Motor for Flexispeed Lathe
Mark P.10/01/2015 13:58:41
634 forum posts
9 photos
Do you think that 1/16 hp motor will be enough? I am thinking of a 1/4,or even 1/2 horse motor for my Simat 101 which is almost a copy of the flexispeed.
Michael Gilligan10/01/2015 14:26:59
23121 forum posts
1360 photos
Posted by Mark P. on 10/01/2015 13:58:41:
Mark,
0.16 HP is rather more than 1/16
Mark P.10/01/2015 16:35:41
634 forum posts
9 photos
Oh yes I miss read it, nearly 1/4 hp.
herbert punter10/01/2015 17:53:24
128 forum posts
1 photos
I have a Simat 101 to set up some time this year and I'm proposing to use the motor from one of these:
I think it would be ok for it.
Bert
Mark P.10/01/2015 19:00:31
634 forum posts
9 photos
I think you would need quite a speed reduction via a counter shaft.
herbert punter10/01/2015 20:54:45
128 forum posts
1 photos
Posted by Mark P. on 10/01/2015 19:00:31:
That's the plan. I have the countershaft assembly, with a small motor some gearing down will give it more poke at low speed. I think these lathes need to run at speeds of less than 1000 rpm.
Ian S C11/01/2015 09:15:58
7468 forum posts
230 photos
Bert, I think the usual speed for the counter shaft is 500rpm, so you just have to work out the ratio required.
Ian S C
Roderick Jenkins11/01/2015 10:53:10
2376 forum posts
800 photos
It will probably need a 6:1 ratio although you may get away with 5:1, it depends how much the motor speed drops under load. The problem will be getting the belt to have a good wrap around the small motor pulley. Long centres will help but a better alternative might be to use timing pulleys and belts with teeth. Let us know how you get on.
Rod
Mark P.11/01/2015 11:06:39
634 forum posts
9 photos
Hello Herbert, what width belt are you using from the counter shaft to head stock on your simat? My pulleys measure 7.85mm so I suppose that an 8mm (5/16" wide belt will be ok.
herbert punter11/01/2015 13:44:19
128 forum posts
1 photos
Thanks for the good advice chaps!
I'm not in too much of a hurry with it. I bought it on a whim a year or so ago. It was mounted on an old kitchen cabinet with a large motor that wouldn't look out of place on a Myford!
I saw this B&Q bench grinder without any wheels for £6 so I thought it would do. I don't have much time at the moment but I'm hanging up my clogs at the end of April so I should be able to get on with it. I shall log it on here when I do, hopefully with some help from you guys it wll be a useful addition to my workshop.
Bert
James Alford09/07/2015 22:22:41
501 forum posts
88 photos
Finally, I have set up my Flexispeed and it isready to try using. I am not sure whether I have set the speeds at realistic rates: the top speed is a shade under 500 rpm, the lowest without the backgear being 190 rpm. With the backgear, it is measuring 50 rpm. The first thing that I wish to make for it is a pair of oilers for the headstock, followed by a QCTP. Making these will soon give me an idea of a how useful the speeds are.
James.
Ian S C10/07/2015 11:48:27
7468 forum posts
230 photos
James, that sounds a quite sensible speed range. Is that a clutch on the counter shaft pulley? That looks a nice little lathe.
Ian S C
Ian S C10/07/2015 11:49:22
7468 forum posts
230 photos
Ooops
Edited By Ian S C on 10/07/2015 11:50:18
CotswoldsPhil10/07/2015 13:11:05
196 forum posts
112 photos
The problem with small grinder motors apart from the 2850 speed is that they are not continuously rated - do check the label. They get quite warm after a few minutes or at least the two I have do.
Phil
Ajohnw10/07/2015 14:23:34
3631 forum posts
160 photos
If this crops up again. Peatol sell a nice compact GEC motor for their lathes. 1400rpm. They get a bit hot but this type of motor often does. The price was very reasonable and I'd guess it still is. 1/4hp £50 currently. Their lathe needs the power for it's nK top speed. There would be plenty available at normal speeds on other small lathes.
I had something similar to the flexispeed at one point, came fitted with 1/2 hp. Too much doesn't hurt really but as it was an old motor it was a bit big.
Whoops - I'm assuming the Peatol still uses the same motor or a very similar one as the motor board and belt would have to be changed if it was much bigger.
Edited By John W1 on 10/07/2015 14:24:05
Michael Gilligan10/07/2015 14:45:40
23121 forum posts
1360 photos
Posted by John W1 on 10/07/2015 14:23:34:
John,
If you want to check ... here is the website for Peatol [in Harborne]
Ajohnw10/07/2015 16:08:20
3631 forum posts
160 photos
Different make but looks the same style of motor to me due to the external capacitor.
He isn't far from me so I have visited him a couple of times but not for a long time. I sold my Peatol a couple of years ago but kept a few of the bits which will probably find there way onto my Pultra. I'm hoping to machine the 4 jaw I have to fit directly on the spindle nose to avoid overhang and get the 3 jaw and do the same but will need to do some size checks for that. The 3 jaw can be persuaded to grip as true as any collet if it's on a lathe that can turn very round and parallel. Just machine the faces while the chuck is closed on a washer pulled back into a small register at the back. Remove the washer and clean up the slight lip that's left. Grip - I've held sharp 3/8 end mills in it and cut straight through 3/8 mild steel. Also a 1/8 in woodruff cutter probably a bit over 1in dia to its' full depth. (Making a router fence.)
David Clark 110/07/2015 20:39:59
3357 forum posts
112 photos
10 articles
Hi Herbert
There will be no power in a small grinder. I tried one on a small engraver, total waste of time.
James Alford10/07/2015 21:31:30
501 forum posts
88 photos
John,
Thank you. I am pleased with the machine, which was a Christmas present. The lump on the pully is just the stub of the billet from which I machined the pulley. I started doing it on a friend's lathe, but needed a bigger machine to bore it out. I did that on a huge great industrial machine in a factory at about 10:00pm. As I barely knew the person, I did not want to overstay my welcome, so it had to stay as it is.
I am not sure whether the comments from others regarding grinder motors refer to my motor or not: however, this motor is not from a grinder, is rated at 1/6hp and cost just £25.00 delivered.
James.
