Is a separate drive for the lathe cross-feed worth the extra money?
Gray62 | 27/08/2013 18:14:25 |
1058 forum posts 16 photos | Would not be without power X-feed. Use it all the time for facing cuts and parting off. I use HSS parting tools and have never broken one using the power feed, anything up to 75mm is a breeze with the standard feed rates. CB |
Howard Lewis | 27/08/2013 19:14:31 |
7227 forum posts 21 photos | When I changed lathes, ten years ago, PXF was a MUST. The Myford Super 7 Sigma was my choice until I found the cost AND that PXF could not be fitted. I use it pretty much all the time. Whether you CAN have PXF will depend on how big a lathe you can accomodate. My lathe is an Engineers Tool Room BL12/24, very similar to the WARCO BH600, or the Chester Craftsman. Warco offer the BH600 in Imperial or Metric form. I think that Chester only offer the Craftsman in Metric form. The BL12/24 is basically Metric but is dual dialled, and so suits me as an Imperial Luddite who infrequently uses Metric. I have never been brave enough to part off with PXF, despite having madeand fitted a Backtoolpost, so can't comment. But for Facing, my view is that PXF is a must. A personal slant is that I am extremely happy that the lathes listed above have a separate feed shaft, as I was used to as an Apprentice, and do not use the leadscrew to power either sliding or facing feeds. As another aside, I made a 80T 1.25Mod gear for the Norton Box on the BL12/24to halve the feedrate, which meant repositioning the closure for the backgear cover. It is a worthwhile modification, allowing, using slow speeds and sharp tools, with lubrication, superb finish. Hope that this helps a little. Howard
mechman48 | 27/08/2013 20:07:19 |
![]() 2947 forum posts 468 photos | Jerry… Good choice I have put down a few pointers for you when you get your machine; other members may have different items to offer, but these are what I found on my machine, 250V-F. Check the electrics when you get it; the two main problems I found were that the change gear guard has a tab on the bottom at the back (250V-F, other machines may have it placed elsewhere), this tab contacts and operates a micro switch for the motor cut out, this tab had been bent away from the switch making it unable to start… frustrating when still in the box! The other item is check the locking collar on the emergency stop button, this is secured (on mine) by a screw acting on the locking bracket & jacking the bracket against the top of the electrical compartment casing & pulling the button down against the casing top, this had the effect of allowing the button to rotate loosely which then had dislodged one of the wires from the button hence … no workee… scratchee head… along with a lot of ‘oh dear me’ ‘tut tut’, or words to that effect!... & supposedly checked by Warcos Engineers… ? Check all the fastenings on the machine; SHCS & bolts, these are made from the Chinese basic steel… crap! The SHCS / Hex head bolts are stamped 4.2 which is lower tensile strength than the minimum BS3692 of 4.6… in other words ‘soft as s**t! so it doesn’t take much torque to strip threads... trust me I know! Especially the two compound slide T bolts that hold the compound slide to the cross slide, on mine I found these to have stripped very soon after a couple of angle settings on the compound, & not tightened to any excess (subjective I know!) merely snugged up. I replaced these with a couple of 8.8 grade bolts & fabricated some proper ‘T’ nuts from decent steel… EN8 IIRC. plus they were short in length stopping short of the full nut so I ensured that my replacements went down into the ‘T’ nut full length. The change wheel gears are noisy, this was due to the backlash being incorrectly set up, (don’t think the manufacturers know what this is) I set mine up using the ‘paper method’ (which it seems a few members have used). All it needs is to place a piece of paper, which is generally about .004” thick between the meshing teeth & adjusting the banjo to nip the paper, do this with each gear mesh. The other factor is there is a lot of slop … on mine… between the ID of the gear bore & the OD of the matching banjo shaft. I am looking to reduce this by some means later on, bushings, new shafts? Adjust your gib strips as these are made from the above mentioned steel, not cast iron, & are just strips of plate with the angles somewhat ground on & they don’t ensure that the gib screws fit, it seems that their idea of dimples is to ram a pistol drill down the tapped hole irrespective of the strip being in the correct location or centralised, followed by three or four black SHCS with lock nuts on. I will replace these later if I can get hold of some thin enough CI, or poss’ Phos’ Bronze/ Brass Hopefully you get a machine that has had better quality control applied, never the less now I have tweaked, adjusted, replaced etc. I have a very reasonable ‘hobby machine’ that does what I have thrown at it, after all, ‘you don’t get a rolls for the price of a mini’, other members may /may not have had similar issues, so I assume they may offer additional tips, anyhow the main point is … ‘enjoy’ Cheers George |
JasonB | 27/08/2013 20:31:23 |
![]() 25215 forum posts 3105 photos 1 articles | The 280 also has the same tab to work the microswitch, mine was fine. Being a 2008 machine it has a rectangular switch which won't rotate. Still on all the original fixings though I may have lost one of the chuck nuts, no sign of the sockets rounding or threads stripping. Using original compound fixings. Did remesh the change gears but you will want to do that whenever you change them anyway for screwcutting etc. Still on original gibs with just the occasional adjustment.
