Here is a list of all the postings Milly S has made in our forums. Click on a thread name to jump to the thread.
Thread: Drain plug |
04/10/2023 22:14:03 |
Thanks Stuart & not done it yet i had used hose to siphon oil out of filler cap which worked fine but a little slow just wanted to know where drain plug is for future reference might have to strip headstock as knocking noise suddenly appeared cheers steve |
03/10/2023 19:37:25 |
Hi all I want to change the oil in my Chipmaster headstock can’t seem to find drain plug found the drain plug for gear box can anyone help please this is the metric lathe cheers steve |
Thread: Colchester Chipmaster |
01/10/2023 20:11:16 |
Hi emgee thanks for the link cheers steve |
28/09/2023 21:38:24 |
Hi all I’d just like to say thanks for your help As always everyone is very helpful I just hope i can return the favour one day cheers steve |
28/09/2023 18:37:49 |
Hi Pete thanks for your reply haven’t had a chance to download web site you posted I’ll try to get to it tonight’ cheers steve |
28/09/2023 18:35:11 |
Hi daggers thanks for info on headstock the hole in the headstock has got 2 grub screws in the same hole in relation to each other thanks steve |
Thread: Chipmaster |
27/09/2023 21:03:07 |
Hi ady this is the photo with holes in headstock hope it helps cheers Steve |
27/09/2023 19:51:45 |
Hi ady I posted a picture a few days back got no reply so I thought I would try again this time just asking for Chipmaster owners in the photo I posted it showed 2 holes 1 in headstock & 1 just behind chuck These were in the machine when I bought it a couple of month back I was wondering if they had a specific use or if someone had tried to add something they both have grub screws in just wondering if any other chipmastes have these holes in as this is the 1st time I’ve bought a Chipmaster thanks for replying regards steve |
27/09/2023 18:59:03 |
Hi all does anyone on this forum have a Chipmaster please reply thanks steve |
Thread: Chipmaster lathe |
25/09/2023 16:56:36 |
Hi does anyone know what these holes are for not sure if they should have an oiler in or grease nipple cheers Steve
Thread: Gear wheels |
31/07/2023 19:22:53 |
Hi Howard my Chipmaster is the continental ive only had it a few weeks trying to collect everything that goes with it the gears that came with 1 of them had a broken tooth with advice I received from forum members i decided to repair it myself by welding & filing it turned out perfect im collecting a set of change gears as I’ve started single point screw cutting mainly to replace parts for my sons garage thanks steve |
31/07/2023 16:08:23 |
Hi I’m after 2 gear wheels for Chipmaster 24tooth & 66tooth tried to put these on wanted adds with no luck maybe someone can advise please cheers steve |
Thread: Gear |
26/07/2023 17:29:27 |
Hi all sorry it wasn’t 46t it is 48t eyes not as good these days Cheers steve |
25/07/2023 16:40:20 |
Hi all I’m after a 46 tooth gear for Chipmaster the one that came with machine has tooth missing tried eBay with no luck any help appreciated cheers steve |
Thread: Stud |
18/07/2023 18:37:47 |
Hi thanks for all your help thats the one,the manuals a bit confusing cheers steve |
18/07/2023 17:29:48 |
Hi it’s not on the cover plate it holds the rear splash guard this is the only bolt that secures it it screws into back of headstock the part number is 1228 but it does not say what thread it is cheers steve
18/07/2023 17:16:03 |
18/07/2023 15:37:31 |
Hi all If you have a Chipmaster can you let me know what size thread is on the stud that holds the splash guard on please cheers steve Edited By Milly S on 18/07/2023 16:06:50 |
Thread: Edit advert |
13/07/2023 07:56:12 |
Thanks for help Jason much appreciated cheers Steve |
12/07/2023 19:12:54 |
Hi all can someone advise on editing a classified ad I’ve placed & forgot to ad a photo cheers Steve |
