Who labelled the X and Y axes for DROs on lathes and mills?
Buffer28/01/2023 09:14:26
430 forum posts
171 photos
On my lathe DRO next to the displays I have drawn an up and down arrow for the cross slide and a left and right arrow for the carriage. This way I don't even have to think what the axis are labelled as.
Thinking about it now I suppose an up and down arrow might confuse some people!
SillyOldDuffer28/01/2023 09:38:47
10668 forum posts
2415 photos
Another example where our forefathers weren't consistent and it's too late to fix now.
I'm not aware of a Standard. Developers are free to choose which way is 'up', 'right' and 'forward', where the origin is, and whether spin is clockwise or anti-clockwise. So instead of having a clear Standard, we have to cope with different local conventions - what somebody thought was best at the time.
Many differences! For example, in maths, science, and engineering, it's conventional for graph paper to be laid flat on a table so that the X-axis goes right/left, and the Y-axis goes front/back. All fine and dandy until the graph is pinned to a wall, when the Y-axis is aligned on a line running to the earth's centre, which we call up/down. This is unfortunate, because by convention the Z-axis is up/down. More! The origin is conventionally bottom left on a graph, but not in computer graphics, where the origin is always top/left and Y is up/down.
The inexpensive DRO on my mill doesn't label the axes; I have to remember what the displays refer to. Not a problem until DRO is fitted to other machines, in which case I would urgently need to label them consistently. As I can't remember what day it is, I'd never get flipping axes right when moving between machines.
On the forum I avoid typing X,Y, Z unless the meaning is unambiguous. Safer I think to say up/down, right/left, or to&fro.
Edited By SillyOldDuffer on 28/01/2023 09:39:15
John Haine28/01/2023 10:53:11
5563 forum posts
322 photos
Posted by Martin Kyte on 27/01/2023 23:06:00:
Not sure why that is confusing John, the controlled point that is the tip of the threading tool is rotating clockwise relative to the work.
regards Martin
Hmm. Well it got me puzzled the first time I threaded in M3 and I know others have been confused too from postings on M3 Support. One is used from milling to the CP being the centre of the rotating tool, the lathe is different. Part of the problem is that the M3 thread wizard isn't remarkably clear. This is "settings":
As a novice to Mach3, what "splindle" direction would you select for a RH thread? The correct answer is CW but for a lathe user that's reverse. Clearly the UI was designed by a software engineer.
norm norton28/01/2023 11:07:28
202 forum posts
10 photos
To set any worried minds at rest, I am not at all distressed at how I have been required to label my lathe DRO axes. I was just a little interested in the history as to when this might have come about. My tongue was slightly in the cheek.
I like the suggestion that the labelling of the axes was well before the time of DRO's and dates to the very earliest, complex automated machinery.
We all seem to be happy that the convention for milling machines in mapping X, Y and Z is agreed. This suggests that hobbyist equipment is being labelled in a similar manner to the types of industrial machine.
The interesting difference is in the lathe. There seems to be a consensus on what (I assume) is big industrial use for the spindle axis to be Z, and this make a lot of sense. If you take a great big mill, lay it on its side, the machine might look lathe-like but that spindle direction is still Z.
Perhaps we have a distinction between big industry and hobbyist/small industry suppliers of of scales and DROs. The responder who helpfully used bold type to point out my error in their eyes with a quote - "Who labelled the axes for DROs on a lathe as X and Y? You did." might note that I was following the supplier's manual. I have seen three different manufacturer's manuals that all agree on the small lathe X and Y labelling.
I have now fitted DRO's to four machines and if you obtain a two-axis lathe kit it comes with a X and Y labelled DRO. The X control has a specific function to x2 (times two) the X axis movement and it helpfully illuminates a 'diameter' LED. Therefore you cannot swap X and Y and retain this function.
If you obtain a three axis lathe DRO kit (hobbyist again) and put the Z scales in the top slide, then the Y and Z can be 'added' by a DRO push button. This is quite helpful on my Myford when you bring the saddle up to the work and finish with a few thou of cut on the top slide (set true on the Y axis) - the Z display will show the total travel into the work.
Robin28/01/2023 11:13:05
678 forum posts
It's like trying to remember that the word data is plural. Always sounds wrong.
On my lathe the DRO shows numbers for X and Z.
If I want to zero Z, I press the button next to the Z value.
If I want to set Z, I can press the Z button until the cows come home with no effect...
I have to press the Y button instead.
Whoever set it up didn't like the taste of XZ any more than I do. It just sounds icky sad
best
Robin
Martin Kyte28/01/2023 11:26:29
3445 forum posts
62 photos
Posted by John Haine on 28/01/2023 10:53:11:
regards Martin
Yes, I can see your point. Once you add a layer of user interface on top you get a little more remote from the machine. I suppose I was just thinking about the machine itself and how I would label the axis and it does seem logical to me.
regards Martin
Dave Halford28/01/2023 11:26:39
2536 forum posts
24 photos
I think it might be history.