Maybe I got a Monday morning one |
Jerry Wray | 27/08/2013 20:53:36 |
84 forum posts 4 photos | Thanks for all the contributions, most encouraging when the spend approaches £2000 ! Andrew, Glad you pointed out my conflicting statement about fun. I had not thought of it that way. I have never had a machine of my own with PXF but it seems it's the way to go; I don't have a lot of patience now I'm near retiring and 'twiddling' the feed may just drive me mad. George; Thanks for the pointers, I'll have to check those things, and of course all the bits that might be less than perfect, and Jason I am even more encouraged that your experience with the 280 has been good,. When I get it I'll try to remember to post some pictures. Jerry
JasonB | 27/08/2013 21:09:29 |
![]() 25215 forum posts 3105 photos 1 articles | Well I did have one motor brush wear quickly, the 60p replacement set have lasted 4 years. One head bearing dried out so I replaced the pair with better FAG ones And the speed control pot on the front of the machine went, few quid to replace. It has done a lot of work, half a 2" traction engine, one IC aero engine, one vee twin 4 stroke,two large stationary steam engines and three hit & miss engines Edited By JasonB on 27/08/2013 21:10:15 |
Andrew Johnston | 28/08/2013 10:21:13 |
![]() 7061 forum posts 719 photos | Jerry: It was, of course, a tongue in cheek comment. Parting off under power is a controversial subject. A few weeks ago I was talking to a couple of professional machinists. One always parted off under power, the other always parted off manually. I don't have direct experience of Warco machines, but in my experience most far east tooling uses very soft SHCS. This includes 'professional' tooling, as well as ME. I don't manage to strip the threads, but I find that the hexagon sockets tend to 'round' very quickly. I normally replace the screws as a matter of course on new tooling. Regards, Andrew |
Russell Eberhardt | 28/08/2013 11:24:59 |
![]() 2785 forum posts 87 photos | Thought I'd give parting off under power another go while making a batch of screws from 5/8 in bar. I had been parting off by hand using a 1.5 mm HSS blade. Tried under power with a 3 thou/rev feed and the first one worked perfectly with a nice finish. Tried second one, it got halfway then bang! A chunk came off the tip of the tool. Back to parting by hand winding to finish the batch. I can hear and feel what's going on and control the rate of feed accordingly. Maybe power Xfeed is better for parting larger components with a wider tool? I'll give it another go. Any pointers from those who regularly do this? Russell. |
Another JohnS | 28/08/2013 11:57:38 |
842 forum posts 56 photos | re: power cross feed. I've two manual lathes; one full blown with all the knobs and gadgets, a smaller one with change wheels for the lead screw, and no power cross feed. The smaller one - I've never missed having power cross feed, and have never used the leadscrew for power feeding for turning. The larger one - use both feeds all the time! I think that the reason is that I do small things on the smaller machine, so the machining goes quickly by hand twiddling. Another JohnS |
Bazyle | 28/08/2013 12:24:15 |
![]() 6956 forum posts 229 photos | Jason, Have you identified a Grizzly equivalent manual for this lathe? Jerry, You don't have to post pictures - we don't ask for proof of lathe ownership |
JasonB | 28/08/2013 12:41:08 |
![]() 25215 forum posts 3105 photos 1 articles | Russell I tend to part at a much slower feed rate, usually finest on the machine which is 0.00075"/rev so about 1/4 of what you tried. On small work say 1/2" or less I use a 0.050" blade over that either a 3/32" eclipse in the Dickson holder or one of the Chronos tipped tools which has a 2mm bit. Bazyle I've not had the need for a Grizzly manual the Warco one has been OK. Though I don't think they do an equivalent anyway Edited By JasonB on 28/08/2013 12:41:43 |
Andrew Johnston | 28/08/2013 15:26:58 |
![]() 7061 forum posts 719 photos | For parting off on my main centre lathe I normally use insert tooling, 3 mm wide. I lock the saddle at the appropriate point; the top slide is always locked unless actually in use. For low carbon steel I'll run about 3-400rpm and a feedrate of at least 4 thou/rev; below that I find it chatters. I also use flood coolant on everything except those metals that produce fine chips (brass and cast iron), and plastics. The last dig in I had was because I was in a rush and didn't use coolant on a piece of aluminium. On the repetition lathe, which is all manual and uses 5/16" square HSS, I just pull as hard as I can on the handle! I recently made, and parted off, several hundred aluminium spacers from 8mm diameter stock. I've just measured the thickness of the resulting swarf: 12 thou. I parted off at top speed, about 1000rpm. So, there we have it. Lower feedrates, higher feedrates, slow speed, high speed; I suspect the answer is that there is no surefire recipe for successful parting off. Regards, Andrew
