larry Phelan | 07/03/2018 11:53:19 |
![]() 544 forum posts 17 photos | I am old enough to remember red hot tap washers,then they just seemed to vanish. I also remember black cold water washers which were shaped like half a ball and were fitted onto a short spigot. Does anyone else remember these,or am I just doting ? Those boxes of washers on Ebay look the same as the ones sold in Aldi/Lidi from time to time,quite cheap,and handy to have. |
FMES | 07/03/2018 12:01:42 |
608 forum posts 2 photos | Posted by larry Phelan on 07/03/2018 11:53:19:
I also remember black cold water washers which were shaped like half a ball and were fitted onto a short spigot. Does anyone else remember these,or am I just doting ? . Yup, they were for 'Holdtite' taps **LINK** |
Martin W | 07/03/2018 12:14:44 |
940 forum posts 30 photos | Somewhere I think I have still got a tap seating tool from my younger days. Much like a valve seating tool that used to be used on cars during their periodical 'de-coking' service except the cutting edge was at right angles to the shaft. It was/is an all metal tool with guide carrying the appropriate cutter that screwed into the tap body and with a couple of turns of the handle a fresh seat was cut. I can only assume that we must have been using hard washers as soft ones would have deformed and sealed. It's not a job I have done for donkey's years so whether the body material of taps has improved and doesn't corrode or whether the plastic style washers seal better and stop the seat eroding I don't know. Another trip down memory lane. Martin W Edited By Martin W on 07/03/2018 12:16:49 |
Richard S2 | 07/03/2018 12:43:06 |
![]() 237 forum posts 135 photos | Posted by Martin W on 07/03/2018 12:14:44:
Somewhere I think I have still got a tap seating tool from my younger days. ............Martin W Without deviating too much from the OP's subject, a pictorial example of Martin's description, part of many 50/60s DIY Plumbing items I inherited long ago- This is the 3/4" example. I also still have Hemp strands, Frys Plumber Solder Bars,the old Bakers active Flux etc etc. Regards
Journeyman | 07/03/2018 12:58:12 |
![]() 1257 forum posts 264 photos | At the risk of going even further off at a tangent... I think that is a counterbore, tap re-seating tool usually looks like this:- John |
not done it yet | 07/03/2018 13:04:27 |
7517 forum posts 20 photos | Not that far off on a tangent. Seats usually require recutting if allowed to leak, particularly at mains pressure. I still use mine (journeyman’s pic) occasionally. |
Martin W | 07/03/2018 13:09:28 |
940 forum posts 30 photos | Yes that's the one John, somewhere in a dark and forgotten place mine resides Martin W |
Richard S2 | 07/03/2018 22:41:07 |
![]() 237 forum posts 135 photos | Posted by Journeyman on 07/03/2018 12:58:12:
At the risk of going even further off at a tangent... I think that is a counterbore, John Thanks for the corrective response. Sure I remember correctly that he used it for Bath Taps?. I'll relegate/elevate it to my Tooling stock, although the shank is turned down for a hand drill. Fortunately my 58 year old Bath Taps are still good. I'll get some of those Washers though |
martin ranson 2 | 08/03/2018 08:47:55 |
![]() 135 forum posts 2 photos | To Roy Entwistle ... try MKM builders merchants ... I have previously bought washers from them ... the label reads BARKING GROHE tap washers, in a pack of 2 ... they seem to survive well on hot water. martin |
Perko7 | 08/03/2018 09:03:33 |
452 forum posts 35 photos | In Australia, for the last umpteen years i have used Hydroseal tap washers exclusively. Not sure if they are available in UK. Uses a face-mounted o-ring style seal held in place by the water pressure. Suitable for hot or cold and wide pressure range. http://www.hydroseal.com.au/taprepair.pdf Work like a charm, but you need to have scrupulously clean seats in your taps. |
not done it yet | 08/03/2018 12:11:12 |
7517 forum posts 20 photos | Regarding different materials for hot and cold water, I would expect that modern materials would cover the whole range of water temperatures. Any problem, experienced with fitting new washers these days, is almost certainly related to not recutting the seal face when doing only half the job. |
Philip Rowe | 08/03/2018 13:30:32 |
248 forum posts 33 photos | Wandering off topic again, has anybody ever dismantled one of the newer ceramic valved taps? Just curious as to how they operate. Phil |
not done it yet | 08/03/2018 14:38:19 |
7517 forum posts 20 photos | They simply an insert. Remove the old innards and replace with new into the tap. There might be different thread options and certainly longer or shorter stems for the operating knobs/handles. Right and left handed insers for taps with long levers, of course. If you mean how do the inserts work, they are simply close tolerance ceramic discs which don’t wear out - it is the cages that eventually fail. |
Perko7 | 09/03/2018 07:49:10 |
452 forum posts 35 photos | Might those ceramic tap inserts be suitable candidates for adapting as steam regulators? |
Martin King 2 | 09/03/2018 08:10:07 |
![]() 1129 forum posts 1 photos | I see loads of tap reseating cutters, usually with a load of spare washers, at car boots, they redefine the expression 'sale proof'! Martin |
