DC motor Operation - Q&A
Andrew Johnston13/09/2013 17:10:43
7061 forum posts
719 photos
I thought I'd start this thread rather than continue to hijack a previous thread while trying to improve my understanding of DC motors.
I think we've already covered permanent magnet, and shunt wound DC motors. Essentially the speed is directly proportional to applied voltage, and torque is directly proportion to armature current.
Now to tackle series wound motors. It made my head hurt thinking about these. In a series wound motor the field coils and armature are in series, so the the same current flows through both. As before let's start with a 'perfect' motor, ie, no mechanical or electrical losses. If we apply a voltage across the terminals a current flows in both the field winding and armature. The interaction between magnetic field generated by the field coils and that generated by the armature causes the motor to start turning. As before, when the armature turns it also generates a back emf which reduces armature current. But this same current flows through the field windings, so the strength of the magnetic field from the field windings decreases. This is where my head starts hurting. In order to maintain the same back emf the armature has to turn faster because the field strength has decreased. But as the motor turns faster the current decreases still further and so on ad inifinitum, until the armature goes bang!
In practise mechanical and electrical losses will limit the speed to a finite number, but not necessarily low enough to prevent damage to the motor.
Does this argument seem reasonable?
Les Jones 113/09/2013 17:28:07
2292 forum posts
159 photos
Hi Andrew,
That is the same as my understanding of series motors. One thing I did consider was using a series motor from a washing machine as a shunt motor. (For better speed regulation.) I found that the resistance ov the field winding was very low. It would have required a very low voltage powering the field. (Less than 5 volts if I remember correctly - I did not keep any notes about the experiment.)
Les.
jason udall13/09/2013 17:37:37
2032 forum posts
41 photos
Am I missing something.
More rpm.》.more back emf 》less current》 less torque》 less rpm less back emf 》more current 》more torque more rpm......ie will tend to regulate ...
jason udall13/09/2013 17:38:12
2032 forum posts
41 photos
I believe its called negative feedback
Michael Gilligan13/09/2013 17:51:56
23121 forum posts
1360 photos
This seems to be a reasonable introductory text.
Les Jones 113/09/2013 17:57:23
2292 forum posts
159 photos
Hi Jason,
I think it could be considered negative feedback in terms of torque. The torque will be proportional to the square of the current. In terms of speed I think it is more like positive feedback.
Les.
john fletcher 113/09/2013 18:08:04
893 forum posts
Regarding running an ex washing machine seies wound motor as a shunt wound motor Jim ???? who other name I can't remember wrote a small book published by model engineering and he gave details of what he found when doing just that. As you say the field resistance is low, I ran a modified one as a seperately excited shunt wound generator several years ago, I think I energised the field from a 12 volt battery. I was just sort of playing around and didn't keep details, but it did work OK. The motors are well made, have very good balance, but rely on speed to obtain the power, they have a nice pair of bearings, very useful for other for other projects. I modified a Hoover pcb to give speed control, just got it working then some did an article in MEW on the very same thing. Motors on the latest machines with digital control are much the same, they are also fitted with a tacho for feed back.If you are interested in power electronic,there some very good components on early type printed circuit boards ready for removal,not so on the digital ones,shame. Ted
jason udall13/09/2013 18:21:13
2032 forum posts
41 photos
Les please explain..it would suggest "possitve feeback" implies more rpm 》more rpm...ie runnaway..but where would the energy come from..
Les Jones 113/09/2013 18:29:11
2292 forum posts
159 photos
Hi Ted (john fletcher 1),
I have not seen the book you mention, All of the speed control boards I have seen contained an IC on which I could find no data. All the motors I have removed had tacho feedback which was just a magnet and a coil generating an output frequency proportional to speed. I think they all used an analog control loop. I have read somewhere that some modern machines use brushless DC motors. I would be interested in playing with one of these if I ever come accross a scrap one.
Les.
John Stevenson13/09/2013 18:42:06
5068 forum posts
3 photos
Andrew forgive me for the hijack but it's just a heads up for the future.
Fork trucks run on DC motors [ the electric ones that is smiley ] the motor is the most expensive part on the truck and the most unreliable, some of these can cost 4K each. Because they also run at usually 48 volts normally the control gear has to be big and heavy to handle the current so not cheap.
Modern trend is to now run them on 440 v 3 phase motors, so cheap and the control gear is far lighter to supply these.
The magic bit is a 48 v DC inverter that takes it up to 440v 3 phase and given moder electronics they seem very reliable.
So a few years into the future as these get scrapped out could be a nice source of genuine clean 3 phase power at 440 volts.
John S.
Edited By John Stevenson on 13/09/2013 18:43:40
Michael Gilligan13/09/2013 18:57:58
23121 forum posts
1360 photos
Posted by john fletcher 1 on 13/09/2013 18:08:04:
<etc.>
Ted
That would be Jim Cox ... Workshop Practice No. 16.