Stub Mandrel | 28/08/2013 19:39:46 |
![]() 4318 forum posts 291 photos 1 articles | > surefire recipe for successful parting off. It's a zen thing. Neil |
Howard Lewis | 29/08/2013 10:42:45 |
7227 forum posts 21 photos | Like many others, I have found parting off works better using a back toolpost (which is what is always used on Capstan lathes). Various explanations have been offered for this, (pressure on dovetails. etc) This carries a 3/32 blade in a holder which allows a little flexibility. This blade is ground at angle, so that the workpiece should have no central pip, (left on the base stock). Theoretically, this is bad because the swarf is wider than the slot, but it works OK virtually all the time, maybe the flex in the holder helps In the Front toolpost, I sometimes use a 2mm replaceable tip tool, and very rarely does it dig in. |
Jerry Wray | 29/08/2013 12:13:19 |
84 forum posts 4 photos | Many thanks to all the contributors to this thread, I've now placed my order with Warco, who expect to deliver it in early October. Andrew, your comment following my 'fun' and twiddling post was understood in the way you meant it. It's amaxing how easy it is to make a remark without understanding that others might interpret it in a different way! To be honest I had not thought of the boundary between various levels of mechanisation. I now to think about some of the other issues I might have.. For that I will start a new thread. Once again many thanks for all the useful information. Jerry |
mechman48 | 29/08/2013 18:40:30 |
![]() 2947 forum posts 468 photos | As far as parting off under power goes, I have always been reluctant to & always used manual when I’ve had to, mainly due to lack of confidence & not have the correct set up. I think I have now resolved my issue; I needed to have some large washers to replace the ones holding my vice to the mill table as the present ones are the large penny / patch ones, backed up with a couple of 10 mm standard washers. I decided to put my Hemmingway kit (usual disclaimer) constructed rear tool post to the test & part off some 30mm dia. BMS that I had drilled 10.5mm, I have used this tool post before but only on brass as a test after I built it. Having set it up true& checked centre height I proceeded to part of … manually first, the cut went ok provided I applied plenty of neat cutting oil with one hand & trying to maintain constant feed rate with the other, (really could do with 3 hands here). Two washers were completed ok but the finish wasn’t the best so in for a penny etc. I went for the PXF... I locked everything down & my speed was set at 200 rpm (arbitrarily) & the federate was as set originally from day one…. .03mm per rev. the lowest setting on the machine chart. I set the leadscrew to run in reverse, actuated the crossfeed lever & set to, the cutting action was very smooth but it soon told me when it started to get tight, I could discern the swarf trying to bind in the cut, this was remedied quickly by applying a constant supply of neat cutting oil, by brush (I don’t have a constant supply set up … yet) which made cutting a lot easier. There wasn’t any noticeable loading on the motor & it did the cut well, which has done wonders for my confidence now, also the finish was much better. Still goes to show, you can teach an old dog new tricks! The blade used was HSS 3/32, I also have a small ¼” HSS tool steel cutter that I have ground to 1mm thick blade for small parting off which I have used without any fear. I am tempted to get one of the indexible insert type parting tools, complete with holder but it’s a bit pricey at £32 (RDG) but do I do enough parting off to warrant the expense... hmmm? First attempt at PXF parting off in years...
The remaining rag shows parallel cutting... The two on the left were manual feed, bit of a rough finish, (the dark one is 'cos the flash didn't reach it, it's not heat discolouration)) the one on right is PXF parted off & much better finish... I shall not now be wary of using PXF with the rear tool post on steel. George |
JasonB | 29/08/2013 19:01:46 |
![]() 25215 forum posts 3105 photos 1 articles | Mechman, there is nothing to stop you using the "C" position when using cross feed which should give you half what you have now assuming your chart is anything like mine which leaves most of the "C" position blank. |
