Nick_G | 31/08/2017 12:32:12 |
![]() 1808 forum posts 744 photos | Posted by Bazyle on 31/08/2017 12:25:52:
250lbs. How you going to lift it? Some pictures of that operation might be helpful for others getting this size. . 2 people. Strongest one at the headstock end. Any more than that on a small machine and they would get in each others way. Nick |
V8Eng | 31/08/2017 13:19:15 |
1826 forum posts 1 photos | Posted by jimmy b on 31/08/2017 12:05:08:
Good point about sand in the base. Would give weight and potentially reduce vibrations.
Jim Those half moon shaped weights they put in washing machines 'aint arf heavy' and they have a couple of flat surfaces. No idea what they are made of though!
How about some photos of all these goings on for this forum? Edited By V8Eng on 31/08/2017 13:23:05 |
JasonB | 31/08/2017 13:35:37 |
![]() 25215 forum posts 3105 photos 1 articles | According to the Twitter posts you need "Wes" to pick up the heavy end. Some pics there too. I can (just)pick up the headstock end of my 280 when still fixed to the stand so I should think Neil can manage the tailstock end of an SC4. I just keep faceplate, steadies, etc in the stand and have draws with tooling in between and it does not seem to jump about even with some large out of balance castings on it |
Dave Martin | 31/08/2017 14:00:51 |
101 forum posts 11 photos | Posted by Ian S C on 31/08/2017 12:28:07:
I'v got half a dozen 7.62 mm Ammo boxes full of lead, that's the stuff for ballast. Ian S C Just lead - or propellant as well? (guess that would then be blast not ballast though!) |
Neil Wyatt | 31/08/2017 14:05:52 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 31/08/2017 13:35:37:
I can (just)pick up the headstock end of my 280 when still fixed to the stand so I should think Neil can manage the tailstock end of an SC4. I can just lift the headstock end of the SC4, but as Wes (one of my steplads) now drives and unloads HGVs and previously used to carry granite kitchen worktops about in one hand I thought I would let him do the hard work. We managed to go from front drive, through the house and into the workshop in one, but I think we were both glad to get it down We still have to lift it on the stand tonight, I've made a downpayment in Foster's. The SO is wondering how we managed to move the lathe within a couple of hours but the old washing machine is still in the garden... I'm not worried about the stand going anywhere, but I might screw it down if I can figure out a way of doing so! Neil |
not done it yet | 31/08/2017 15:42:50 |
7517 forum posts 20 photos | I might screw it down if I can figure out a way of doing so! It does say it is designed to be bolted to the floor. Nothing about screws, mind
JasonB | 31/08/2017 17:41:25 |
![]() 25215 forum posts 3105 photos 1 articles | And you can see the bolt holes in the photo you linked to. If its a wooden floor then couple of coach screws would do |
Neil Wyatt | 31/08/2017 19:33:31 |
![]() 19226 forum posts 749 photos 86 articles | I can see the holes, but how do I push bolts up through the floor from underneath without ripping it up? There's only about 1 1/4 inches of headroom over the holes so no way to get a coach screw in. Methinks two wooden strips overlapping the base and screwed to the floor will do the job. Neil |
JasonB | 31/08/2017 19:39:35 |
![]() 25215 forum posts 3105 photos 1 articles | mark hole positions with a pencil through the holes, move stand so you can pilot drill the floor. Pack stand up off the floor 3", poke a 4" coach screw through teh hole (should fit at an angle) then wind it 1" into the hole, lower stand 1" and screw another inch, etc. However if it is only going to screw into a floorboard then 1" screws will do. Alternatively don't bother screwing it down, mine is not and stand is almost identical design. |
MichaelR | 31/08/2017 20:06:27 |
![]() 528 forum posts 79 photos | Threaded Head wood screws, mark position screw into wood floor drop cabinet over and bolt up. Mike. **LINK** |
Neil Wyatt | 31/08/2017 21:39:23 |
![]() 19226 forum posts 749 photos 86 articles | It's not getting bolted down fast... I can't get the gearbox door fully open, so I might have to saw 8" off my mill/handwork bench and put that across the end of the workshop and the lathe can go where it was... Anyway, got it running and did the classic of discovering it doesn't work with the guard open... Lots of head scratching before I worked out how the standard feed and cross feed interlock with each other. At least it seems to be impossible to engage them both at the same time. This does seem to be a very well thought out machine, look at those oil points and highly useful t-slots on the cross slide and top slide. These are meant for using it with a milling attachment on the back of the bed but in practice will provide lots of options for workholding or mounting accessories. Way more complicated than a mini lathe. It's going to be a busy weekend moving benches and cleaning this troll snot off the lathe. Then lots of adventures ahead like parting off under power crossfeed! |
Nick Wheeler | 01/09/2017 00:38:07 |
1227 forum posts 101 photos | Posted by Bazyle on 31/08/2017 12:25:52:
3ft long (910mm) so you could use a paving slab if you can get a good old 2in thick one between drip tray and stand. 250lbs. How you going to lift it? Some pictures of that operation might be helpful for others getting this size. Easy job for two people. One at each end. Using equipment such as engine cranes is just making work for yourself.