Les Jones 113/09/2013 19:05:53
2292 forum posts
159 photos
Hi Jason,
As Andrew describes with a theoretically ideal series motor on no load runaway will occur. As the speed goes up the back emf increases. The difference between the supply voltage and the back emf will be less. This difference is the voltage across the field coils so the field current is reduced which means the motor must go faster to produce the same back emf. As the motor is producing no external torque there is no energy output. all the energy that has been supplied to the motor will be stored as kinetic energy in the rotating mass of the motor.
Les.
Ian P13/09/2013 19:20:51
2747 forum posts
123 photos
Posted by John Stevenson on 13/09/2013 18:42:06:
John S.
Well you could be right but to generate enough amps at 48V to drive the inverter will require a substantial power supply (or batteries and a charger) if the 440Voutput from the inverter is going to do any useful work.
I don't see why the 'genuine clean' 440V will be any cleaner then the three phase synthesised in the common VFD. It only has to clean enough for the job, not clean enough for an operating theatre
May as well convert the 240V mains to 440V with a simple autotransformer (with a VFD) its greener too.
Ian P
jason udall13/09/2013 19:30:18
2032 forum posts
41 photos
Les.."stored as kinetic energy in the rotating mass" ...which is increasing in rpm
....I think from memory proportional to the square of theta or rpm"
Russell Eberhardt13/09/2013 20:04:24
2785 forum posts
87 photos
Your argument is quite correct Andrew. A series would motor with no load will run away. The load will control the speed but the regulation (speed vs torque) is very poor.
So why are they used? They have very high starting torque ( and current of course ) so can be used for example for car starter motors and for traction motors for everything from milk floats to railways.
Russell.
Andrew Johnston13/09/2013 22:27:38
7061 forum posts
719 photos
Thanks all for the comments, and for confirming that I have the basic idea correct. It was the ever increasing speed that made my head hurt! But, as Les says, I eventually realised that in the 'ideal' motor there is no energy loss, and ultimately no torque, so the speed can be whatever it likes.
I don't know what the output waveforms of the inverters described by JohnS look like, but I can assure you that the output of VFD doesn't look anything like a 3-phase sinusoid. It is essentially three PWM waveforms, so constant amplitude, but varying duty cycle. There is no equivalent of the 'neutral' line so if you look at the output of a VFD you are effectively looking phase to phase. If you use an oscilloscope to look at the outputs it would be advisable to use a high voltage differential probe to avoid nasty surprises.
Muzzer14/09/2013 01:38:07
2904 forum posts
448 photos
Take a look at Curtis Instruments for typical inverters that are used in materials handling, utility and leisure vehicles (link below). They do controllers for brushed (series) DC motors as well as asynchronous (induction) and synchronous (permanent magnet). However, they don't boost the voltage up to mains levels. Instead they design the motors for the battery voltage in the first place.
For higher power applications, the battery voltage will tend to be higher to avoid silly currents and resulting lower efficiency. However, as you can see, they do 24V induction motor drives.
As Andrew says, the voltage is a PWM waveform but of course the current is smoothed by the inductance of the motor and is controlled to be a very smooth and accurate sinusoid. Most industrial motors nowadays are designed to tolerate the different voltage waveform which puts higher voltages stresses on the insulation but I've never had a problem with "old" motors when driven by a modern VFD.
Muzzer
Stub Mandrel14/09/2013 09:25:13
4318 forum posts
291 photos
1 articles
As you say, they will just go faster and faster until mechanical losses limit the speed, which for a well made motor might be 'quite fast'.
'Duplex' wrote a a small grinder for ME that was based on a simple 'universal (i.e. series wound) motor.
It had a typically neatly made, but crude in action, adjustable brake to limit the off-load speed.
Personally I woudl think this was a very silly way to make a grinding machine...
Russell Eberhardt14/09/2013 10:19:56
2785 forum posts
87 photos
Posted by MICHAEL WILLIAMS on 14/09/2013 09:24:10:
Early power electrical systems are a fascinating subject to study .
You mean like this?
That's where I did my study of electrical machines. The only "electronics" was the mercury arc rectifier and inverter. There was three phase ac on open brass terminals at that bench on the right. The HSE would have a field day there now!
Russell.
Andrew Johnston14/09/2013 10:54:50
7061 forum posts
719 photos
When I was deciding which university to attend I saw an electrical machines lab like that during one visit. And the guide was very proud that some of the machines were made in the 1890s. Put me right off, at the time. It didn't help that it poured down all day and on the bus ride from the railway station to the campus all I could see were damp, drab concrete buildings.
PS: Note the bus journey; none of the modern trend where the university tours are as much for the parents as the prospective students. I think the most my parents did was give me a lift to the railway station in my home town. wink
Edited By Andrew Johnston on 14/09/2013 10:55:31
