Trouble with M2 thread
Eric Cox20/09/2014 09:02:47
557 forum posts
38 photos
I'm drilling a 1.7 mm hole in aluminium and threading it M2 x 0.4. When I screw in the M2 threaded rod which fits an M2 nut perfectly the rod will not hold. The rod measures 1.8 mm in dia. Am I trying to screw a fine thread rod into a course thread hole Also the tap appears to be too big to screw into the M2 nut.
Edited By Eric Cox on 20/09/2014 09:03:59
Les Jones 120/09/2014 09:23:16
2292 forum posts
159 photos
Hi Eric,
The chart I have I have suggests a 1.6mm tapping size drill. If you are using a 1.7mm drill (And assuming it does not drill oversize) then as the threaded rod measures 1.8mm then there is only 0.05mm (About 2 thou) engagement. I suggest also checking the pitch of the threaded rod by measuring how far the nut moves when it is rotated 10 revolutions. Just use a digital caliper to measure from the end of the rod to the nut.
Les.
Andrew Johnston20/09/2014 09:44:25
7061 forum posts
719 photos
Eric: I drilled and tapped a few M2 threads last week for a client project. I used a 1.7mm drill, which should be about 70% engagement and had no problem with the threads holding. A value of 1.8mm sounds a bit small for an external M2 thread; I just measured one of my M2 screws and it is a tad over 1.9mm. The other possibility is that your drill is drilling over-size. What make of drill are you using?
HomeUse20/09/2014 09:51:05
168 forum posts
12 photos
Never had any problem but I always use a 1/16” drill (I have a lot of them) and they always seem to drill oversize so seem to give the correct engagement
Keith Long20/09/2014 10:04:20
883 forum posts
11 photos
Eric - to state the obvious, if the tap is too big to fit the M2 nut that your trying, then either the nut isn't M2 or the tap isn't! - You've got a mismatch between the tap and bolt/threaded rod. The problem now is to identify what it is that you've actually got and then sort out the way forward.
1.8mm is a standard metric thread, so you could have a M2 tap and a 1.8mm rod and nut - which sounds distinctly possible. Very easy to confuse by eye. It's also just possible that you might have 9 or 10 BA threaded rod and nut - 10 I think would be more likely that 9, buit the rod should have an od of 1.70mm in that case.
It's also possible that the tap is M2.2 - also a standard thread - but I think you'd have found that tapping the hole required more effort than expected as the tapping drill size for M2.2 is 1.9mm rather than 1.7.
Checking the pitch of the rod will help but you need to be aware that M1.8 has a pitch of 0.35, M2 can come with pitches of 0.25, 0.40 and 0.45. While M2.2 has a pitch of 0.45. Unfortunately 9BA has a pitch of 0.39mm so very close to the nominal M2 pitch, and 10BA has a pitch of 0.35 - the same as M1.8, so the comments from Les above about checking over 10 revolutions (at least) is very pertinent.
Good luck
Keith
JasonB20/09/2014 10:07:03
I've just finished an engine that had about 40 M2 holes tapped in aluminium, all done with 1.6mm drill and the screws hold firm.
Is it a bit of off the shelf M2 studding you are using as some can be quite poor quality and undersize. If its a rod you have threaded yourself try to expand the die a bit more to make the male thread OD larger.
Robert Dodds20/09/2014 19:33:53
324 forum posts
63 photos
Eric,
It's just possible that some ally may have galled up onto your tap and as you came out it tore the thread, making it oversize,It's not easy to spot at these small sizes and it is important to keep some cutting fluid around specially with aluminium
Bob D
Jeff Dayman20/09/2014 21:41:13
2356 forum posts
47 photos
A good quality -SHARP- HSS tap makes a world of difference in most metals but especially aluminum.
JD
Chris Trice20/09/2014 22:20:45
1376 forum posts
10 photos
This is a guess but is this rod a radio controlled linkage rod? The threads on these are rolled and frequently come out undersize on O.D. Combine that with an oversize I.D. in the tapped hole and they'll pull out easily.
Eric Cox21/09/2014 08:26:45
557 forum posts
38 photos
Thanks for all the comments. bare with me and I'll be back in the shed on Monday and let you know how I got on.
By the way, the threaded rod was off e-bay and the nuts and taps were from well known ME suppliers.
Edited By Eric Cox on 21/09/2014 08:29:08
Steve Withnell21/09/2014 11:53:56
858 forum posts
215 photos
Posted by JasonB on 20/09/2014 10:07:03:
That deserves an award for "Outstanding Patience"!
Steve
jason udall21/09/2014 14:15:26
2032 forum posts
41 photos
For one production part we had to tap M1.6 into 316S11 stainless steel..in effect bottomed ie two threads runout to blind hole....challenging enough but this was threaded for 5 mm at end of 4 mm deep ... clearance hole. .....these were ordered and delivered in lots of 250...they were turned prior to tapping in lots of 1000..that was the potential scrap rate...we budgeted for ten parts per tap...
In practice it settled down to over 500 parts per tap and the yield consequently went up.
The tapping fixture built for the job achived thread controlled infeed and finger tip reverse for swarf break ( you know that quarter turn backwards used with hand taps...)..
We ( well I) achived this with a simple very wide pulley...imagine a form with 60 mm between flanges and 80 mm dia flange..on spindle carrying tap...
Spindle floats and drive is via 50 mm "wheel" between flanges perp. To spindle.
Push spindle one way and drive is cw
pull spindle and drive stops and reverses.....
Another slide carries part and is fed as desired. ..leaving other hand to apply you favourite cutting compound. ....
Used mill to drive vertical spindle. ...and off you go. ..
From breaking two..to three taps per finished part to 100 s per tap...
Any way the real secret is present tap in line....and rigidity sideways....
Eric Cox22/09/2014 15:34:49
557 forum posts
38 photos
Problem solved, drilled 1.6 not 1.7 as stated in handbook.
Chris Trice22/09/2014 16:57:17
1376 forum posts
10 photos
It had to be the hole was getting drilled oversize assuming the tap was accurate.
Nick_G22/09/2014 18:48:03
1808 forum posts
744 photos
I see this chart gives different tapping drill sizes for different materials
Link to chart :- **LINK**
Nick
speelwerk22/09/2014 19:29:15
464 forum posts
Raised metric one of the first things I learned at school in the sixties was that the drill size for metric taps is 0.8 times the nominal tap diameter, It has and still works fine for me. Niko.
