Samsaranda | 10/03/2018 19:59:56 |
![]() 1688 forum posts 16 photos | Bob, you state that customer is a nuclear power station, one would assume that they know their metallurgy and would have specified accordingly, if they are of the opinion that 400 grade “stainless” is not going to rust then they are either deluded or have made a major error in specification. I have worked in companies who contract supply to nuclear customers and my experience is that they are meticulous in specifying materials and processes, if they required a passivation process then my experience is that it would have been clearly documented as required. It is nearly 30 years since I was involved in making for nuclear customers and they were always very thorough in their dealings with contractors, unless things have changed drastically then in your case they have specified incorrectly. If this is an error on their part then one wonders how many other components, perhaps critical components, have also suffered from specification errors. Dave W |
Chris Evans 6 | 10/03/2018 20:56:59 |
![]() 2156 forum posts | I have used a lot of 400 series stainless steel when wire eroding parts for injection mould tools and extrusion dies. Normal tool steels would rust in the wire eroding process if done overnight hence the switch to 420 stainless. It would still rust if left overnight on the machine though not excessively . |
Martin Dowing | 10/03/2018 21:23:54 |
![]() 356 forum posts 8 photos | Posted by Windy on 10/03/2018 19:52:04:
I used hardened magnetic stainless balls in my water pump on the hydro soon found they were no good and lost there sealing due to surface defects caused by corrosion. 316 balls were the solution but they are not very hard some can be drilled but have had no problems with them.
There is solution for that and it takes a form of silicon nitride bearing balls which are for all practical purposes indestructible in use which you are describing and you can buy these cheaply from manufacturer here: http://lozyskaceramiczne.pl/index.php They speak english over phone and will send via mail order. Amazon also sells these but watch out - I have seen ripoffs. If after a long time of use they collected stone, you can get rid of it by washing with hydrochloric acid (viniger will also do with more patience). Martin
lug lord | 10/03/2018 21:34:47 |
![]() 60 forum posts 20 photos | I make moulds out of off cuts of stainless tube and i have found contact with fairy liquid which i use to stop the silicon sticking makes the stainless rust like mad 304 and even 316 gets rust spots. I have also found that even 316 rusts where its been worked on cut drilled etc mostly
Martin Dowing | 10/03/2018 21:36:07 |
![]() 356 forum posts 8 photos | Posted by Samsaranda on 10/03/2018 19:59:56:
Bob, you state that customer is a nuclear power station, one would assume that they know their metallurgy and would have specified accordingly, if they are of the opinion that 400 grade “stainless” is not going to rust then they are either deluded or have made a major error in specification. I have worked in companies who contract supply to nuclear customers and my experience is that they are meticulous in specifying materials and processes... .....If this is an error on their part then one wonders how many other components, perhaps critical components, have also suffered from specification errors. Dave W Most of peoples who knew what they are doing are now retired. Lets hope, nothing will go pop! Martin |
Clive Hartland | 10/03/2018 22:22:51 |
![]() 2929 forum posts 41 photos | I think that the washing up liquid is thickened with salt? There must be a better de-greaser for that job? Clive |
Bob Rodgerson | 10/03/2018 23:51:04 |
612 forum posts 174 photos | Hi all, thanks for responding. I have heat treated 10 buttons tonight and will see if this improves their corrosion resistance., The same material has been used in the past for this application but nobody can tell us what surface treatment was used ,if any. I should point out that I am not dealing directly with the power station but with a sub contractor who specified the material. I m trying my best to resolve the problem for him because it has cost him so much money with people being pulled off the job twice while the problem was investigated.
Raymond Anderson | 11/03/2018 07:01:15 |
![]() 785 forum posts 152 photos | Bob, Would be best if the company involved in the Specs contacted AALCO or James Duva as they have specialist Nuclear / Power Generation materials divisions. and full traceability.
Cheers.