We carried my wm250 across the road, down the cellar steps, through both doors and onto the bench. |
JasonB | 01/09/2017 07:30:40 |
![]() 25215 forum posts 3105 photos 1 articles | It will be interesting to see how far to the right that top slide moves as there is a lot of overhang where the toolpost is at the moment. |
not done it yet | 01/09/2017 08:31:07 |
7517 forum posts 20 photos | I see it has a four way tool post - are you going to retain it or get a QCTP? If the latter, I would advise against an Arc Euro 'set'. Buying separately is the way to go and here are a few reasons: Not really cheaper as you prolly won't want all the different tool holders in the set. The knurling tool is an excessive pressure jobbie - not good for the lathe and the scissor types are far superior (even if a little/lot more expensive). The parting tool holder is carp (well, mine is). The parting blade is fitted at an angle, so every time the blade is extended or retracted (for different diameter cuts) it must be reset at centre height! More normal, simple tool holders are the real priority - the cheapest ones in the 'kit'. Might be more, but will post now. IMO it would have been far better to offer a good price on the tool post and half a dozen, or so, normal tool holders (with maybe one of them with a V notch able to accommodate a round boring tool).
JasonB | 01/09/2017 08:59:55 |
![]() 25215 forum posts 3105 photos 1 articles | twitter photo shows the QCTP in it's box. Can't quite see which one it is but the QCTP set for the SC4 that ARC suggest on their site just comes with just standard tool holders
Edited By JasonB on 01/09/2017 09:10:08 |
MW | 01/09/2017 09:53:55 |
![]() 2052 forum posts 56 photos | I only just realized that the micro lathe comment was just a farce! Michael W
Edited By Michael-w on 01/09/2017 09:54:35 |
Neil Wyatt | 01/09/2017 10:10:41 |
![]() 19226 forum posts 749 photos 86 articles | Posted by not done it yet on 01/09/2017 08:31:07:
I'll explore different QCTP possibilities. I don't understand your issue with the parting tool holder? How can you have one that holds the tool at an angle and doesn't need height adjustment if you extend the blade? Even my home-made QC parting blade holder works like that. the alternative is my inserted tip parting tools which fit in an ordinary tool holder. Having made both scissor and push-in knurling tools, I am far from convinced that the 'excessive pressure' argument really applies in these days of lathes with hefty rolling-element bearings in the headstock. I've shown this before, a 2 1/4" straight knurl done with a push-in tool on my mini-lathe, and it really wasn't difficult or traumatic: |
MW | 01/09/2017 16:53:35 |
![]() 2052 forum posts 56 photos | I much prefer solid ground to shape parting tools or insert ones rather than the parting blades, they have a suberb ability to bend even at relatively short lengths! I've never had a problem with knurling, I always follow the rule that you have to run them back up the length of the part in order for it to cut well. Michael W
Neil Wyatt | 01/09/2017 21:10:21 |
![]() 19226 forum posts 749 photos 86 articles | Posted by JasonB on 01/09/2017 07:30:40:
It will be interesting to see how far to the right that top slide moves as there is a lot of overhang where the toolpost is at the moment. I've checked, it moves a long way, right past where it is fully supported. About ~15mm overhang when aligned with the edge of the cross slide. I guess a tool in a QCTP holder should be past the edge of the cross slide with the dovetail fully engaged. Looks like I finally have a machine I can use my Wimberley tool holder with - I've waited about two years to try it! This is the US alternative take to tangential tooling. Neil Edited By Neil Wyatt on 01/09/2017 21:11:35 |
Hacksaw | 01/09/2017 21:29:01 |
474 forum posts 202 photos | Is knurling done dry or lubed ? |
