Brian Abbott | 08/07/2015 23:40:37 |
![]() 523 forum posts 95 photos | Hello all, In the process of making a water pump ( side tracked from building the minnie ) need to drill a 33/64 hole into the existing one shown in the picture below but really worried about the drill snatching, can anyone offer any advice to reduce the risk. Thanks. Edited By Brian Abbott on 09/07/2015 00:10:28 |
Brian Abbott | 08/07/2015 23:41:04 |
Edited By Brian Abbott on 09/07/2015 00:09:31 |
Black Cat2 | 09/07/2015 01:02:47 |
83 forum posts | I have just drilles 1 mm hole 7/8 inch through a 5 mm diameter spigot..I think its a spigot! Then put a thread on the outside..No problems at all..Its colphos 90 .. Last week I turned a piece of pb for a canon and it was very ' chewy' I ended up using emery cloth to get a nearly smooth finish.. An elderly friend at work who spent a few years at an engineering firm said he used 1/2 water1/2 milk to lubricate pb..I havent tried it but he s not daft! i now decided to use colphos 90 all the time! Jonathon |
Jeff Dayman | 09/07/2015 02:48:14 |
2356 forum posts 47 photos | Brian - Have you ground flats on the cutting lips of the drill, parallel to the drill axis? (to remove the helix lead angle in the lips) Look up "grinding drills for brass" on Google if you are not sure what I mean. This will reduce or eliminate snatching during drilling in brasses and bronze (except in thin sheets) . Drop of good cutting oil doesn't hurt either. In thin sheets, a stepped "Christmas tree" type drill works well. Good luck, JD |
JasonB | 09/07/2015 07:06:45 |
![]() 25215 forum posts 3105 photos 1 articles | I've never been one to modify drill bits and not had too many grab. As its a bit over 1/2" I would open it up with the boring head. J |
Michael Gilligan | 09/07/2015 07:07:41 |
![]() 23121 forum posts 1360 photos | Brian, This appears to be already set-up on a mill ... My preference would be to use a milling cutter, or a single point boring tool: either of these would be lower risk than using a drill. MichaelG. |
Martin Kyte | 09/07/2015 08:41:55 |
![]() 3445 forum posts 62 photos | I would not go anywhere near the grinder to modify a drill for brass or bronze. All you need to do is generate a flat parallel to the axis of the drill on each cutting lip/flute of the drill with a small emery stone. You only need a few thou to give you zero rake and eliminate any grabbing. I suspect that's what Jeff meant when he said 'grind'. regards Martin |
mechman48 | 09/07/2015 08:49:08 |
![]() 2947 forum posts 468 photos | I am building up a set of brass drills by taking the cutting edge of the lips by dressing off with a diamond hone... it only removes a couple of thou' but it's enough to stop the 'grab' if through drilling, or pulling effect in a blind hole. George. |
IanT | 09/07/2015 09:28:15 |
2147 forum posts 222 photos | I've just recently drilled a couple of 12mm holes in some PB rod. I was opening out the second hole to final dimensions when the drill badly jammed in the hole. The drill bit was nearly new too (pretty sure I'd only used it on brass a few times previously). When I went to take it out of the collet - the work and drill were still quite warm - suggesting a good deal of rubbing/friction had been going on. I finally got the drill out (maybe the bad language helped) but the outside of the work was scored in the process. So in future with PB, I will move over to a boring tool as soon as practical... Regards, IanT |
Nigel McBurney 1 | 09/07/2015 09:30:39 |
![]() 1101 forum posts 3 photos | I have seen accidents with drills grabbing bronze,grind flats on the drill lips on a grinding wheel ,you require a visible flat not a bit of honing on a half inch drill,and on the casting in the photo I would use two clamps,better than wrecking a casting, the correct method would be to use a straight fluted drill or straight fluted milling cutter.For one offs a boring tool in the mill is possibly the safest option.For cutting fluid I would use ordinary soluble oil,cooling the tool is more important than lubrication,When drilling drawn phosphor bronze,possibly the worst material for "snatching" start off with minimum depth of centre drill and then drill to required size with one drill,grind the drill so that one cutting edge is slightly longer than the other one so that the drill make a slightly oversize hole as drills not only snatch in bronze they also tend to bind in the hole if the depth is greater than 2x dia. |
Vic | 09/07/2015 10:12:14 |
3453 forum posts 23 photos | Posted by Martin Kyte on 09/07/2015 08:41:55:
I would not go anywhere near the grinder to modify a drill for brass or bronze. All you need to do is generate a flat parallel to the axis of the drill on each cutting lip/flute of the drill with a small emery stone. You only need a few thou to give you zero rake and eliminate any grabbing. I suspect that's what Jeff meant when he said 'grind'. regards Martin Don't suppose you have a picture of the required modification to a drill bit by any chance Martin? |
Martin Kyte | 09/07/2015 10:53:24 |
![]() 3445 forum posts 62 photos | There is a picture here Martin |
jason udall | 09/07/2015 11:00:12 |
2032 forum posts 41 photos | Drilled quite a lot of bronze at work. Never modified a drill to suit. But.keep it ( tool and work) cool Don't faff around and work harden metal. .. Spoken after making about 1000 bushes a week from solid..5000 from tube. So in the latter normally bore only so don't count |
Martin Kyte | 09/07/2015 11:02:03 |
![]() 3445 forum posts 62 photos | Fair comment from Nigel. I do tend to put bigger flats on larger size drills and it is possible to do it on a grinder but for a first go hand work with a stone is more controllable. Martin |
Martin Kyte | 09/07/2015 11:07:04 |
![]() 3445 forum posts 62 photos | There is a world of difference between drilling a hole in bronze and drilling a hole in a hole in bronze. :0) Martin |
jason udall | 09/07/2015 13:03:15 |
2032 forum posts 41 photos | There is indeed. Thats why the bushes made from tube don't count ![]() |
Martin Kyte | 09/07/2015 14:04:36 |
![]() 3445 forum posts 62 photos | My point Jason was that when drilling into solid without breaking through as you would on a lathe making bushes from bar stock the chisel point of the drill controls the grab and you can get away with it. regards Martin |
MK | 09/07/2015 14:08:54 |
![]() 24 forum posts 20 photos | Puting it in the lathe with a four jaw and a small boring bar would work, as I just done that yesterday when I had to make a phosphor bronze cylinder with a 8mm bore. |
Vic | 09/07/2015 14:17:20 |
Thank you Martin, that makes it very clear. |
Brian Abbott | 09/07/2015 16:50:50 |
![]() 523 forum posts 95 photos | Thanks all for taking the time to reply, not sure which way to jump but will post a picture of the results. |
