Cutting Sheet Brass
Phil H 112/11/2014 11:51:34
128 forum posts
46 photos
I am about to start cutting some brass sheet (1' square sheets of 18g) for the Northumbrian tender. I have only ever used shears for sheet work on jobs where the 'curved' sheared edges don't matter. Does anybody have any tips for holding and cutting flimsy and expensive brass sheet to give nice clean, straight edges?
PhilH
Michael Gilligan12/11/2014 11:54:45
23121 forum posts
1360 photos
Phil,
Buy a jeweller's piercing saw and some decent [Swiss] blades.
[Sorry to be so brief: Just got back from the Dentist, and feeling rough]
Edited By Michael Gilligan on 12/11/2014 11:55:53
JasonB12/11/2014 13:20:06
Clamp the sheet between two bits of MDF or ply with the line sticking out about 1/8". 32tpi blade in a hacksaw and keep the blade fairly flat to the work.
I'd only use a opiercing saw for any curved bit. If you do have any then cut a "V" notch about 2" beep into some scrap MDF or play, clamp that flat to your bench with teh V overhanging the edge and sit at the work, the blade will pull the metal down onto the board and it will be supported around the cut by the V.
J
J
Michael Gilligan12/11/2014 13:25:30
23121 forum posts
1360 photos
Ooops ... just noticed you said 1' square sheets
... I read it as 1" square sheets, and presumed you were making something very small.
...Blame the Dentist.
Neil Wyatt12/11/2014 15:20:19
19226 forum posts
749 photos
86 articles
Or cut oversize and trim down to the line with a file or linisher - very easy to do with the latter, so take it easy!
Phil H 112/11/2014 17:52:12
128 forum posts
46 photos
Thanks.
The tender is very simple with relatively long straight lines so it looks like I'm off to B&Q for some MDF.
Taa.
PhilH
Roger Provins 212/11/2014 18:17:29
344 forum posts
I'd use a bandsaw with a 32 tpi metal cutting blade.
I keep a small 2 wheeler specially for this sort of thing.
Edited By Roger Provins 2 on 12/11/2014 18:19:23
Russell Eberhardt12/11/2014 19:01:30
2785 forum posts
87 photos
I use a 40 year old Burgess bandsaw for sheet brass using a 1/4" wide 32 dpi blade. Having three wheels it has a good throat depth for a small saw so will take a 12 inch cut. There are always a few on Fleabay.
Russell.
john jennings 113/11/2014 16:46:20
69 forum posts
I too use the bandsaw route for sheet metal cutting, both with a B&D equivalent of the Burgess and a bigger ELU wood cutting saw. A 32 dpi blade is needed and for brass will need to be sharp (new?), alloy cut by this method will tolerate a blunter blade.
My usual technique is to use 3 to 4 mm ply wood as a carriage, this damps the blade and reduces the noise.
Correctly positioned (and with a well set up bandsaw) you can run the carriage plywood edge down the fence and get very reasonable straight edges.
I must confess to having abused the B&D in the past , cutting steel blocks 1-1/2" thick and alloy blocks even thicker.
John.
IanT13/11/2014 20:25:29
2147 forum posts
222 photos
Or you could use a jigsaw and a guide like this guy Phil...although I think I'd make the gap narrower on mine
IanT
Phil H 114/11/2014 12:00:58
128 forum posts
46 photos
Everyone, thanks for all the suggestions so far.
I like the jigsaw fixture and maybe the bandsaw idea but I'm also thinking about the number of times I will cut plates like this. For example, the Northumbrian that I am building will have maybe 6 or 7 pieces of brass sheet. I think I will try the simple twin MDF sheet to cut with a hacksaw followed by filing to a line and see how I get on.
Michael/ Jason... when it comes to the fine cuts e.g. for piercing the tender pump hatch - you mention a piercing saw with high quality blades. Do you have any links to get the right blades?
PhilH
Michael Gilligan14/11/2014 12:54:31
23121 forum posts
1360 photos
Posted by Phil H 1 on 14/11/2014 12:00:58:
Phil,
I haven't bought any or a while [you do, eventually, learn how to not keep breaking them]; but I would recommend Vallorbe ... They have been making them since Noah was a lad, and I've not found any better.
They seem to be available on ebay at very realistic prices [assuming that they are genuine!]
You need at least three teeth in the thickness of the material you are cutting; so choose the pitch accordingly.
Best Wishes
Edit: ... there are a few useful comments and links in this previous thread.
Edited By Michael Gilligan on 14/11/2014 13:09:08
JasonB14/11/2014 13:06:39
You can get the Vallorbe blades here and their Swiss ones are good as well
Phil H 114/11/2014 17:49:38
128 forum posts
46 photos
Cheers.
clogs14/11/2014 19:32:51
630 forum posts
12 photos
HI Guy's, ref bandsaw blade cutting...
what pitch and Ft/per/Min do you suggest to cu 3mm 316 stainless plate, have a lot of friction plates to make for two sets of girder forks....(yes, motorcycles again)....
many thanks Frank in France
Barry McDowell15/11/2014 05:26:41
12 forum posts
Place between 2pieces of 3 or 4mm MDF and cut out with a Scrollsaw with a 32tpi or thereabouts metal blade will cut straight, curve, internal cuts without any worry. Glue / paste the outline onto the front of the MDF and just follow the line.
Barry.
Ian S C15/11/2014 11:21:56
7468 forum posts
230 photos
I'v used my band saw on thin brass, and steel without any backing, and a fairly coarse blade, just don't push too hard. The other way is to use a guillotine, set up right it should be able to cut straight and square.
Ian S C
Nicholas Farr15/11/2014 11:30:47
3988 forum posts
1799 photos
Posted by Ian S C on 15/11/2014 11:21:56:
I'v used my band saw ..................................................................
Ian S C
Hi, depending on the thickness and hardness, guillotining brass can leave an annoying little curve along the cut edge, unless it can be clamped down very close to the cut.
Regards Nick.
Derek Drover15/11/2014 13:22:43
90 forum posts
I clamp the sheet between some strips of mild steel... there's no chance of the cutting blade eroding into the steel and it'll maintain the edge.. if you drift off a little then its also easier to file down to the steel edge.. very fine blades are necessary and it elbow grease !!
Ian S C16/11/2014 11:02:44
7468 forum posts
230 photos
18 swg .048", a cheap, or worn guillotine might not leave a very tidy edge.
Ian S C
