not done it yet | 16/03/2023 07:55:43 |
7517 forum posts 20 photos | Posted by Jelly on 16/03/2023 01:23:36:
Posted by Robert Atkinson 2 on 09/03/2022 21:48:37:
The fact that plasma cutters inherently generate interference and it is difficult and expensive to mitigate is one reason why there are very few that meet domestic interference regulations. What's the implication of running equipment which meets the relevant standards for Class A (Industrial) but not Class B (Domestic) in a home environment, it's not clear from a cursory search what duty (if any) to control for EMI from CE marked equipment is placed on the end user, or from which law(s) such a duty would originate.
My plasma cutter is a 50A ESAB jobbie, the manual declares that it is designed to EN50199 (Electromagnetic compatibility - Product standard for arc welding equipment) for conformity with 89/336/EEC (the EMC compatibility directive), so in principle is it is an entirely compliant device, but it very clearly falls into Class A. When the DNO visited to discuss putting in a 3-phase supply, they didn't bat an eyelid at the equipment, because from a network perspective my utilisation levels and number of starts was well below that of several light industrial users connected to the same substation.
I would also be interested to know if running off a Gen-Set decreases or removes the problems, or if it's actually RF emissions which are the issue (as with HF start TIG welders). Edited By Jelly on 16/03/2023 01:31:09 I expect that many inverter machines specifically advise against running from a generator. Many have, I suspect, failed due to the ‘less than satisfactory waveform’ from a small generator output. Likely OK for larger much generators, but not for a lot of cheaper, small sets with very basic AVRs. |
Robert Atkinson 2 | 16/03/2023 09:05:05 |
![]() 1891 forum posts 37 photos | Posted by Jelly on 16/03/2023 01:23:36:
I would also be interested to know if running off a Gen-Set decreases or removes the problems, or if it's actually RF emissions which are the issue (as with HF start TIG welders). Edited By Jelly on 16/03/2023 01:31:09 It is illegal, technically, to connect an industrial machine to a domestic supply. A Domestic supply is one which has a third party domestic dwelling connected to the same low voltage feed from the substation / transformer. The law assumes that only industrial users will purchase industrial machines. As with many things the legislation has not kept up with the market. The problem will only be addressed when there is an incident. The consumer market sellers of these things are pushing the limits and could face action if something goes wrong.
Robert. Edited By Robert Atkinson 2 on 16/03/2023 09:05:48 Edited By Robert Atkinson 2 on 16/03/2023 09:06:53 |
Jelly | 16/03/2023 10:15:52 |
![]() 474 forum posts 103 photos | Posted by Robert Atkinson 2 on 16/03/2023 09:05:05:
The fact that plasma cutters inherently generate interference and it is difficult and expensive to mitigate is one reason why there are very few that meet domestic interference regulations. What's the implication of running equipment which meets the relevant standards for Class A (Industrial) but not Class B (Domestic) in a home environment, it's not clear from a cursory search what duty (if any) to control for EMI from CE marked equipment is placed on the end user, or from which law(s) such a duty would originate. It is illegal, technically, to connect an industrial machine to a domestic supply. A Domestic supply is one which has a third party domestic dwelling connected to the same low voltage feed from the substation / transformer. The law assumes that only industrial users will purchase industrial machines. As with many things the legislation has not kept up with the market. The problem will only be addressed when there is an incident. The consumer market sellers of these things are pushing the limits and could face action if something goes wrong. Where is that set out in legislation though and what does it say specifically? It's not just out of line with market conditions, but it is also clearly at odds with how the power distribution grid in both rural areas and urban areas with large amounts of light industrial units interspersed with housing (Birmingham, Manchester, Sheffield) functions. Edited By Jelly on 16/03/2023 10:26:45 |
Robert Atkinson 2 | 16/03/2023 12:26:15 |
![]() 1891 forum posts 37 photos | Jelly, That's the problem, the legislaation is at odds with reality. There is not a single law that says you can't plug an industrial (not light) unit into a domestic supply.
