Michael Callaghan | 26/10/2022 11:40:46 |
173 forum posts 7 photos | Hi, still need some help. Today I took a look a look at the oil in the drill, only to find that there was none. So as the site glass looked like there was oil in the drill, I removed same and remade a new glass. However I have now two problems. The first is what oil should I use, and second where’s the oil filler. If anyone knows can they please let me know. Thanks |
AJAX | 26/10/2022 12:08:56 |
433 forum posts 42 photos | I can't answer your question but I'd be interested to know how you made the sight glass and the material used. |
Michael Callaghan | 26/10/2022 12:50:00 |
173 forum posts 7 photos | Hi, I made the site glass using a bit of clear plastic from cheap plastic storage box. Just marked the diameter and cut it out with a pair of scissors |
Fatgadgi | 26/10/2022 14:44:26 |
188 forum posts 26 photos | The filler plug is on top of the head casting, under the top cover (below the belt). It’s a hex socket plug. Is funny, I had to make a new sight glass as well, must be a common thing. I turned a disc of clear plastic (Acrylic?), and used silicone sealant to fix and seal. Been there 30, and looks 3mm thick. Cheers Will |
Michael Callaghan | 26/10/2022 15:49:33 |
173 forum posts 7 photos | Thanks for letting me know. I just hope I don’t find a lot of oil pouring all over the place once I have filled the drill. |
Kiwi Bloke | 27/10/2022 01:36:42 |
912 forum posts 3 photos | The oil originally specified was Shell Vitrea 69. This pre-ISO number became Vitrea 150, post-ISO standardisation. Current equivalent seems to be Shell Morina S1 (or S2) B 150, available in small quantities here: **LINK** (no connection with the firm, and not a customer) It's not going to be a critical choice, however, there's a large gear in the gearbox that is Tufnol, or a different, grey plastic that swells with age. So, perhaps, one should avoid lubricants stuffed with additives, or 'synthetics'. Mine piddled oil out from the gear-change lever's bore, but it's a simple O ring seal. |
Michael Callaghan | 27/10/2022 09:13:25 |
173 forum posts 7 photos | Thanks Kiwi, I hope mine does not have a P. And thanks for the link. |
