Member postings for Brian Abbott
Here is a list of all the postings Brian Abbott has made in our forums. Click on a thread name to jump to the thread.
Thread: Steel Boiler Manufacturers
28/09/2023 11:55:25
Good morning everyone,
Looking for suppliers of steel boilers for a 3" engine
Could i please have your recommendations?
Thank you
Thread: Seig KX3 Still available in the uk
02/06/2023 19:22:33
Good evening all
Really sorry if this has been asked before but does anyone know if the Seig KX3 cnc is still available to buy in the UK?
I have done a search but nothing came up.
Thanks
Edited By Brian Abbott on 02/06/2023 19:23:10
Edited By Brian Abbott on 02/06/2023 19:25:13
Thread: 1" Scale "Thetford Town" showmans
26/05/2023 12:04:41
Hello everyone.
Has anyone ever build a 1" Scale "Thetford Town" showmans?
Just asking out of interest.
Thanks
Thread: Brian's 1" Minnie Traction Engine
09/05/2023 14:40:53
Hello Django
There are a few supplies for the casting, Reeves, Blackgates & GSS all do them,
As for the boiler, i would just order one from Western Steam, cost a few pounds but you will have a perfect start to the project.
08/05/2023 20:27:24
Thanks Jason and Clive
Turned a couple of diameters to help form the beading,
that with lots of annealing seemed to do the trick.
To answer Django, i only have a few hours a week, that together with all
the messing about is why it’s taken so long, i would have thought if you set your mind to it then you could build one in a fraction of the time.
07/05/2023 22:38:11
Good evening all.
Need some help regarding this one.
Beading the tender on the Minnie, left-hand side the beading needs forming around the driver entry/exit cut out.
Tried forming it by hand but it's not working, wondered how others managed it.
Thanks
Thread: Copper Nickle Chrome Plating advice
28/04/2023 19:39:41
Thanks for taking the time to reply and for the advice given.
Spoke to a local plating company and i’m sorted now
27/04/2023 09:45:35
Hello all,
Need some expert advice if possible.
I need to make a small aluminum plate, approximately 35 x 35 x 1mm thick
This then needs plating
Does this need to hang in the tank? and if so is it possible to bond / solder a wire or lug to the back?
Thanks for any help
19/04/2023 13:31:54
Ash pan and damper sort of complete, need to make the linkage and a few other bits but its nearly there,
Going to move onto the tender for a while, need to solder this up and make water tight, then add the beading.
Thread: Box pan folder recommendations
17/04/2023 22:27:14
Hello.
I always struggle with bending material, always have.
I end up making formers for everything.
Does anyone have any experience with box pan folders?
Looking for something 12" long, maybe like the one Warco sells
Thanks
07/04/2023 16:24:22
Thanks Jason
Did you machine those from solid or bend 1/16 plate?
06/04/2023 21:04:08
Hello everyone
I am working on the ash pan, damper and hinge arrangements.
I have made the hinge that attaches to the front of the boiler but am having trouble picturing the 2 small hinges that solder to the damper.
Would anyone have a clear picture?
Thank you
Thread: Rivet Squeezer help
28/01/2023 14:37:20
Thank you
All done and seems to work ok.
Make a start now on riveting the Minnie.
27/01/2023 19:44:28
Hello all, thanks for the reply’s
Jason, is there any science behind the 0.025 of is it just what worked?
25/01/2023 22:08:41
Hello everyone.
I am in the process of making a Rivet Squeezer to help me complete the riveting needed on the 1" Minnie I'm building.
Based on 1/16" copper rivets, what is the best method to produce the dome within the rivet snap?
Thanks
10/11/2022 14:14:44
Thank you for send me those,
Now, anyone who has one going rusty under a bench, let me know before i start making one
10/11/2022 09:01:31
Sorry..looks like there was another one
1987
Vol 158
Issue 3801
Page 574
Can anyone help?
Thanks
10/11/2022 08:51:27
Thank you..
10/11/2022 08:06:51
Would someone be able to send my a copy of the rivet squeezer write up?
ME Index for 1988, Volume 160, Issue 3824, Page 526
I thought i could get it through the archive but it does not go back that far
Thank you.
26/10/2022 22:23:25
Thanks Derek,
Hello Jeff, never got that far,
Plan now is to write a list of all the half finish bits I need to do then strip the engine and sort all the gaskets so I can get it running,
Im not planning on painting it so just need to clean everything.
Be good to get it finish, I’ve really dragged my feet with this and I’m lucky I have never lost interest.
