Mark Rand | 05/08/2018 22:20:25 |
1505 forum posts 56 photos | Note:- Bastard files are between coarse files and second cut files. Bastard files are fairly rare these days. Coarse files are an endangered species. |
Clive B | 06/08/2018 00:20:30 |
46 forum posts 21 photos | Thanks for all the helpful replies. The Millenicut files sound as if they will do the job. I see that they are available with straight or curved teeth - what would be the advantages of one versus the other? Clive
Bob Murray | 06/08/2018 05:49:03 |
24 forum posts | The curved teeth don't seem to clog as much, and the filed surface is somewhat smoother. Bob |
Brian G | 06/08/2018 09:14:43 |
912 forum posts 40 photos | Posted by Roderick Jenkins on 05/08/2018 16:46:43:
...There was also the Aven (then Sandvik?) Trimatool. Doesn't look like these are available anymore though... Pferd car body files look like they function in much the same way as a Trimatool, although the option to flip the handle from plane to file format is missing www.carbodyfiles.co.uk/carbodyfiles/Car_Body_Files.html (so that is how to show the address in a link) Must admit I had never thought of using my Dad's old Trimatool on metal, although I much prefer it to using a rasp on the brown stuff as there is far less work to finish. Brian |
Alan Jackson | 06/08/2018 09:31:40 |
![]() 276 forum posts 149 photos | I have found that painting the file surface with white spirit helps to reduce the file clogging. I use a wire brush to clear most of the file grooves but I still have to pick out the stubborn bits with a pointed object. Alan |
Russell Eberhardt | 06/08/2018 09:46:13 |
![]() 2785 forum posts 87 photos | I find that French chalk a.k.a. talc helps. Cheapest source is Johnson's Baby Powder! Russell |
Muzzer | 06/08/2018 11:45:34 |
![]() 2904 forum posts 448 photos | These latex blocks are just brilliant for declogging belt sanders. I haven't tried it with a file but suspect it may be another effective way to clear teeth, particularly if combined with PTFE spray or WD40. Murray |
Cornish Jack | 06/08/2018 12:08:16 |
1228 forum posts 172 photos | Muzzer - the last time I went to the MEX, (at least 10 years ago), the disc sander salesman was demonstrating that the standard super market plastic bag, rolled into a pad, does the same ... and a bit cheaper! rgds Bill |
Ian S C | 06/08/2018 12:23:13 |
![]() 7468 forum posts 230 photos | Or a bit of plastic garden hose. But a Dreadnought file is the way to go for fast removal of metal(tooth pattern (((((((, for finer work, ordinary files, new and kept for aluminium. I think Johnson's Baby Powder is starch based nowdays to get away from the ? cancer causing minerals in chalk. Ian S C Edited By Ian S C on 06/08/2018 12:24:21 |
Brian G | 06/08/2018 12:30:42 |
912 forum posts 40 photos | Chalk blocks and powdered chalk are still available from tack shops or dog groomers. (or even Amazon at a price) Brian |
Jon | 08/08/2018 18:38:44 |
1001 forum posts 49 photos | Posted by Mark Rand on 05/08/2018 22:20:25:
Note:- Bastard files are between coarse files and second cut files. Bastard files are fairly rare these days. Coarse files are an endangered species. Must admit you are quite correct, think it was the demise of the quality tooling over previous decades leaving a few producers calling them bastards when more like a courser second cut. Dreadnought Millenicut As above millenicut are straight teeth though can be angles like this.
Any file will scratch think about it, even a though proud over the whole file will scratch! They were only working with thin guage materials as well. You wont get even close to 10 thou with a millenicut yet alone file to sub thous!
