Clive Foster | 05/10/2021 14:47:42 |
3630 forum posts 128 photos | I need to sleeve some small (6 mm link?) chain so it doesn't damage things where it touches in a mobile application. The sleeve needs to be thick enough for useful protection but thin enough not to greatly reduce flexibility. Need it long enough to get 4 ft or so lengths out of it. All I can find is large sleeving for the heavy duty motorcycle and plant securing chains. Nothing for smaller sizes which surprises me given the number of places that sell relatively lightweight 6, 8 , 10 and 12 mm link chains for moderate security uses. The chain in this application is unavoidably a little slack so it will rattle. Firm fixing is via aero elastics. The chain and padlock merely provide a modicum of security against opportunist theft. Clive |
ega | 05/10/2021 15:11:40 |
2805 forum posts 219 photos | Such sleeves are used on recumbent cycles where there is a need to protect the chain. ICE (Inspired Cycle Engineering) is a possibility. |
Brian G | 05/10/2021 15:20:55 |
912 forum posts 40 photos | Assuming you don't mean roller chain, how about using heat shrink tubing without shrinking it? Brian G |
Clive Foster | 05/10/2021 15:36:12 |
3630 forum posts 128 photos | ega Bicycle / trike chain protection sleeves generally seem to be split with a velcro joiner so they can be wrapped round the structural tubes for protection if the drive chain should whip against the tube. Unfortunately the parts I'm hooking onto and running the chain over won't accept a wrapped protector so I have to fit it to the chain. The velcro joiner doesn't stand up to flexing and the nominal bore appears overlarge. Brian G Unfortunately heat shrink and ordinary flexible cable sheathing are too thin for lasting protection. Heat shrink is fairly pants at bending too. Tends to go into lots of kinks. Something I tried in a slightly different application as an emergency "night before we leave" fix many years ago on the firms money. It just survived a fortnight long field trial. Thanks for the suggestions. Clive |
Adrian R2 | 05/10/2021 15:39:05 |
196 forum posts 5 photos | Not answering the question, but have you considered using a plastic coated bicycle cable locks? |
DC31k | 05/10/2021 15:51:12 |
1186 forum posts 11 photos | Please see if any of the following RS part numbers provide some inspiration: 668-1254 668-1273 668-1239 Something tough enough that works on the Chinese finger trap principle might do. |
Robert Atkinson 2 | 05/10/2021 15:58:15 |
![]() 1891 forum posts 37 photos | Silicone rubber tube? This is fairly thick wall but might not be tough enough. Use soapy water as lubricant while fitting. Robert G8RPI |
Clive Foster | 05/10/2021 16:12:39 |
3630 forum posts 128 photos | Posted by Adrian R2 on 05/10/2021 15:39:05:
Not answering the question, but have you considered using a plastic coated bicycle cable locks? That's actually where I started but the available lengths just don't work out. Except for the ones that roll up like a flexible tape measure. The lock part of those is, inevitably, relatively large and I'm unsure about accommodating it. Having a large lock swinging around would rather defeat the objective. Would need to buy one to try one and its a rather expensive device to waste. Some breeds are said to be poorly engineered on the lock mechanics too. DC31k Very interesting suggestions. I think the silicone sleeved glass fibre type might well be up to the job. Fibre inner should spread the load so the silicone sleeve doesn't rub through quickly on a small contact area. Which is what happens if you use ordinary, thin, sleeving on a chain. Its amazing what you can find these days from folk like RS et al. If you know what to search for. I remember when the RS catalogue was just a single volume yellow book! Time to root round the "one day from RS I'd like list to get free delivery. Robert As mentioned previously the issue with chain is it tends to give a very small contact area where it rubs so silicone and similar thin sleeves don't stand up well. Thicker sleeving tends to do better as it compresses to spread the load but then you loose out on flexibility. Braided (and sleeve?) is probably best of both worlds. Thanks Clive Edited By Clive Foster on 05/10/2021 16:41:50 |
Nick Wheeler | 05/10/2021 17:12:31 |
1227 forum posts 101 photos | How about something like THIS? |
Clive Foster | 05/10/2021 17:29:27 |
3630 forum posts 128 photos | Nicholas DC31k got there first. Same sort of thing as RS 668 1273. I'm surprised by how many varieties of something I'd never heard of, until this afternoon, floating around. And I try to keep up. Thanks. Looks like I'll be trying something of that ilk, unless someone comes up with the perfectly engineered for the job solution. Clive |
DC31k | 05/10/2021 17:31:02 |
1186 forum posts 11 photos | Posted by Clive Foster on 05/10/2021 16:12:39:
Its amazing what you can find these days from folk like RS et al. Those popped up just searching for 'cable sleeving' as my mind went blank on the proper term. I have now remembered that a generic search term is 'braided sleeving', e.g. https://www.hypex.co.uk/Techflex-Sleeving-and-Heatshrink/Heavy-Duty-Sleeving/Gorilla-Sleeve/ https://www.hellermanntyton.co.uk/products/expandable-braided-sleeves (polyamide and even aramid are available) Another source for the siliconised fibreglass stuff is catering equipment suppliers, and as Nicholas' post above shows, it is also widely used in performance vehicles. My only concerns with this stuff are that it might trap moisture as it not very breathable and it might be somewhat baggy on the chain. |
Clive Foster | 05/10/2021 18:03:55 |
