mechman48 | 03/07/2018 10:59:40 |
![]() 2947 forum posts 468 photos | A couple of pics of aforesaid mic'... |
Hopper | 03/07/2018 11:20:25 |
![]() 7881 forum posts 397 photos | Get a bit of printer rod out of an old printer. Any clue as to the application of this micron-perfect bar that is sought? There might be other alternatives if we knew what we were talking about. |
Circlip | 03/07/2018 11:26:22 |
1723 forum posts | Why not a piece of 3/8"diameter by 4 3/4" long? Regards Ian. Edited By Circlip on 03/07/2018 11:27:26 |
Baz | 03/07/2018 12:01:51 |
1033 forum posts 2 photos | Perhaps the OP ought to find a precision grinding shop and get them to grind a couple of lengths down for him, if done between centres it should be truly round, then he can get the accuracy he requires, at a price! |
Vic | 03/07/2018 13:35:45 |
3453 forum posts 23 photos | Would Linear shafts be good enough? |
SillyOldDuffer | 03/07/2018 14:09:19 |
10668 forum posts 2415 photos | Trust nothing when taking high precision/high accuracy measurements! Below, say, 0.005mm /0.0001" it's difficult to measure length without taking special precautions. It's close to tool-room and metrology lab territory involving clean rooms, temperature control, calibrated equipment, optical methods, multiple measurements, trained operatives and the like. How exactly did you take the measurements lfoggy? If done in an ordinary environment with basic skills it's possible you're detecting errors in your equipment or technique as well as, or even instead of, problems with the silver steel. Not intended as a criticism - I'm particularly conscious of human error and rate myself below average when using tools. Others are far more competent! Dave |
David George 1 | 03/07/2018 14:27:21 |
![]() 2110 forum posts 565 photos | I used to operate a centerless grinder about 40 years ago in the manufacture of hydraulic cylinder shafts and inspection would have rejected anything with more than a couple of tenths out of round as when they were chromed and then reground you could not guarantee the chrome thickness. David |
lfoggy | 03/07/2018 16:18:11 |
![]() 231 forum posts 5 photos | Thanks for all useful replies. Didn't know about h8 and H8 but it makes sense. My measurements were all taken with an ordinary Mitutoyo digital micrometer. This seems to give remarkably consistent results to within a few microns. This is the micrometer measuring a setting standard at 20C. With care it measures to within 0.002mm of 25mm fairly consistently. The part is required to help a friend restore an old Reichert microtome. It is in fact just a replacement for a damaged shaft so nothing special really but it does need to match the original which seems to be a few microns under 10mm. I fear that my box of random bits of silver steel may not be the best place to look.... |
Neil Wyatt | 03/07/2018 18:21:20 |
![]() 19226 forum posts 749 photos 86 articles | Posted by lfoggy on 03/07/2018 16:18:11:
Thanks for all useful replies. Didn't know about h8 and H8 but it makes sense. My measurements were all taken with an ordinary Mitutoyo digital micrometer. This seems to give remarkably consistent results to within a few microns. This is the micrometer measuring a setting standard at 20C. With care it measures to within 0.002mm of 25mm fairly consistently. The part is required to help a friend restore an old Reichert microtome. It is in fact just a replacement for a damaged shaft so nothing special really but it does need to match the original which seems to be a few microns under 10mm. I fear that my box of random bits of silver steel may not be the best place to look.... Well that's the sort of approach needed to get that sort of accuracy. I found a Mitutoyo publication on the web 'Quick Guide to Precision Measuring Instruments' and it's quite illuminating. A 325mm micrometer will show errors between 0.0 and 5.5 microns depending on how and which way up you mount it, for example. A 200mm standard bar will expand 20 microns when held in a warm palm for 10 minutes, also test bars and micrometers don't expand at the same rates with temperature, and a common source of inaccuracy is the test equipment and object being measured not being at the same temperature. |
