not done it yet | 09/11/2017 08:22:50 |
7517 forum posts 20 photos | Stuart, The lathe can be operated manually (no theading or power feed) but in this case, with the apron jammed, that would be unwise without sorting out the reason for the jamming. Unfortunately, some might mean fitting a non-shearing item in place of the shear pin. In that case the lathe would cheerfully go on operating until a jam occurs, but this time much more damage to the gear train would likely be the result. There may be a bent shaft in Brian's apron which is preventing much movement in either direction of turning. |
Mick B1 | 09/11/2017 09:13:45 |
2444 forum posts 139 photos | Posted by not done it yet on 09/11/2017 08:22:50:
Stuart, The lathe can be operated manually (no theading or power feed) but in this case, with the apron jammed, that would be unwise without sorting out the reason for the jamming. Unfortunately, some might mean fitting a non-shearing item in place of the shear pin. In that case the lathe would cheerfully go on operating until a jam occurs, but this time much more damage to the gear train would likely be the result. There may be a bent shaft in Brian's apron which is preventing much movement in either direction of turning. In the WM250V, I think it's more likely that one of the leadscrew nuts would get damaged than the headstock gears. Since Brian was facing - not turning - when the jam occurred, it would be the crosslide leadscrew assembly that was under load, and I *don't think* that's strong enough to distort the apron pinions or shafts. If the shearpin didn't do its job, I'd guess the crosslide leadscrew nut is the more likely casualty. Still speculation, though really. |
Stuart Riddell | 09/11/2017 10:28:16 |
![]() 15 forum posts | Sounds like it would be handy to keep a couple of these as spares in the toolbox but good to know it can still be used without them the good old fashioned way |
Brian Rutherford | 09/11/2017 10:37:44 |
109 forum posts 3 photos | Took the centre bolt off the cross slide which dropped the nut which allowed me to unwind the cross slide leadscrew and withdraw it. Pretty good bend in it at the start of the thread nearest the front. Will put it in the lathe between centres to see if I can straighten it. Pity I can't use the cross slide to do it |
Russell Eberhardt | 09/11/2017 10:53:17 |
![]() 2785 forum posts 87 photos | Posted by Brian Rutherford on 09/11/2017 10:37:44:
Will put it in the lathe between centres to see if I can straighten it. Pity I can't use the cross slide to do it That sounds as if it will put undue strain on other parts of the lathe. Better to use two V-blocks and a press. Personally I would contact Warco to see if they have a spare cross-slide leadscrew. Russell |
Mick B1 | 09/11/2017 10:53:48 |
2444 forum posts 139 photos | Posted by Brian Rutherford on 09/11/2017 10:37:44:
Pretty good bend in it at the start of the thread nearest the front. Will put it in the lathe between centres to see if I can straighten it. Pity I can't use the cross slide to do it Depending on severity, I'd think there's a good chance you can. It's not hugely substantial. On mine, there's a crosslide shearpin where the drive's taken from the pinion to the leadscrew. Looks like yours didn't snap like it should've. While you've got it in bits, there might be a case for judiciously weakening it as Howard suggested. Edited By Mick B1 on 09/11/2017 10:56:32 |
Brian Rutherford | 09/11/2017 15:11:51 |
109 forum posts 3 photos | Partially straightened it. Been ringing Warco all day for cost of replacement but no answers. Might get it good enough to let me make a replacement if warco are too dear. Have had the long lead screw out to knock shear pins out but very tight. Will drill out on the mill. Screw cutting lever is jammed so suspect other bits have sheared in the apron and fell into the bottom. Off to Belfast tonight to see son and grand kids so on hold till Tuesday.
Ian S C | 10/11/2017 09:17:07 |
![]() 7468 forum posts 230 photos | If like mine it's 3 mm brass for the shear pin, I did the pin in very early in my learning screw cutting, I got a bit flustered and grabbed the saddle hand wheel, that stopped the saddle moving, and in a way was reassuring that the shear pin worked. On my lathe there is one (SP)on the lead screw, and one on the feed rod. There were two spare pins, and a pin punch in the tool box that came with the lathe. Ian S C |
Brian Rutherford | 13/11/2017 20:46:03 |
109 forum posts 3 photos | Just an update. Got back from Ireland this afternoon so had chance for another look tonight. Have drilled the brass shearpin out of main leadscrew. Removed the apron and managed to free the halfnut lever. Another shearpin has gone on the shaft holding the gear that drives the cross slide leadscrew. The cross slide leadscrew i have straightened best i can but it will be tight when wound out near to its limits. Ideally it needs to be replaced. I think the pitch has been stretched. Warco want about £70 including postage and vat for a replacement so i am thinking of making another myself |
Mick B1 | 13/11/2017 21:16:05 |
2444 forum posts 139 photos | You'd normally expect only one shearpin to break, and that would stop the action, so something quite complicated must've happened to break both. I don't think I'd want to make a leadscrew myself, but that's because I prefer to concentrate on product for family and friends, and don't like to invest lots of time on tooling projects. But as far as I can see it should be a practical proposition. If there's a way to do it (and I've not taken the crosslide off for examination), I'd try to avoid jamming on the far end of crosslide travel by having it simply run off the end of the leadscrew like my Myford Speed 10 used to rather than hitting a solid stop. And maybe use a smaller shearpin to reduce the damage from outward facing up against the handwheel bearing housing as seems to've happened to you. |
Clive Hartland | 13/11/2017 22:30:55 |
![]() 2929 forum posts 41 photos | I would suggest that brass is too hard for a shear pin and you should go back to a soft aluminium one. I have not seen a shear pin on a lathe other than an Alu one. |
Brian Rutherford | 15/11/2017 20:28:20 |
109 forum posts 3 photos | Lathe all back together now. Crosslide is a little tight but not patchy. Its as if the gibs are done up too tight but they are not. Still its useable. Will probably make a new one in the near future. |