Martin Kyte | 16/03/2023 13:08:33 |
![]() 3445 forum posts 62 photos | I shouldn’t think they are bothered what you connect so long as it is not generating huge emissions. Industry pays at a different rate to domestic consumers ( and doesn’t get Gov subsidy in an energy crisis) but generally at a lower rate per kW. What’s the odds between a 3kW pressure washer and a 3kW table saw.? regards |
SillyOldDuffer | 16/03/2023 13:29:36 |
10668 forum posts 2415 photos | Posted by Jelly on 16/03/2023 10:15:52:
The fact that plasma cutters inherently generate interference and it is difficult and expensive to mitigate is one reason why there are very few that meet domestic interference regulations. ... It is illegal, technically, to connect an industrial machine to a domestic supply. A Domestic supply is one which has a third party domestic dwelling connected to the same low voltage feed from the substation / transformer. ... Where is that set out in legislation though and what does it say specifically? It's not just out of line with market conditions, but it is also clearly at odds with how the power distribution grid in both rural areas and urban areas with large amounts of light industrial units interspersed with housing (Birmingham, Manchester, Sheffield) functions. ... We can all agree that the law is often a mess. Badly worded Acts of Parliament, enforcement unfunded, delegation of powers, and a system that confirms or denies interpretations through the courts. It means what somebody thinks it means until a successful challenge changes it. Simple clear rules are unusual in my experience! Robert's definition of a 'Domestic Supply' would appeal to an engineer, but I don't think it's a rule suppliers follow. I believe the difference between a 'Domestic Supply' and an 'Industrial Supply' is more to do with the contract and tariffs rather than the actual wiring. A domestic supply assumes the consumer's needs are simple; basically about 80A single-phase, with Terms and Conditions attached that empower them to intervene if a customer breaks the rules, maybe connecting something that disrupts the neighbours supply, or upsets the distribution network. A man knocks on the door and says he will disconnect the supply unless you stop or arrange a suitable supply. The suitable supply could be industrial, one where the tariff, Ts&Cs, and wiring are all agreed to a suitable standard; that is the load is professionally matched to the supply, not just plugged in like a Hoover. A 100HP machine centre needs more than a 13A plug and a pre-payment meter! The professional matching triggers a whole bunch of different legal and safety requirements, and of course installing a big machine centre that does more than light work will change the status of the building from dwelling to something requiring planning permission, with a different tax liability. Being able to buy lots of light industrial equipment that will just about work OK in an ordinary house is a new phenomenon. Lidl and others selling tools only a business could have afforded in the recent past, to folk who just want to plug them in at home without reading the small-print. I suspect no-one will care about semi-industrial tool being a bit leery until there's a major incident. A serious complaint will result in an investigation, and then action might be taken. Unlikely we'll end up in gaol! More likely told to switch it off, or made to pay for a suitable supply. It's the paying bit that Model Engineers don't like! Dave
Maurice Taylor | 16/03/2023 14:00:50 |
275 forum posts 39 photos | Being able to buy lots of light industrial equipment that will just about work OK in an ordinary house is a new phenomenon. Lidl and others selling tools only a business could have afforded in the recent past, to folk who just want to plug them in at home without reading the small-print. Hi, Dave Please explain “just about work ok in an ordinary house”. Maurice
Martin Kyte | 16/03/2023 14:39:08 |
![]() 3445 forum posts 62 photos | I’m not sure that the law works quite the way some think it does and I guess this would be civil rather than criminal law. From the authorities side of the fence it would be about granting the power to enforce compliance where appropriate which has a good deal of judgement attached. As to that 100 hp machine someone mentioned, that would be around 3 times the current available from my supply which is 100Amps so no need to resort to the courts the supply fuse would disconnect the property itself. regards Martin
Robert Atkinson 2 | 16/03/2023 14:50:48 |
