usual 230/250v. It has been on the lathe for at least the last 35 yrs.
When I acquired the lathe, its an old Myford ML1/2 (not sure if motor was with it). Had to make counter shaft and motor base for it, at the time I was employed in the steelworks, have not that luxury now, pity, could have made my clutch.
james
09/10/2015 23:26:28
More photos in Album, my next job is to put it all back together. ( Murray, one may never ever see one of these again ). The second photo shows the centrifugal switch at the back of the slip rings. By the way I live in Cardiff..
james
09/10/2015 23:12:37
004.jpgGentlemen
07/10/2015 21:48:33
Murray,
Will see what I can do, as counter shaft is now in bits. Can give the motor a bit of TLC, years since I last had it apart.
james
07/10/2015 19:59:13
Gentlemen,
It is a slip ring wound rotor. no windings on the stator, all start and run windings are on the rotor along with the
centrifugal switch. You are correct John, it is a curiosity, at 1/4HP it's been on the lathe this last 35 years or more.
Plenty of ads for single phase to single phase stuff on the web, I am just testing the water, oh well, many thanks.
I will carry on with my clutch mod.
james
06/10/2015 20:44:12
Has any one any information on a single phase 230v wound rotor slip ring motor? Can't seem to find any info on web, mostly 3 phase with slip rings. (would like to try VFD with it if possible )
james
Thread: Spot the connection
04/10/2015 22:41:12
Steve,
Why do you want to find the star point? Do you now want it to be connected in a delta?
james
Thread: ML7 Clutch
22/09/2015 20:43:08
Thanks to you all,
I have a couple more questions regarding said clutch, can I use copper as a bearing (5) on the counter shaft
pulley, it's only 6" dia, (unit all made many moons ago). I am considering casting the cones in ali, is there a reason
why parts 3&4 are separate, could they be made as one ? ( Bit daunting having to cut threads ).
james
21/09/2015 18:29:23
Graeme W, Thank you, overall, quite thick stuff at over 1/8"..
james
21/09/2015 17:04:04
Hello all,
I have the drawings for the ML7 clutch from issue 5 1991, which I would like to
adapt to my old, (very old ML2), can someone inform me of the material used
between the two cones ? I have been unable to access the article in question.
james
