straight shank adapter for MT2/MT3 drill bits
Adam Harris05/01/2021 20:15:12
533 forum posts
26 photos
I am struggling to find a straight shank adapter (1/2" shank would be good) for holding my MT2/MT3 drill bits to use in portable drill - can anyone steer me in the right direction please?
peak405/01/2021 20:26:33
2207 forum posts
210 photos
When I needed one for my old AEG/Unifix drill, I made one out of an old MT2-MT2 extension that I had in stock.
ARC sell them, new but there are obviously many other sources.
Mine was slightly more complicated as I also needed a threaded section, to screw in to the hammer mechanism of the drill to disengage it and make the drill rotary only.
From past experience, just be a wee bit careful using large metal cutting bits in a hand drill; even in just hardwood.
Bill
Pete Rimmer05/01/2021 20:49:16
1486 forum posts
105 photos
Posted by Adam Harris on 05/01/2021 20:15:12:
1. Buy a AEG/Wolf gutbuster which has a MT socket.
2. Hang on tight (or pay someone else to).
Here's an example
Edited By Pete Rimmer on 05/01/2021 20:55:57
DC31k05/01/2021 21:07:10
1186 forum posts
11 photos
Posted by Pete Rimmer on 05/01/2021 20:49:16:
As an alternative to busting his gut, he might consider something that will help reduce his gut and keep him warm on those long winter workshop evenings:
https://www.ebay.co.uk/itm/packer-boiler-ratchet-drill/224023213046
old mart05/01/2021 21:25:22
4655 forum posts
304 photos
Parallel od sockets are available, I have two, 1" and 2" for MT2. Capstan lathes use them. The taper part of the drill is not as hard as the rest and if you can hold them using the centre at the end of the tang to steady them you can turn down the taper. I turned parallel shanks on some of the smaller MT3 drills, and one of the volunteers took a MT3 26mm drill home to turn as his lathe could just pass about 28mm through the spindle.
Adam Harris05/01/2021 21:42:14
533 forum posts
26 photos
Pete that Wolf drill link is sold. Struggling to find on ebay any electric drill that says it takes Morse Taper. Only found a Metabo which was £250 odd and at that level I'd rather get a Mag Drill. Is there a particular Wolf model you know that takes MT bits (and the seller may not know)? Other Wolf Sapphire drills do not seem to have any MT extension on the nose
Edited By Adam Harris on 05/01/2021 21:43:46
noel shelley05/01/2021 22:33:14
2308 forum posts
33 photos
BIG handheld drills are affectionatly known as gut busters, but it's not your gut that gets broken it is more likely to be your wrists or fingers. Much above 1/2"dia be very careful. For larger sizes if not needing deep holes a slowspeed drill and hole saws can work. and much safer. Good Luck Noel
JasonB06/01/2021 07:02:57
25215 forum posts
3105 photos
1 articles
Why would you risk injury from an old Gut Buster, Modern SDS plus machine with a clutch and set to rotary only is a lot safer and the if you get one with vari speed even nicer to use. 1/2" chuck on SDS+ arbor will then hold your parallel shank adaptor.
DC31k06/01/2021 08:39:26
1186 forum posts
11 photos
Posted by JasonB on 06/01/2021 07:02:57:
...Modern SDS plus machine with a clutch and set to rotary only is a lot safer and the if you get one with vari speed even nicer to use. 1/2" chuck on SDS+ arbor will then hold your parallel shank adaptor.
There are some challenges with this idea.
The major dia. of the SDS shank is circa. 10mm, with its cross-sectional area reduced by grooves and slots. Its torque-transfer ability is therefore limited. Compare with the traditional way of holding oversize drills in a standard 1/2" capacity chuck - blacksmiths's drills (Silver and Deming). They have a full dia. 1/2" shank.
The adapters from SDS to 1/2" UNF for drill chucks are often made of low quality material, so when overloaded, they twist, making them very difficult to remove from the SDS chuck. This is especially a problem in rotary-only mode where the chucks's drive key bears on the same part of the adapter all the time, as there is no reciprocating action to create uniform destruction.
Your idea has merit if he wants to stand in his own house and drill a hole in his neighbour's one. There is a big issue with length. A Jacobs chuck on an SDS adapter sticks a long way out from the nose of the drilling machine. To that you want to add a straight shank to Morse adapter (minimum length slightly over the tapered length of the bit's shank) and into that you want to poke a relatively long Morse taper drill bit.
This one on eBay has suffered some bodgery but it has Morse taper (the ejection slot is shown in one of the pictures) https://www.ebay.co.uk/itm/Vintage-very-large-Wolf-Drill/323818987520
It seems Wolf and Kango had some connection so a search under that brand could help.
Also made by Black and Decker, when that was a good brand:
https://www.ebay.co.uk/itm/Black-and-Decker-2-Speed-Industrial-Drill-240v-3-4-22mm-Chuck/324400611399
https://www.ebay.co.uk/itm/DRILLING-MACHINE-BLACK-DECKER-HIGH-TORQUE-INDUSTRIAL-3-MORSE-TAPER-240-volt/224009296517
I have also seen an old DeWalt version of the same, in 110v.