![]() 1891 forum posts 37 photos | My description of an industrial or domestic supply is that used for conducted emissions standards. Nothing to do with power cost or billing. Harmonics generated by you plasma cutter will to some extent be absorbed you the supply transformer (causing it to overheat or have insulation breakdown which the distribution company don't like) so less likely to affect a domestic user on a different connection. "just about work" may refer to equipment that draws more power than a 13A outlet is rated for but when used intermittently and / or at less than full output will work OK. I have in the past used a 4kVA power source (>16A input) on a 13A plug. However it was clearly labeled with an output current that was not to be exceeded and just to be sure had a 10A fuse in the plug. The plug fuse did operate once during a long test.... |
Martin Kyte | 16/03/2023 14:55:31 |
![]() 3445 forum posts 62 photos | Posted by Robert Atkinson 2 on 16/03/2023 14:50:48:
My description of an industrial or domestic supply is that used for conducted emissions standards. Nothing to do with power cost or billing. Harmonics generated by you plasma cutter will to some extent be absorbed you the supply transformer (causing it to overheat or have insulation breakdown which the distribution company don't like) so less likely to affect a domestic user on a different connection. "just about work" may refer to equipment that draws more power than a 13A outlet is rated for but when used intermittently and / or at less than full output will work OK. I have in the past used a 4kVA power source (>16A input) on a 13A plug. However it was clearly labeled with an output current that was not to be exceeded and just to be sure had a 10A fuse in the plug. The plug fuse did operate once during a long test.... I agree with you on emissions and I said as much in an earlier post. So when you run your ‘industrial’ kit make sure you stay within the domestic emissions limits. regards Martin |
Nicholas Farr | 16/03/2023 15:58:15 |
![]() 3988 forum posts 1799 photos | Hi, the maximum power you can use at home, is whatever the supply will allow, in my case it is 60A at 230V. I have a 30A socket to plug in my inverter welder, and it will struggle to work on anything less, basically for the arc striking threshold but doesn't use that much during actual welding, and my old manual metal arc welder has always blown a domestic plug top fuse if I use the top end of the output, so that gets plugged into a 16A socket. So what makes the difference from a Plasma cutter to a TIG welder or an inverter welder, as far as emissions are concerned? I will say that my nearest neighbour is about 100 meters away, and the local mains transformer is about 500 meters away, and I haven't had any complaints about any interference from anyone. Regards Nick. Edited By Nicholas Farr on 16/03/2023 15:59:02 |
peak4 | 16/03/2023 17:17:55 |
![]() 2207 forum posts 210 photos | If anyone's near Glossop, and in the market for one, Lidl had 4 plasma cutters in stock when we left at about 16.30 today. |
Pete Rimmer | 16/03/2023 17:57:34 |
1486 forum posts 105 photos | I wonder if anyone can find any instance of anyone ever being prosecuted or penalised in any way for using 'industrial' equipment on a domestic supply, in respect of the circumstances here? I suspect not. Many industrial units only have a single phase supply no different to a domestic one. Edited By Pete Rimmer on 16/03/2023 17:58:05 |
Robert Atkinson 2 | 16/03/2023 18:44:53 |
![]() 1891 forum posts 37 photos | Posted by Nicholas Farr on 16/03/2023 15:58:15:
Hi, the maximum power you can use at home, is whatever the supply will allow, in my case it is 60A at 230V. I have a 30A socket to plug in my inverter welder, and it will struggle to work on anything less, basically for the arc striking threshold but doesn't use that much during actual welding, and my old manual metal arc welder has always blown a domestic plug top fuse if I use the top end of the output, so that gets plugged into a 16A socket. So what makes the difference from a Plasma cutter to a TIG welder or an inverter welder, as far as emissions are concerned? I will say that my nearest neighbour is about 100 meters away, and the local mains transformer is about 500 meters away, and I haven't had any complaints about any interference from anyone. Regards Nick. Edited By Nicholas Farr on 16/03/2023 15:59:02 Industrial TIGs and inverter welders can suffer from the same issues This is only talking about plasma cutters because that was the original subject. Plama cutters do tend to be worse because the plasma is produced by radio frequency power. |
Bazyle | 16/03/2023 22:22:50 |
![]() 6956 forum posts 229 photos | Posted by peak4 on 16/03/2023 17:17:55:
If anyone's near Glossop, and in the market for one, Lidl had 4 plasma cutters in stock when we left at about 16.30 today. Note the one currently in Lidl is not the same as the one that started this long thread off. At least not in my local lidl. |
peak4 | 16/03/2023 23:20:28 |
![]() 2207 forum posts 210 photos | Posted by Bazyle on 16/03/2023 22:22:50:
