woody1 | 10/09/2015 22:52:43 |
![]() 91 forum posts 21 photos | Evening all, My attempts at milling on the myford 3'' 1/8'' are pretty poor! I do not have a vertical milling vice, my attempts using V blocks, clamping with T nuts and milling horizontally have been poor. Would this be the factor? If for example I try to mill a 1/4'' slot in ally I get a gouge in the lower of the slot feeding in with the cross and visa versa feeding out. The fly cutter I machined is fine horizontally end mills however just gouge. Tin hats on David. |
Ady1 | 11/09/2015 00:18:31 |
![]() 6137 forum posts 893 photos | Aluminium can sometimes be better done on the back gear. less heat Everything needs to be properly adjusted to do decent milling on a lathe, no slop anywhere (You should really get a milling slide, it makes things easier) Edited By Ady1 on 11/09/2015 00:30:15 |
Hopper | 11/09/2015 04:20:04 |
![]() 7881 forum posts 397 photos | And locking all the slides not in use is essential. Good solid locks, not just nipping up a couple of the gib screws. Is the ally free-machining alloy? Some of the low grade alloys and straight aluminum can be very sticky to machine. |
woody1 | 11/09/2015 18:46:47 |
![]() 91 forum posts 21 photos | Posted by Hopper on 11/09/2015 04:20:04:
Is the ally free-machining alloy? Some of the low grade alloys and straight aluminum can be very sticky to machine. That may be my problem it was just flat bar bought at my local metal supplier so unknown it is gummy to machine though. I do have some marine ally mostly broken bits off the various boats we'v owned over the years my gave that a try just to see the results. I realised locking everything off is a must but milling on the cross slide horizontally means i need all of my movements. Milling vice would be the way forward, just asking though I'm going to finish all the odd jobs on the machine I have, sell it and buy something bigger which I will invest in a milling vice for.
Thanks David. |
Russell Eberhardt | 11/09/2015 19:40:02 |
![]() 2785 forum posts 87 photos | Are you using a four flute end mill or a two flute slot drill? If you use the four flute variety to mill a slot there is a sideways force created by the front of the cutter that deflects it if the set-up isn't sufficiently rigid and causes the side of the cutter to dig in. If it is a sticky material try lubricating it with paraffin. Russell. |
Ajohnw | 11/09/2015 22:58:57 |
3631 forum posts 160 photos | Sounds like your cross slide is way too loose to me. This might be due to uneven wear. If so it will be difficult to do anything about it. John - |
john carruthers | 12/09/2015 08:29:21 |
![]() 617 forum posts 180 photos | Hi David, I've just started experimenting with milling on a small lathe (sc3) and I have found a carriage lock to be almost mandatory. I use an mt3 collet and draw bar to hold the end mills but the home made fly cutter goes in the chuck. |
Neil Wyatt | 12/09/2015 12:18:46 |
![]() 19226 forum posts 749 photos 86 articles | > but milling on the cross slide horizontally means i need all of my movements You still only use one movement to make the cut. Neil |
woody1 | 12/09/2015 20:32:51 |
![]() 91 forum posts 21 photos | Sorry, I do lock off the carriage, My problem is with the cross slide. When I feed in, the cross slide gets pulled in the direction of cut in jerks, I imagine that it's the back lash in my machines cross slide. I shall film and post. I hope you understand my explanation Neil. David. |
Gordon A | 12/09/2015 21:54:21 |
157 forum posts 4 photos | Greetings David, Try to feed the workpiece against the direction of cut to prevent "grab". A good book on this subject is "Milling Operations in the Lathe" by Tubal Cain. Workshop Practice Series number 5. Gordon. |
Paul Lousick | 13/09/2015 04:30:16 |
2276 forum posts 801 photos | Hi David, It sounds as if you are "climb milling" which does exactly as you describe, pulls the work into the tool and jerks unless you have a lead screw with no backlash. Try feeding in the opposite direction which is "conventional milling". This will only apply a load to one side of the nut on the screw and should eliminate the jerk. Paul. |