JasonB06/01/2021 08:53:53
25215 forum posts
3105 photos
1 articles
From using large wood augers I would say the clutch will cut in long before a drill or adaptor fails, or you could go upto SDS MAX. The whole reason for using something with a clutch is it will slip before there is enough load to snap the drill bit or your wrist which will likely come first.
David George 106/01/2021 09:14:52
2110 forum posts
565 photos
Look up Rotabor cutters a lot safer than drills in a hand held drill.
David
Martin Connelly06/01/2021 09:21:58
2549 forum posts
235 photos
DC31k, my Bosch SDS drill has interchangeable SDS chuck and keyless 3 jaw chuck (which I think is Ø13mm). It has a clutch which is easy to trigger, if using a 4" core drill on hard bricks for example, if pushed too hard. The clutch operating point is set at a good value because the kicks that occur just before it operates are quite high but manageable. Useful if you are up a step ladder.
Martin C
John C06/01/2021 09:31:57
273 forum posts
95 photos
Adapters are available - here is an example but rather pricey: Link
I am sure I bought one from Arc but can't find one in the current catalogue.
Mike Poole06/01/2021 09:32:19
3676 forum posts
82 photos
I think your mag drill idea would be the best way to go with some Rotabroach cutters if you are drilling steel. I don’t like using decent drills in handheld equipment as the lands of the drill will almost certainly get worn. You haven’t said what you will be drilling but I am assuming steel. If the taper shank drills are expendable then the shanks can be turned down quite easily.
not done it yet06/01/2021 10:31:35
7517 forum posts
20 photos
Arc do these:
but clearly supplied for precision - not a drill waving around about half a metre from the chuck.
The obvious alternative is one of these. Less extra length but has a groove down one side (not a problem with a 3 jaw chuck?). Not 1/2” but you can’t expect everything for a bodge like this?
I just hope you don’t intend drilling holes greater than the drill manufacturer recommends (the chuck size fitted is a good indicator) and it might appear your drill is only a 1/2 inch one?
Edited By not done it yet on 06/01/2021 10:33:21
Nicholas Farr06/01/2021 11:31:59
3988 forum posts
1799 photos
Posted by John C on 06/01/2021 09:31:57:
Hi John, Arc had a 1/2" to 2MT one in their No.10 catalogue.
I have used a 2MT to 3MT extension one in my 2MT gut buster drill on several occasions without any problems, it's all a mater of assessing the job and having the correct stance and keeping your mind on the job in hand allowing the drill to do the job and not forcing it. Gut buster drills were all you had to use on site work many years ago.
Regards Nick.
Edited By Nicholas Farr on 06/01/2021 11:48:28
Adam Harris06/01/2021 12:21:23
533 forum posts
26 photos
Thanks for all the efforts to impart H & S advice with such zeal. I do have two drills with clutches. I also have a few blacksmith drill bits. I have wanted a Mag Drill for a while but still can't really justify the price based on the infrequent use. I was really simply looking for a signpost to a cheap adaptor for my very large number of Morse Taper drill bits over 10mm. I'm not going to spend much money because blacksmith drill bits are cheap. I suppose my alternative is to make a threaded shaft to screw into MT holders that take a drawbar.
Adam Harris06/01/2021 12:47:03
533 forum posts
26 photos
Thanks DC31K for those links but they are all too expensive especially after postage .The first link looks promising but he seems to have welded the chuck shaft into the taper. I am really looking for a sub £30 adapter but if an appropriate old drill around that price with appropriate functions popped up then great. However I think clutches came into drills more recently
Howard Lewis06/01/2021 15:50:00
7227 forum posts
21 photos
The only parallel sided MT Adaptors in the Arc Euro catalogue are 3/4 or 1" diametr for 1 MT and 1" diameter for 2 MT, so are far too big to fit into a 1/2 capacity chuck.
Arc sell MT taper shank extension sockets. It MAY be possible to shorten the external MT shank, and turn it down to 1/2" diameter (Depends on how hard the shank is! )
The internal taper has a slot for a drift to eject the MT drill.
They come in 1MT to 1MT, 1MT to 2MT, 2MT to 1 MT , 2MT to 2MT, and 3MT to3MT,.
So, IF the shank can be modified, you would need
2MT to 1MT, 2MT to 2MT and 2MT to 3MT (A 1MT shank will probably finish up at less than 1/2" by the time that it is parallell ) Cost of materials will be about £35..
If you have not already got drifts to suit the three MT sizes, you will need to buy these as well, adding another £6 to the cost of the project.
Total cost circa £45 including shipping in UK, plus .time and effort to modify the shanks.
JasonB06/01/2021 16:19:07
25215 forum posts
3105 photos
1 articles
I think I'd be inclined to turn down the shank of an R8 - MT holder to 1/2" or maybe do the final bit by milling to give 3 flats or hex so it does not slip in the drill chuck. NDIY linked to a suitable R8 holder.
