Sid Wittmann | 31/01/2017 14:23:46 |
3 forum posts | Hello everyone. I recently bought a mostly complete ML7 and I'd like to power the leadscrew with a DC motor for fine feed. I don't have any requirement for threadcutting so it'll likely be a permanent fitting. The question is, what kind of DC motor and speed controller should I buy ? |
oldvelo | 31/01/2017 18:12:27 |
297 forum posts 56 photos | Hi Sid "Also what sort of motor should I consider". A 12 or 24 volt DC wind screen wiper motor is a good place to start and a PWM DC Speed Control from that corner of the world. My limited experience is using them for the power feed on A lathe and a Mill drill plus the oil pump on the lathe. http://www.kbelectronics.com http://www.surpluscenter.com/Electric-Motors/DC-Gearmotors/ May be useful place to start. Eric
Michael Gilligan | 31/01/2017 18:55:19 |
![]() 23121 forum posts 1360 photos | Sid, If it's seriously going to be permanent fit and frequent use ... you might consider something from the Parvalux range: **LINK** http://www.parvalux.com/products/dc-motors-and-geared-motors Not cheap ... but excellent quality; and they do turn up second-hand, if your wallet is cringing at the thought. MichaelG. |
Brian Oldford | 31/01/2017 19:54:15 |
![]() 686 forum posts 18 photos | In this day and age you could even consider a stepper motor using elements of http://www.jeffree.co.uk/pages/ml7-cnc/part-1-files/myfordcncpt1.htm |
Sid Wittmann | 31/01/2017 20:02:53 |
3 forum posts | Ta very much. Edited By Sid Wittmann on 31/01/2017 20:08:56 |
not done it yet | 31/01/2017 20:31:00 |
7517 forum posts 20 photos | There are plenty of u-toob videos on the topic. Enough to give you some inspiration, I would think. Just avoid the downright dangerous examples (open gears rotating is not the best idea!). |
John Haine | 31/01/2017 21:30:44 |
5563 forum posts 322 photos | That motor sounds reasonable. You can buy an MFA speed controller from Maplin, it's rated at 15 volts but I think you can run the motor output through the motor to a 24 volt supply but supply the electronics with 12 volts as it uses a simple MOSFET output stage. The Maplin part number is rn41u. |
Sid Wittmann | 01/02/2017 12:14:34 |
3 forum posts | That should get me going then....thanks |
Seafax | 01/02/2017 17:16:08 |
4 forum posts | Posted by Sid Wittmann on 31/01/2017 20:02:53:
If it's the one I think it is I use one as the feed motor on this machine:-
Edited By JasonB on 01/02/2017 17:45:07 |
Muzzer | 01/02/2017 18:57:48 |
![]() 2904 forum posts 448 photos | Posted by Michael Gilligan on 31/01/2017 18:55:19:
Sid, If it's seriously going to be permanent fit and frequent use ... you might consider something from the Parvalux range: **LINK** http://www.parvalux.com/products/dc-motors-and-geared-motors Not cheap ... but excellent quality; and they do turn up second-hand, if your wallet is cringing at the thought. MichaelG. I see they supply brushless motors, which clearly require a controller / drive to make them work. Indeed, they talk of "the controllers we supply", yet on their website there doesn't appear to be any mention of such products. Is it just me or is this one of these annoying companies that can't organise a simple website to describe their fairly limited product line? Murray |
JasonB | 01/02/2017 19:12:04 |
![]() 25215 forum posts 3105 photos 1 articles | Controllers from page 14 of catalogue |
Muzzer | 01/02/2017 19:38:14 |
![]() 2904 forum posts 448 photos | Where did they hide that? There was me expecting to find it in the "Products" heading rather than in the footnotes under "catalogues". As I said, rather a bizarre way of "selling" your products! |
Swarf, Mostly! | 01/02/2017 19:58:06 |
753 forum posts 80 photos | Hi there, all, Reverting to windscreen wiper motors for a moment, adapting one of those to a continuous rotation function means disposing of the wiper blade waggling linkage. I've never actually held one in my hands but I've wondered whether a side window raising/lowering motor might be simpler to adapt. They're obviously reversible. How do they compare, power-wise and mechanically? Best regards, Swarf, Mostly! |
Seafax | 01/02/2017 20:16:36 |
4 forum posts | Posted by Seafax on 01/02/2017 17:16:08:
Edited By JasonB on 01/02/2017 17:45:07 What was the reason for editing this and creating the false impression that it hadn't embeded properly JasonB?
Col. |
JasonB | 01/02/2017 20:21:20 |
![]() 25215 forum posts 3105 photos 1 articles | It was just showing as a black box not as it should, I tried getting the Embed code direct from youtube and same problem, it usually comes up about 3 lines long but I could only get one and a bit lines. No false impression, it did not embed. |
Neil Wyatt | 01/02/2017 20:48:19 |
![]() 19226 forum posts 749 photos 86 articles | |
Neil Wyatt | 01/02/2017 20:48:59 |
![]() 19226 forum posts 749 photos 86 articles | I have the power! (It takes ages to load, but does start eventually) |
Seafax | 01/02/2017 21:32:24 |
4 forum posts | Ok, thanks JasonB, I had played it back immediately after posting to verify it though so I've no idea what the cause could be. Col. |
Nick Hulme | 14/03/2017 19:46:21 |
750 forum posts 37 photos | Posted by Swarf, Mostly! on 01/02/2017 19:58:06:
Hi there, all, Reverting to windscreen wiper motors for a moment, adapting one of those to a continuous rotation function means disposing of the wiper blade waggling linkage. ESAB did a lot of testing in the 80s and found the most reliable DC motors available were Volvo wiper motors and used them to drive the wire in their MIG welding equipment, if you think about the job they do on a rainy day and how many years they last I'd say you've made the right decision Door window motors are similar but smaller and not designed for 100% duty cycle applications. - Nick Edited By Nick Hulme on 14/03/2017 19:46:57 |
Ian S C | 15/03/2017 10:42:30 |
![]() 7468 forum posts 230 photos | I use an old Lucas wiper motor on my milling machine table. You can knock the origonal spindle out of the worm wheel, and fit an extended spindle, on this you can fit your drive system, mine is a sprocket for a bike chain. Ian S C |