3630 forum posts 128 photos | DC31k Looks like we have a winner! The Gorilla sleeve is probably as good as it gets. Decent wall thickness at 0.05", 1.27 mm so it should take a while to wear through. Just need to work out the equivalent bore size so its neither baggy nor expanded. At the price per meter I'll probably end up buying more than one size. The Hellermann stuff appears to be intended to be used expanded as protection for things like precision rods and the like. Over the years I've bought many similarly wrapped. Fortunately water ingress by rain et al isn't going th be a problem as the open ends are well shielded. Thanks again for taking the trouble to track something down. Clive |
Steviegtr | 05/10/2021 19:28:04 |
![]() 2668 forum posts 352 photos | I would have thought good old clear plastic tube would work. The type you would buy from local auto spares shop or hardware store. Steve. |
bernard towers | 05/10/2021 19:45:26 |
1221 forum posts 161 photos | Modern push fit plumbing pipe?? |
Robert Atkinson 2 | 05/10/2021 19:48:39 |
![]() 1891 forum posts 37 photos | I'm not so sure about the braded coverings. They are good on hoses and cable bundles, but there is nothing to stop the filament moring apart. I'd be concerned thet the corners of the links could spread the filaments enough to be exposed. Robert G8RPI. |
Clive Foster | 05/10/2021 20:46:44 |
3630 forum posts 128 photos | Hoses, polyplumb and similar flexible but relatively thick wall tubes are good at preventing a chain from eating what its wrapped round. But, of necessity, the thick walls constrain the chain to sweeping bends. They cannot accommodate the near 180° flexibility possible at link to link joints of an open or lightly constrained chain. My application requires the chain to go make a 180° turn round a pair of relatively thin rods, perhaps 3/8" diameter, and four fairly sharp 90° bends. The 180° turns need full link to link flexibility and the 90° bend radius is probably too sharp for a chain in a thick walled tube to follow well. Only a braided or woven protector can properly follow the 180° bends. The thin silicon skin on the woven glass fibre braids might stretch enough to follow. Or it might not. Something I'd need to try. A tightly woven braid will follow a sharp bend so long as the outside isn't sufficiently tensioned so as to open the braid all the way round. The Gorilla sleeve is tightly braided and, if a little oversize, ought not stretch enough when run round the outside of the chain curve to separate at the contact points. We shall see. A picture being worth a thousand words this is the application :- Helmet bag on a Krauser K2 top plate fitted to my Yamaha GTS. Plenty of space in the compartment under the bag to hold the lock but the chain needs to follow the bends quite closely so as not to rattle uncontrollably. It cannot of course be made tight enough to hold the bag. Lockable closure is already sorted. Clive
not done it yet | 05/10/2021 21:43:20 |
7517 forum posts 20 photos | Lay flat water hose? |
Clive Foster | 05/10/2021 21:58:15 |
3630 forum posts 128 photos | Posted by not done it yet on 05/10/2021 21:43:20:
Lay flat water hose? I've never actually seen lay flat water hose but it could well do the deed if orientated the right way and of suitable bore. Good idea. Clive |
AJAX | 05/10/2021 22:01:10 |
433 forum posts 42 photos | Posted by Clive Foster on 05/10/2021 20:46:44:
Hoses, polyplumb and similar flexible but relatively thick wall tubes are good at preventing a chain from eating what its wrapped round. But, of necessity, the thick walls constrain the chain to sweeping bends. They cannot accommodate the near 180° flexibility possible at link to link joints of an open or lightly constrained chain. My application requires the chain to go make a 180° turn round a pair of relatively thin rods, perhaps 3/8" diameter, and four fairly sharp 90° bends. The 180° turns need full link to link flexibility and the 90° bend radius is probably too sharp for a chain in a thick walled tube to follow well. Only a braided or woven protector can properly follow the 180° bends. The thin silicon skin on the woven glass fibre braids might stretch enough to follow. Or it might not. Something I'd need to try. A tightly woven braid will follow a sharp bend so long as the outside isn't sufficiently tensioned so as to open the braid all the way round. The Gorilla sleeve is tightly braided and, if a little oversize, ought not stretch enough when run round the outside of the chain curve to separate at the contact points. We shall see. A picture being worth a thousand words this is the application :- Helmet bag on a Krauser K2 top plate fitted to my Yamaha GTS. Plenty of space in the compartment under the bag to hold the lock but the chain needs to follow the bends quite closely so as not to rattle uncontrollably. It cannot of course be made tight enough to hold the bag. Lockable closure is already sorted. Clive That braided sleeving is good stuff for many jobs but your need to stop it fraying (easily done with heat shrink tubing) and purchase the correct size, which is sometimes easier said than done. If you take a length and "shorten" it by pushing end-to-end the diameter opens up, sometimes quite significantly. Under tension, the diameter really closes down and it can be a problem to feed cables (or whatever) through. I have some reels of it somewhere (maybe +100 m), but it may not be the size you are after. Laid flat (as it comes off the reel) what width are you hoping for? Brian |
Clive Foster | 05/10/2021 22:20:50 |
3630 forum posts 128 photos | Brian When it comes to a suitable size for the braided sleeve the short answer is "I dunno". Had some preliminary thoughts which I will look over tomorrow then will order a couple of sizes to try. Compared to the inconvenience of carrying the helmet all the time when I park up, or having light fingered laddie lift £400+ worth of head gear, if I just rely on the aero elastics wasting a few £ on unused sizes of sleeve is trivial. Usually such stock comes in handy in the future anyway. I'm tired of running round with big panniers all the time just so I can park my hat. Clive |
