Vic | 13/06/2015 12:58:17 |
3453 forum posts 23 photos | I often use the green Scotch Pads (scourers) sold in supermarkets as a general purpose abrasive for some jobs. Does anyone know what the grade is likely to be for these? Ive also bought some of the finer Grey ones in the past and am pretty sure it had some sort of grade on it but I no longer have the packet. |
mechman48 | 13/06/2015 13:14:22 |
![]() 2947 forum posts 468 photos | I bought some of the grey pads from B & Q a while back; they are graded as 'Fine & superfine'. I would compare them to wet & dry 800 -1000 grade respectively. George |
MICHEL GIRARD | 13/06/2015 14:00:26 |
3 forum posts | I think this link should answer your question: www.evergreen.edu/biophysics/technotes/fabric/finish.pdf
Michel |
capnahab | 14/06/2015 08:56:28 |
194 forum posts 17 photos | More info here No affiliation etc.. |
Vic | 14/06/2015 09:52:56 |
3453 forum posts 23 photos | Thanks folks. |
Gordon W | 14/06/2015 10:08:48 |
2011 forum posts | We use these pads, mostly for there intended use, but do have one or two in the w/shop. I find that the quality varies and some start falling apart after a short time. Maybe they are from different sources but it is worth checking before using on a significant job. |
Ian S C | 14/06/2015 10:59:53 |
![]() 7468 forum posts 230 photos | I got some at the $2 shop some years back and found they had virtually no abrasive properties at all. I found a use for them as air filters on the intake of my compressor, and the Kawasaki engine on my home built generator. Ian S C |
Vic | 14/06/2015 11:10:12 |
3453 forum posts 23 photos | The blue ones are non abrasive, as I believe some of the white ones are as well. |
Ian S C | 15/06/2015 13:45:58 |
![]() 7468 forum posts 230 photos | The ones I got are grey, and come from some where in the east, they are not Scotch Brite. Ian S C |
Tim Chambers | 15/06/2015 14:35:15 |
89 forum posts 33 photos | Posted by Ian S C on 15/06/2015 13:45:58:
they are not Scotch Brite. Ian S C There's your answer! I remember when I worked in a dairy and they tried to fob us off with a cheap substitute for Scotchbrite for cleaning up the cheese vats. |
