Restoring a wooden tool box, help needed
Brian Abbott26/09/2020 21:35:08
523 forum posts
95 photos
Thanks Bo’sun
Will get some danish oil and give that a try.
Pete White27/09/2020 09:48:50
223 forum posts
16 photos
Yes like the Bosun said, but............what did you glue it up with, I need to know.!
Pete
Rod Renshaw27/09/2020 10:12:31
438 forum posts
2 photos
Anyone found a way of getting old (machine) oil out of the wooden parts of a well used toolbox so that glued repairs can be attempted? I have tried using turps substitute which got the dirty oily surface clean but left a residue which the glue would not adhere to.
There is a product called "Chair Doctor" made by Veritas, and sold by Hobbies and Amazon etc., which is a very low viscosity glue. It wicks by capillery action into loose mortise and tenon joints of chairs, and it sounds as if it would be useful for toolbox joints which cannot easily be dismantled.
Rod
Dalboy27/09/2020 10:28:14
1009 forum posts
305 photos
If the toolbox has a varnish or lacquer finish on already then an oil finish will be of no good as it relies on Penetrating the wood and the other finishes will prevent this happening. Even if you sand the box there will always be a residue of the varnish or lacquer remaining may result in a blotchy finish.
I know it is difficult but try a like for like finish if you can find out what was originally on there. Sanding back and reapply a varnish or lacquer.
Edited By Derek Lane on 27/09/2020 10:29:12
KWIL27/09/2020 11:19:45
3681 forum posts
70 photos
Veritas is a trade name of Lee Valley Tools, Ottawa. A family owned firm. Google it to view some treasures.
Circlip27/09/2020 12:23:15
1723 forum posts
" Anyone found a way of getting old (machine) oil out of the wooden parts of a well used toolbox "
Recent "Salvage Hunters The Restorers" think they poured Meths onto an oil soaked panel and ignited the Meths, it drew the oil out.
Regards Ian.
They also use Meths and fine wire wool for cleaning existing varnish before refinishing.
Edited By Circlip on 27/09/2020 12:25:01
Donovan Kaardal27/09/2020 12:44:30
27 forum posts
48 photos
Posted by KWIL on 27/09/2020 11:19:45:
I lived right by their store and manufacturing location in Ottawa (Nepean) for years. It was a very expensive time for me.
not done it yet27/09/2020 15:06:11
7517 forum posts
20 photos
Posted by Donovan Kaardal on 27/09/2020 12:44:30:
It was a definite ‘must visit’ whenever we went to Ottawa. Space In our luggage was always made for quite a few quids worth of stuff, on our return.
Dalboy27/09/2020 18:48:00
1009 forum posts
305 photos
Posted by Circlip on 27/09/2020 12:23:15:
Using meths as a cleaner on varnish has been used for many years and is very effective
JohnF27/09/2020 20:31:23
1243 forum posts
202 photos
Regards Ian.
You can use Oxalic acid to remove oil and stains from wood, use liberally and allow to dry then wash off and rub on lime or borax to help neutralise the acid and wash off. Allow plenty of time to dry naturally -- don't dry with heat. However gently heat will bring oil to the surface and you can wipe it off but I have found the acid works better ,at least on gun stocks !
Please do wear suitable protective gear, Oxalic acid is not really nasty like say Nitric acid but still treat with v=care and respect.
edit - forgot to say you mix the acid crystals with water to apply to the wood
Edited By JohnF on 27/09/2020 20:32:10
Edited By JohnF on 27/09/2020 20:32:28
Rod Renshaw27/09/2020 20:53:10
438 forum posts
2 photos
Thanks Ian. I will try the meths and fire, it sounds like something a wizard might do!
Thanks John. If the meths does not work I will get some oxalic acid and try that.
Rod
Brian Abbott27/09/2020 21:16:04
523 forum posts
95 photos
Hello Pete, i used Gorilla Glue, just the normal white wood glue.
bit unsure but it has worked really well.
now had 2 coats of the danish oil and is starting to look really good,
would like a bit more of a shine but maybe this will come with a few more coats.
Thanks all.
Edited By Brian Abbott on 27/09/2020 21:20:10
SillyOldDuffer27/09/2020 21:28:33
10668 forum posts
2415 photos
Posted by Rod Renshaw on 27/09/2020 20:53:10:
Rod
Turps and Turps Substitute are both light oils, so although they dissolve out thicker oils the residue is also oily and bad for glue. I'd try scrubbing and rinsing the turps off with with a good dose of meths - a two stage clean.
I like the idea of setting fire to a surface splash of meths as a way of drawing out deeper oil, but it's an outdoors job with a bucket of water. Oil soaked wood and burning meths - what could possibly go wrong?
smiley
Pete White27/09/2020 21:47:19
223 forum posts
16 photos
Posted by Brian Abbott on 27/09/2020 21:16:04:
Thanks all.
Thanks for the reply, I just wondered what you would opt for after all the advice. I like "normal" monkey glue, but not sure about the expanding stuff myself. Danish oil does need a coat or two, but can be tidied up at any time later with a quick sand and an added coat. Light sand and thin coatswink
Pete
Brian Abbott02/10/2020 18:57:19
523 forum posts
95 photos
Hello all.
So, i have given this about 6 coats of oil,
and is looking so much better but would like to give it a coat of wax to give it a little more sheen.
Any reason why i shouldn’t?
thanks all
Dalboy02/10/2020 19:21:06
1009 forum posts
305 photos
Leave it for about a week then add wax if you want to
bricky02/10/2020 19:27:32
627 forum posts
72 photos
I still have a bottle of oxilic acid from my working life ,like John F it is the best to remove stains from wood,I used it often with good result ,I don't know where one would buy it today are gone when you could get chemicals from your local chemist.
Frank
pgk pgk02/10/2020 20:26:21
2661 forum posts
294 photos
Posted by bricky on 02/10/2020 19:27:32:
Frank
Ebay for one
pgk
David Noble02/10/2020 20:51:50
402 forum posts
37 photos
Rod
One of the reasons that I love this forum. Where else in our Heath and Safety obsessed world could we get such advice 😁
David
Edited By David Noble on 02/10/2020 20:54:16
Circlip03/10/2020 12:09:29
1723 forum posts
Sadly, the nanny state has pre determined that the Jean Pool is at the point of drying up, coupled with the fact that ingineering as a full time job is only carried out in the far east, the old Alchemy wheezes drop into obscurity. I'll bet our black arts are still practised in these satanic manufactories' who haven't heard of HSE. Bet there aren't any "Factories Act" posters on their walls.
Still, we are good at flipping burgers and wearing buttons out killing aliens and crashing cars.
Regards Ian.