When you designed a DRO back in the day on paper, at a drawing board XYZ suited a Mill, graph layout for the table and the alphabet. Later when making a cheaper one for a lathe it looks a little silly to delete the centre display and also harder to take the circuitry out.
Circlip28/01/2023 11:28:21
1723 forum posts
My vernier clopolipper doesn't give a - - - -
Regards Ian.
Martin Kyte28/01/2023 11:39:42
3445 forum posts
62 photos
Does the CW/CCW question on the lathe have a parallel with the axis directions on the mill. With a mill the CP is the centre of the cutter in the spindle as John says. However as the table moves not the spindle the direction of travel is in the -X in order to create a +X CP movement.
Similarly on the lathe with the CP at the tool tip which cannot rotate, in order to create a CW rotation of the CP the work (and thus the spindle) must rotate in the opposite direction which is CCW.
regards Martin
Nicholas Farr28/01/2023 11:48:19
3988 forum posts
1799 photos
Hi John, I suppose that it all depends on one's understanding of the meaning of the words, for example, the start button for a lathe spindle is often stated as forwards and reverse, which doesn't really make sense, because for machining with the tool on the same side of the work as the operator, you would press the button for forwards, that would mean the material you are about to cut, would be going backwards from the operators point of view, i.e. the workpiece would rotate from the back of the machine towards you. So looking at it from the spindles point of view to the work, it would in fact be going clockwise. It can be very confusing, e.g. do the wheels on your car turn clockwise or counter clockwise, when the car is traveling forwards? Answer, depends on which side of the car you are viewing them from and if you are inside the car, they would be reverse of what anyone would see on the outside, but they would still be rotating in the same direction. It's starting to muddle my grey cells now.
Regards Nick.
Edited By Nicholas Farr on 28/01/2023 11:58:59
Martin Connelly28/01/2023 12:44:09
2549 forum posts
235 photos
The rotation axes are about the translation axes in the following relation ship. A is rotation about X, B is rotation about Y. C is rotation about Z. The positive direction of rotation is clockwise if it is looked at along the relevant axis going from small to large positive values. This is the same as a conventional right hand thread and is referred to as the right hand rule. For a conventionally laid out lathe this means that a lathe that is rotating clockwise should be turning in the conventional turning direction, ie top towards the operator. You have to look at the Z axis from the headstock towards the tailstock to see that this is in fact clockwise. A drill in this lathe's chuck will drill towards the tailstock, ie the drill's Z position would be increasing positively relative to the workpiece, if it could move.
With a mill the C axis about the Z axis is normally turning anticlockwise and you push the drill into the workpiece by decreasing the Z axis value. To see the correct direction of rotation of a mill spindle you would have to look from the R8 socket (or whatever your mill has) towards the drawbar end of the spindle as this is the direction of increasing positive Z.
It is easy to be confused if you look at a rotational axis from the wrong direction. From the tail stock a chuck that looks like it is rotating CCW will, at the same time, be going CW when looked at from the head stock end of the lathe. It is unsurprising that these concepts can cause confusion, especially for someone sat at a desk working out what to put on the screen for a piece of software.
Martin C
PS When thread milling an outside thread from top to bottom and rotating the cutter about the workpiece you are doing something analogous to single point threading in a lathe. If you thread mill a conventional RH thread this way your Z axis is going from larger Z value to smaller Z value and at the same time the tool is orbiting the workpiece in a CCW direction. This CCW is, relatively, the same as a stationary tool and a rotating workpiece going CW.
Edited By Martin Connelly on 28/01/2023 12:58:26
Drew Northcott09/02/2023 07:30:04
15 forum posts
1 photos
So if you have a DRO on your lathe tailstock is that also Z? Little z perhaps? Z2?
" The origin is conventionally bottom left on a graph, but not in computer graphics, where the origin is always top/left and Y is up/down."
It's not even consistent within computer graphics, some 3D packages have Z up and some Y up and either left or right handed depending on the dim and distant origins in engineering drawing, graphics, or being picked at random by a lead developer due to personal preference ( Microsoft DirectX allegedly).
Even within flat texture maps Y can be + up or - up depending on the game engine.
I worked on one game where the senior two physics programmers hated each other, and used different systems for direction and rotation ( radians and degrees), anyone elses code that touched physics had to account for both.
Edited By John Northcott on 09/02/2023 07:46:42
Clive India09/02/2023 13:40:13
277 forum posts
I don't have any DRO's on my lathe, but I do have DROs
However, does it matter what you call them - as long as you can remember which axis is which?
Different thing of course if you are into CNC.
