HSS
richard 205/01/2015 21:30:16
127 forum posts
Happy New Year to all.
I have some 100cm lengths of HSS that I would like to cut in approx 50 cm lengths.
Would someone tell me how to cut it, please, before I either make a hash of it or do some damage?
Many thanks.
Richard.
Bob Brown 105/01/2015 21:46:20
1022 forum posts
127 photos
I would use a small angle grinder (4 or 4.5" with a thin 1mm cutting disc and some water to cool it, I do not mean chuck water at as you cut as electrics and water are not a good mix.
Bob
Steve F05/01/2015 21:47:49
101 forum posts
25 photos
Hi
Last time i did it i think i ran a dremel grinding disc around it .Then put it in a vice and gave it a wack with a hammer.
Whilst wearing eye protection of course. I think i wrapped a rag around it whilst wacking it
regards
Steve
Edited By Steve F on 05/01/2015 21:50:48
S.D.L.05/01/2015 21:52:56
236 forum posts
37 photos
Put a groove on each side with tool of choice ( offhand grinder, angle grinder dremmel etc) wrap in rag and put in vice with groove out of jaws, hit with big hammer. If doesn't break get bigger hammer.
Steve
Frank.N Storm05/01/2015 22:37:27
50 forum posts
Must be a large lathe which uses 50 cm tool bits. I surely hope the cross-section is in the appropriate scale also.
Bad that you only get two our of your 100 cm bar.devil
Regards, Frank
Neil Wyatt06/01/2015 10:19:00
19226 forum posts
749 photos
86 articles
Don't use water to cool it. HSS can be red hot without losing hardness, but putting it hot into cold water can cause cracks.
Circlip06/01/2015 11:38:19
1723 forum posts
Dressmakers and knitters sizes. Yes Frank 1000mm cut down to 500mm must be a long toolpost or for a planing machine?
Regards Ian.
richard 206/01/2015 11:44:51
127 forum posts
Thanks everyone.
Problem solved BUT finger trouble!
The size of the blanks is 100mm not cm!
Richard
chris stephens06/01/2015 15:40:29
1049 forum posts
Hi Neil, agree entirely but when you have to cool it, to save singed fingers, "plunge" from the cold end, so there is far less thermal shock to the hot bit. Added bonus, cools the fingers too.
chriStephens
Neil Wyatt06/01/2015 16:04:42
19226 forum posts
749 photos
86 articles
Or hold it in a toolmaker's clamp or a QCTP holder!
Ian S C07/01/2015 09:32:39
7468 forum posts
230 photos
I find a pair of Vice Grips are handy for holding bits of HSS when grinding, it helps in keeping fingers well away from the grinder.
Ian S C
JasonB07/01/2015 09:39:22
Wet grinderthumbs up
Neil Wyatt07/01/2015 16:04:24
19226 forum posts
749 photos
86 articles
> Wet grinder
Plutocrat!
Bazyle07/01/2015 16:24:29
6956 forum posts
229 photos
Has anyone ever considered cutting with spark erosion using an electrode shaped to minimise subsequent grinding? A sort of N at an angle would do.