Ian S C | 11/03/2018 09:24:44 |
![]() 7468 forum posts 230 photos | Perhaps steel(stainless or not) is not the correct metal in this case, nickle alloy as used in our 20C and 50C coins, and "silver" coins in other parts of the world are highly magnetic, but don't become magnetised, they don't corrode. Ian S C |
SillyOldDuffer | 11/03/2018 10:59:50 |
10668 forum posts 2415 photos | Bearing in mind I know little about stainless I think the thread contains the answers. A few observations:
I think Bob is on the receiving end of unlucky circumstances. The discs:
I'd suggest:
The politics of this may be more important than who was at fault. The customer won't be happy if a second batch goes rusty! If a long-term reputation is at stake might be better to bite the bullet and make a second set. Dave
pgk pgk | 11/03/2018 11:15:02 |
2661 forum posts 294 photos | I had a dig about on the web and stumbled across this: I havent read it all but It doesn't look promising as page 13 shows their best attempts lasted 250 days. I'd suggest time to rethink the project - perhaps soemething as simple as embedding a magnet in plastic or painting the current items. |
John Olsen | 11/03/2018 21:53:49 |
1294 forum posts 108 photos 1 articles | One thing that does not seem to have been mentioned is the effect of using tooling for stainless that has previously been used for ordinary steels. This can contaminate the surface of the stainless with the other steel, giving a place for corrosion to start. It is especially a problem with abrasives, eg grinders and linishers, where a separate wheel or belt should be kept for stainless work. Obviously cutting tools are less able to transfer contamination but ideally separate ones would still be used. Incidentally if you visit the gents in places that do a lot of steel work, you will often find that the stainless steel urinal is pitted and streaked with rust. This is from particles of steel that have been carried through on clothing and dislodged onto the stainless. A particle of steel sitting on the surface is enough to initiate corrosion. John |
Clive B | 12/03/2018 07:22:02 |
46 forum posts 21 photos | Bob, I am sure that passivation will help. If you want to try it yourself, there is an easy to follow guide on passivating stainless steels using a citric acid/caustic soda (sodium hydroxide) three step process. I used this to passivate 303 stainless (another free machining grade containing sulphur) for some components for my home brew boiler/mash tun, Not seen any corrosion - although I know that doesn't prove anything! Exposed sulphides in FM grades can act as initiation sites for corrosion (apparently, according to the article) and the citric acid must be removing the sulphur as you can smell it (hence the need for a final rinse in caustic). https://www.cartech.com/en/alloy-techzone/technical-information/manufacturing-guides/how-to-passivate-stainless-steel-parts Regards, Clive |
CHARLES lipscombe | 12/03/2018 21:03:14 |
119 forum posts 8 photos | This is not directly related to the previous postings but is related to the thread title I make stainless motorcycle control levers etc from 303-grade in the obsolete patterns used by veteran and vintage m/c enthusiasts. After polishing the levers the crevices etc usually contain unsightly deposits of polishing soap. I clean up the castings by placing them in a Lidl ultrasonic cleaner with warm water and a generous dose of washing up liquid which does the job nicely. I then rinse the parts in water, leave to dry, then bag up. Is it fact or urban myth that washing up liquids contain salt? I have never seen or had reported a case of corrosion on my levers etc. I think it very unlikely that the washing up liquids available in Australia are different to those used in the rest of the world. I have seen adverts for cleaning solutions for ultrasonic baths but does anyone know what these contain and weather they would cause an explosion/fire risk used in a (pretty basic!) Lidl bath? Chas |
Clive Hartland | 12/03/2018 22:33:52 |
![]() 2929 forum posts 41 photos | You should not use volatiles in an Ultrasonic, but, you can use a smaller container for tiddly parts but make sure you do not contaminate the liquid. At this time it is best to use Aqueous solutions and once again I will give you a name,' Micro' which is used by the US Nuclear industry and is only a 2% solution so it last ages. |
