julian down | 24/04/2015 12:52:44 |
8 forum posts | Hi, I'm looking to fit a 4mm mild steel bar into another piece of steel, to the depth of 5mm or so.The hole doesn't have to be blind. I need it to be a press fit, so it stays on. My question is how do I get the hole to the right size? I'm considering drilling it to 3.9mm and then using a 4mm reamer to enlarge but will this be large enough and is it best to use a hand reamer or machine reamer? With thanks, Julian |
JasonB | 24/04/2015 13:05:05 |
25215 forum posts 3105 photos 1 articles | A hand reamer has a tapered end so provided you have a through hole you should be able to adjust the fit by how far you pass the reamer into the hole. Have a prcatice on some scrap first.
J |
FMES | 24/04/2015 13:45:36 |
608 forum posts 2 photos | Depends on the actual size of the mild steel bar. If it is 4mm then a drilling of 3.8/3.9 mm will give you a press fit without reaming. but check what size your drills are actually producing - most drill slightly oversize. We normally drill 3.8mm for a 4mm reamer to H7 clearance on 4mm ground mild steel. |
Tony Pratt 1 | 24/04/2015 13:56:18 |
2319 forum posts 13 photos | Yes, check diameter of the bar first, also Loctite will get you out of trouble if it all goes wrong. Tony |
Clive Hartland | 24/04/2015 13:58:16 |
2929 forum posts 41 photos | I normally drill 3.9 mm and use a 3.98 reamer, not many people will have such a reamer but 0.02 interference fit is enough. If you are still unsure then Loctite is your friend. Clive |
Michael Checkley | 24/04/2015 13:59:46 |
121 forum posts 66 photos | If your bar is supplied slightly under then a H7 fit would give you a clearance fit so as Jason says use the taper part of the reamer to get the press fit you want. Try it on a test piece first. Ideally you would use a H7 fit hole and then use a bar slightly oversize i.e for a light press fit a p6 fit would be +0.012/+0.020. An undersize hole of 3.8/3.9mm would be quite a heavy press fit for a bar of this size but it all depends on what size your bar is. |
julian down | 24/04/2015 15:03:06 |
8 forum posts | Thanks for your responses everyone, when the bar arrives I shall measure it exactly. I had to look up the H7 reference, I take it the H's refer to the the fit, lower numbers being tighter. Where do the P's come in though? Julian |
JasonB | 24/04/2015 15:21:00 |
25215 forum posts 3105 photos 1 articles | Capital H refers to hole tollerances Lowercase h refers to shaft tollerances Number 6, 7, 8 etc referes to the actual range of that tollerance |
julian down | 24/04/2015 17:19:09 |
8 forum posts | Thank you. |
Mike Poole | 24/04/2015 18:21:15 |
3676 forum posts 82 photos | I found that a newish H7 reamer cut a bit oversize, a commercial 4mm dowel which measures 4.010mm was actually loose in the reamed hole (machine reamer). A friend of mine who is a toolmaker was not surprised and said they would put a reamer in a drilling machine and run in reverse and lightly stone it to get a firm push fit, sounds crude but they didnt pay for the reamers and the stores only keep H7. Mike |
Neil Wyatt | 24/04/2015 18:41:31 |
19226 forum posts 749 photos 86 articles | The H7 reamer is supposed to cut 4.000m to 4.012mm - a push fit, not an interference fit. Either use Jason's cut on the tape tip, or use a number 37 drill. I suggest experimenting on some scrap first. Neil |
julian down | 24/04/2015 20:23:02 |
8 forum posts | Yes, depending on the size of the bar the machine reamer might be too large then, a hand reamer might be a better bet. Number 37 drill? |
FMES | 24/04/2015 20:31:25 |
608 forum posts 2 photos | Julian, may I recommend purchasing a set of Zeus tables **LINK** You'll never regret it. |
julian down | 24/04/2015 20:44:04 |
8 forum posts | Yes. I was looking at those, I just wasn't sure that metric clearance tables were in them - obviously they are! I think I might invest in one thanks, Lofty |
Michael Checkley | 24/04/2015 21:00:28 |
121 forum posts 66 photos | I'm not that familiar with number drills but is a number 37 a bit small? (2.642mm) |
FMES | 24/04/2015 21:42:07 |
608 forum posts 2 photos | 3.658 = No27 Edited By Lofty76 on 24/04/2015 21:43:36 |
Roy M | 24/04/2015 23:09:11 |
104 forum posts 7 photos | Here is a tip that some of you out there may not know. Given the drilled hole sizes are the same, and all the machine settings are the same, a reamer will cut bigger if you use cutting oil (rocol etc.) as opposed to water based emulsion type coolants. This is a small amount but is sometimes useful. (I'm still toolmaking!) Roy M
bricky | 25/04/2015 07:20:45 |
627 forum posts 72 photos | If I can get the work in the fridge I get to a very close fit ,cool one and heat the other and this has worked for me. Frank |
Michael Gilligan | 25/04/2015 08:12:03 |
23121 forum posts 1360 photos | Posted by Roy M on 24/04/2015 23:09:11:
Here is a tip that some of you out there may not know. Given the drilled hole sizes are the same, and all the machine settings are the same, a reamer will cut bigger if you use cutting oil (rocol etc.) as opposed to water based emulsion type coolants. This is a small amount but is sometimes useful. (I'm still toolmaking!) Roy M . Roy, That's very interesting ! I don't doubt you for one moment; but I would be interested to understand how/why it works like that. MichaelG. |
Bob Unitt 1 | 25/04/2015 09:06:13 |
323 forum posts 35 photos | Any reason you can't turn-down the end of the shaft to fit the hole, instead ? |
