Member postings for Drew Northcott
Here is a list of all the postings Drew Northcott has made in our forums. Click on a thread name to jump to the thread.
Thread: Four jaw chuck strip down
18/03/2023 19:12:43
Thanks all, based on this I knocked one out _just_ enough to get the screw out, just to see how much extra access it got me. Not really enough to be worth it I think, so I've attacked it with a toothbrush and I'll oil them and reassemble.
Thanks folks, much appreciated.
-Drew
18/03/2023 16:18:27
4 jaw back
I'm trying to strip this Chinese chuck down for cleaning but the back looks like the stubs holding the jaw screws in are a press fit. I don't want to wail on them with a crowbar if I'm going to break something.
Am I missing something or does this not come apart?
Edited By Drew Northcott on 18/03/2023 16:24:34
Thread: Who labelled the X and Y axes for DROs on lathes and mills?
09/02/2023 07:30:04
So if you have a DRO on your lathe tailstock is that also Z? Little z perhaps? Z2?
" The origin is conventionally bottom left on a graph, but not in computer graphics, where the origin is always top/left and Y is up/down."
It's not even consistent within computer graphics, some 3D packages have Z up and some Y up and either left or right handed depending on the dim and distant origins in engineering drawing, graphics, or being picked at random by a lead developer due to personal preference ( Microsoft DirectX allegedly).
Even within flat texture maps Y can be + up or - up depending on the game engine.
I worked on one game where the senior two physics programmers hated each other, and used different systems for direction and rotation ( radians and degrees), anyone elses code that touched physics had to account for both.
Edited By John Northcott on 09/02/2023 07:46:42
Thread: Another noob, west midlands
20/01/2023 13:43:25
Posted by lfoggy on 20/01/2023 13:18:57:
Hello John,
Clockmaking is a great pass time but can be quite frustrating and challenging. A lathe, pillar drill and some method for dividing and cutting wheels is essential. There are quite a few specific small tools you will also need but these are all easy to make yourself. I found John Wilding's books and plans to be an excellent starting point which cover pretty much every aspect of clockmaking in a home workshop. Another good book is Making an Eight Day Longcase Clock by Alan Timmins. I've now made half a dozen clocks over the years and am currently working on an English bracket clock with double fusees. I'm in Birmingham so if you need any advice or assistance do get in touch.
Thanks, I'll certainly keep that in mind, I'm thinking I may need all the help I can get .
The projects I'm planning are clockwork rather than clocks as such, but it is an almost total overlap really so I'll stick some of those books on the wishlist.
20/01/2023 13:35:52
Posted by Mike Hurley on 20/01/2023 09:57:06:
Posted by John Northcott on 18/01/2023 13:25:48:
The really cool thing about the clock build is that it just assumes you're starting with a lathe, a pillar drill, and some hand tools. Going through the instructions it will pause occasionally and say "go to appendix n and build that tool to use in the next section". That includes an arbour setup for gear cutting and a jig to index using a spare change gear on the back of the spindle. By the time you've finished you've got a handful of generally useful jigs and tools.
Mind you if an indexing head came up for not to much I wouldn't say no
Interesting. I've made all manner of stuff over the years but never a clock - always had one in the back of my mind but cautious about how to get started. Cooincidently I've just finished fitting my Universal Dividing head into my mill (an old unit I inherited and has been sat in a box for years) so maybe I'll now look into this clock build as my next project as it sounds as if this particular set up will lead you step by step? Majority of my kit is Metric based, do you forsee any issues? ( I'm well used to doing imperial to metric conversions, but its still a pain sometimes)
Regards Mike
I've had a skim through the book and it's all metric and uses module 1 toothform. It's a PDF available from the creator's website. #notsponsored
http://briansworkshop.weebly.com/dark-lady.html
It's an http site so will show a warning going there but it's fine, just not been updated. It took a little while to arrive as it's not an automated system I think.
18/01/2023 22:27:26
Lots of really great advice there thanks Howard, and thanks for all the recommendations. It's very much appreciated.
