MT1 cutter arbours
Peter Ellis 520/03/2022 16:59:41
110 forum posts
11 photos
Hi
I need some 1 Morse Taper milling cutter arbours. Does anyone know who stocks them, please ? I checked ARC, Chronos and Rotogrip, but couldn´t find any. They used to be quite widely available. I´ve Imperial sizes, and 6mm, but need some larger, e.g. 10mm, metric ones.
Cheers
Peter
bernard towers20/03/2022 17:30:36
1221 forum posts
161 photos
I had the same trouble late last year and found one at chronos and two at rotagrip. in the end rotagrip refunded as no stock and got one from chronos. The other possibility is to try Millhill Supplies as sherline is 1 mt. In the end I opted for a 1mt ER16 collet chuck as I already use that size collet. So far it has been ok.
Peter Ellis 520/03/2022 17:53:42
110 forum posts
11 photos
Thanks Bernard. I´ve emailed them.
Cheers
Peter
David George 120/03/2022 19:13:05
2110 forum posts
565 photos
I bought a No 1 morse taper ER16 collet set from RDG Tools. A while ago.
David
Trevor Drabble21/03/2022 10:15:58
339 forum posts
7 photos
Peter, Suggest you try Beaufort Ink in Devon who are advertising an 18 piece ER32 collet system on a No 1 MT for £129.95.
Howard Lewis21/03/2022 15:55:08
7227 forum posts
21 photos
I was going to suggest getting a 1 MT ER collet set. You can then mount, within reason, any size of cutter fro which you have a collet.
As a guide,ER25 will take up to 16 mm diameter shank cutters.
DC31k21/03/2022 16:45:58
1186 forum posts
11 photos
Posted by Trevor Drabble on 21/03/2022 10:15:58:
...ER32 collet system on a No 1 MT ....
Is ER32 on MT1 not just a little ambitious?
Another option is a soft blank arbor and make your own. RDG sell MT1 ones with an M6 thread in the back for a drawbar. Chronos sell tanged oned slightly cheaper should you want a different drawbar thread.
If you are tight on headroom on the machine, this is likely to be the shortest solution. If you go for the ER option, clearly, the bigger the ER-number, the longer the overhang.
Roger Woollett21/03/2022 17:16:14
148 forum posts
6 photos
Gloster Tooling do variious ER collet chucks on 1MT. I have an ER20 chuck and collets from them.
old mart21/03/2022 17:59:04
4655 forum posts
304 photos
I would go for the er16 which holds up to 10mm which is a good maximum for MT1. you may have to make a drawbarif the threads do not match your existing one, easy with threaded studding. Rather than getting a full set of collets, it might be better to get them individually in the sizes which you are going to use. The shank diameters of any imperial ones would have to be converted to metric to find which sizes cover them. I remember seeing for sale on ebay, 50mm shell mills with a MT1 arbor which had been custom made in the USA. Alright for milling plastic, maybe.
Peter Ellis 521/03/2022 21:09:51
110 forum posts
11 photos
Posted by Howard Lewis on 21/03/2022 15:55:08:
I already have a 1MT collet chuck and collets. I am looking for more dedicated arbours.
I agree that I could make some out of blanks, which might be a better solution, as I could thread them internally, as well, to suit threaded cutters.
Cheers
Peter
bernard towers21/03/2022 23:15:08
1221 forum posts
161 photos
Peter, Out of interest I Have made a nut threaded with the spindle thread on my sherline mill so with the No1 MT er16 collet chuck fitted and drawerbar tightened the nut on the spindle thread can be spun down to contact the collet chuck making it more rigid in the same way Clarkson did for their No2 MT collet chucks as they felt that the taper a bit flimsy for hard work.
DC31k22/03/2022 07:25:58
1186 forum posts
11 photos
Posted by Peter Ellis 5 on 21/03/2022 21:09:51:
...I could thread them internally, as well, to suit threaded cutters...
Think very hard before you proceed along this road.
The cutting forces will tend to tighten the cutter making removal difficult unless there is a retractable stop at the back end.
How will you ensure alignment or fit between the thread and the reamed bore such that the two are not fighting each other in keeping the cutter concentric?
In a Clarkson-style chuck, the thread just stops axial movement of the cutter. The removable nose allows easy removal.The cutter is kept concentric by the centre at the end and the fingers of the collet.
AIUI, Clarkson-style cutters have a 20 tpi Whitworth form thread on them regardless of shank diameter (see: https://www.model-engineer.co.uk/forums/postings.asp?th=50573). You can take up the challenge of finding a 10mm x 20 tpi tap or attempt to internally screwcut it...