If anyone's near Glossop, and in the market for one, Lidl had 4 plasma cutters in stock when we left at about 16.30 today. Note the one currently in Lidl is not the same as the one that started this long thread off. At least not in my local lidl. Yes, that's correct, the very first one they offered included a built in compressor, but was not available in any store in our area; indeed when I enquired, non had even been delivered. |
Grindstone Cowboy | 17/03/2023 12:47:53 |
1160 forum posts 73 photos | Just for info, Blackpool South Shore Lidl has accessory kits (circle cutter, etc.) and consumables, but no actual units. Rob |
Nicholas Farr | 17/03/2023 13:38:16 |
![]() 3988 forum posts 1799 photos | Posted by Robert Atkinson 2 on 16/03/2023 18:44:53:
Hi, the maximum power you can use at home, is whatever the supply will allow, in my case it is 60A at 230V. I have a 30A socket to plug in my inverter welder, and it will struggle to work on anything less, basically for the arc striking threshold but doesn't use that much during actual welding, and my old manual metal arc welder has always blown a domestic plug top fuse if I use the top end of the output, so that gets plugged into a 16A socket. So what makes the difference from a Plasma cutter to a TIG welder or an inverter welder, as far as emissions are concerned? I will say that my nearest neighbour is about 100 meters away, and the local mains transformer is about 500 meters away, and I haven't had any complaints about any interference from anyone. Regards Nick. Edited By Nicholas Farr on 16/03/2023 15:59:02 Industrial TIGs and inverter welders can suffer from the same issues This is only talking about plasma cutters because that was the original subject. Plama cutters do tend to be worse because the plasma is produced by radio frequency power. Hi Robert, there seems to be an awful lot of companies selling Plasma Cutters where the public can buy them, even two well know High Street retailers, and none of them say they are for industrial use only, and have a looked through the instruction manual of one of them, the only environmental protection that is mentioned for private households, is the disposal (WEEE) and not to include them in household waste. So are these people wrong for selling such things to the public, or not saying they are for industrial use only? Furthermore, I've looked online for regulations about the use on domestic power, and haven't found anything to say they shouldn't be. I don't actually have a plasma cutter in my garage, and don't have any immediate plans to get one. I have used them at work, and in one of my jobs the workshop was next door to a private house. Regards Nick. |
Milly S | 24/03/2023 07:15:52 |
42 forum posts 9 photos | Hi Ian I’ve read all the comments on the plasma cutter I was also wondering weather to buy one my local Lidl have them in store now £150 not sure if i should buy one what do you use yours for this one needs a separate compressor at least 4bar
Robert Atkinson 2 | 24/03/2023 08:14:25 |
![]() 1891 forum posts 37 photos | Posted by Nicholas Farr on 17/03/2023 13:38:16:
Hi, the maximum power you can use at home, is whatever the supply will allow, in my case it is 60A at 230V. I have a 30A socket to plug in my inverter welder, and it will struggle to work on anything less, basically for the arc striking threshold but doesn't use that much during actual welding, and my old manual metal arc welder has always blown a domestic plug top fuse if I use the top end of the output, so that gets plugged into a 16A socket. So what makes the difference from a Plasma cutter to a TIG welder or an inverter welder, as far as emissions are concerned? I will say that my nearest neighbour is about 100 meters away, and the local mains transformer is about 500 meters away, and I haven't had any complaints about any interference from anyone. Regards Nick. Edited By Nicholas Farr on 16/03/2023 15:59:02 Industrial TIGs and inverter welders can suffer from the same issues This is only talking about plasma cutters because that was the original subject. Plama cutters do tend to be worse because the plasma is produced by radio frequency power. Hi Robert, there seems to be an awful lot of companies selling Plasma Cutters where the public can buy them, even two well know High Street retailers, and none of them say they are for industrial use only, and have a looked through the instruction manual of one of them, the only environmental protection that is mentioned for private households, is the disposal (WEEE) and not to include them in household waste. So are these people wrong for selling such things to the public, or not saying they are for industrial use only? Furthermore, I've looked online for regulations about the use on domestic power, and haven't found anything to say they shouldn't be. I don't actually have a plasma cutter in my garage, and don't have any immediate plans to get one. I have used them at work, and in one of my jobs the workshop was next door to a private house. Regards Nick. Hi Nick, sorry for late reply. I wasn't following the thread closely. Robert. |
