jon hill 3 | 22/07/2023 22:16:58 |
166 forum posts 40 photos | Hi all My Myford speed 10 countershaft pulley (the one on the same side as the motor pulley) makes a funny noise at low rpm. This probably due to mistakingly filling it with grease instead of oil. Rooky mistake which I left for sometime until the noise became noticable, so thought it might be time to sort it out. Anyway I removed the primary drive belt and took out one retaining grub screw for the pulley but it still won't come off. Is there some other retaining screw or fixing? I have'nt taken off the grease nipple if this holds the shaft to the pulley? Any ideas on removal? |
AJAX | 23/07/2023 08:08:06 |
433 forum posts 42 photos | Have you checked whether there is another grub screw hidden under the first one you already removed? |
ALLAN QURASHI | 23/07/2023 11:08:43 |
24 forum posts 4 photos | There are indeed two, 90 degrees apart. |
ALLAN QURASHI | 23/07/2023 13:23:56 |
24 forum posts 4 photos | sorry....180 (ish) apart. |
jon hill 3 | 23/07/2023 15:20:43 |
Allan on my speed 10 the grub screws are drill and taped 90 deg apart, there are only 2. Could be different on the ml10? Anyway the pulley is still held fast, I have taken off the oil nipple. Plan b is it advisable to put some light penetrating oil to displace the grease, clean and shot some more of the correct myford oil? Edited By jon hill 3 on 23/07/2023 15:25:54 Edited By jon hill 3 on 23/07/2023 15:27:18 |
Robert Atkinson 2 | 23/07/2023 15:32:57 |
![]() 1891 forum posts 37 photos | A 3 legged puller and some heat (hot air gun or paint stripper) applied to the pulley should get it off. Robert. |
jon hill 3 | 23/07/2023 15:50:04 |
166 forum posts 40 photos | Could be difficult, as there is only 5" of space between the pulley and window. Is it possible to use some forked wedges?
Clive Hartland | 23/07/2023 15:55:48 |
![]() 2929 forum posts 41 photos | Socket set screw, cup point. could have raised a burr? |
jon hill 3 | 23/07/2023 16:19:08 |
Is there some sort of honeycomb reservoir for the oil in the shaft or bronze bearing? Also how do I best remove all grease and re-oil? Edited By jon hill 3 on 23/07/2023 16:25:34 Edited By jon hill 3 on 23/07/2023 16:26:35 |