18/01/2023 13:25:48
Posted by Mike Hurley on 18/01/2023 09:58:28:
Hi John, welcome to the forum (I'm a midlander also). Plenty of expertise here + friendly advice & comment. That clock looks interesting - I've just watched a short youtube vid about it. What arrangements are you thinking of for cutting the gear wheels? Can be a tricky process and you need some fairly accurate method of indexing. Let us know how you get on.
All the best. Mike
18/01/2023 13:18:51
Posted by Oldiron on 18/01/2023 09:53:09:
Hi welcome to the forum. Good luck getting or finding a lathe & mill etc. Dont forget to allow a chunk of your budget to go towards all the extra tooling & metrology you will need. One thing to note if you are into wood and metal is to try and keep all the saw dust off of the metal working tooling. Wood holds moisture and can soon make machinery go rusty. Answer a post or two and you will be able to contact sellers on the forum.
regards
Edited By Oldiron on 18/01/2023 09:53:51
I've started on the metrology, a set of Starret squares, a small M&W micrometer, a Mitutoyo dial indicator, and an older vernier caliper. That's a good point about the sawdust. I was thinking that the front part of the garage is for wood and any grinding (henceforth known as the dirty end) and the back will be for metal. There's a sliding door between the two which should keep the dust out.
18/01/2023 09:36:13
Hi all,
I'm just getting gear together before launching into a few projects I've got lined. The stuff I'm planning is clock-making adjacent and involves a certain amount of (whisper it) woodwork alongside the wheel cutting and brass shaping.
The garage is attached to the house and insulated all round apart from the gaps in the garage doors which are definitely on the list. I've divided off the back for the machine tools, that bit contains the boiler and is noticeably warmer.
Tools wise apart from the usual rag-tag collection of hand tools, I've got a modest amount of Makita woodworking stuff, tracksaw, small router, multi tool, and a good solid rolling workbench with an mft top. also well as an aging cheap pillar drill, not great for real accuracy but good enough for wood.
Metal wise I've just acquired a Hegner scrollsaw, and I'm looking for a small lathe. There's one in the classifieds here which I'm going to jump on as soon as I've posted enough to see contact details. Something in the linisher line might be useful as well for shaping.
The first project is the "Dark Lady" beginners clock, as much as a skills /tools building exercise as anything, then onto the main event.
Thread: New Member from West Midlands.
18/01/2023 08:45:41
Hi Stuart, another West Midlands noob here, I'm just west of Stratford upon Avon.
That's quite a selection of gear you've got there.
I'm just looking for my first lathe too, something bench sized, but the stuff I'm planning to do is more on the Scrollsaw / small lathe/hand-filling end of things.
Thread: Home garage heating.
17/01/2023 21:03:30
Posted by Circlip on 16/01/2023 11:07:51:
Shouldn't need to warn but be careful if you're going down the log burner trail. DON'T burn treated wood.
Regards Ian.
This, be somewhat wary of palette wood.
Palettes used for international shipping are pumped full of all kinds of chemical fun to kill any potential stowaway organisms. They are stamped/branded to show this I believe, but I'm not sure what the particular stamps are. Can be googled though.
Thread: Spudger
17/01/2023 19:55:08
I bought a replacement screen for a Nintendo somethingorother a few years ago and it came in a kit with a mini tri-point screwdriver and a few plastic spudgers and something like guitar plectrums (plectra?) for wedging into the gap as you opened it.
Thread: I thought winter was over.
17/01/2023 19:37:58
Posted by noel shelley on 17/01/2023 10:24:31:
shed nair a clout till march is out ! Noel.
What IS a clout and are they hard to shed? I've often wondered.
Thread: Hello From Canada
17/01/2023 19:36:26
Greetings to the land of polar bear avoidance and fur-lined underpants.
Thread: Emco Unimat Spare part seller===
17/01/2023 19:10:15
I'm looking at Unimat as a possible first lathe. I don't know how many posts I need to make before you can DM me the list but I'd deffo be interested.
