Here is a list of all the postings Trevor Drabble has made in our forums. Click on a thread name to jump to the thread.
Thread: Marker pens |
09/05/2022 22:00:56 |
I would suggest you check out the extensive range stocked by Walters and Walters ( supplier of Dykem) on 017623 245445. |
Thread: English Wheel |
25/04/2022 11:17:14 |
We also used cyanide salt baths to harden sockets , spanners and other associated products when l worked at Gordon Tools in Sheffield. |
Thread: ME handbook Capstan and Turret Lathes |
23/04/2022 21:47:21 |
Mike , I have a copy available with damaged cover , but am afraid it will be some time before l can look for it . Trevor. |
Thread: Ping - and a screw is lost |
19/04/2022 18:37:13 |
Iain , Are you anywhere near a Dunelm store at all? In the past I have found their materials racks very useful . |
Thread: Liquid Plus Gas |
29/03/2022 15:52:45 |
I believe D&M Tools sell it . Always had good service from them in the past . No connection other than as a customer . |
Thread: MT1 cutter arbours |
21/03/2022 10:15:58 |
Peter, Suggest you try Beaufort Ink in Devon who are advertising an 18 piece ER32 collet system on a No 1 MT for £129.95. |
Thread: Mill Lighting |
10/02/2022 15:38:08 |
Chronos supply 4 off different machine lamps as well as a matching strong magnetic base . |
Thread: Rust Protection |
27/01/2022 09:32:28 |
Chris , You may find theundercoverworkshop on eBay may be able to help with more suitable covers . Also , in the past , people have put a low powered electrical heat source , such as a small light bulb , under their covers to help reduce the problem of condensation. |
Thread: Milling machine advice |
16/01/2022 11:19:06 |
Fred , Totally off piste to all the other advice , the English maker Cowells produce a lovely micro milling machine which is worthy of consideration, albeit a little above your budget. |
Thread: Milling machine, but which brand ? |
12/01/2022 18:01:20 |
DH , The Centec that G&M have for sale of any interest ? |
Thread: VFD - which is best please ? |
31/12/2021 15:17:00 |
+1 for Newton Tesla . My decision was based on the fact that l knew nothing about VFD when l was fortunate enough some considerable time ago to meet a chap at a model exhibition in Lancashire who was selling both individual and packaged units. He was very patient and explained in depth the salient points to look out for , whether l bought his or someone else's . These included a good after sales service . It turned out this chap was Mr NT . I subsequently purchased my equipment from NT and it has performed faultlessly ever since , so no complaints at all . One point of note , broadly in line with AJ comments , they recommend the motor not be run for extended periods below 800 rpm , hence the need to retain mechanical speed reduction options for maximum flexibility. |
Thread: Shims |
28/12/2021 17:07:24 |
Bill , Cromwell Tools used to do it in both brass and steel in assorted packs . Or alternatively , if you have an idea of what length and width required and in what thicknesses , I'll check my limited stocks for availability. |
Thread: Myford Felt Wiper dimensions |
28/12/2021 16:59:41 |
Mark , Have you also checked out same at Home and Workshop Machinery ? |
Thread: Horizontal Milling |
09/12/2021 12:44:00 |
Steve , Sent you a PM . Trevor. |
Thread: Plans and castings |
18/11/2021 19:42:18 |
Polly supply a number of stationary engines. |
Thread: repairing old Tomy Trackmaster Thomas trains |
10/11/2021 21:57:34 |
Also , replacement r/c servo gears available from larger r/c model shops and also Ripmax . Trevor. |
09/11/2021 12:56:42 |
Also , any of the MFA 951 motor and gearbox combinations available for Cornwall Model Boats @ £9 ? Trevor. |
09/11/2021 12:46:43 |
Mike , Any of the following Hobbies products of interest ? 1) Gearwheel set @ £15.99 2) Axle Gearwheel set @ £17.99. 3) Multi Ratio Gearbox @ £7.99 . Trevor. |
Thread: Charatan motors |
07/10/2021 07:53:58 |
Colin , l have 2 off Smith's car heater motors available , and can supply details if you're interested. Trevor. |
Thread: Chain Protection Sleeve |
06/10/2021 12:30:34 |
Clive , For a custom made solution l suggest MachGuard in Rotherham or the wire-reinforced ducting and hoses available from Arco in Sheffield . Trevor. |
