Terry Blush | 24/08/2014 16:58:13 |
7 forum posts | Evening all I'm new to this site as I have a problem.
Does anyone have a drill press and know the ins and outs with them?
I have a wee B&Q powerbase one and lately when I have it running its been vibtating badly. I have worked out that this is due tothe front pulleys that turn the chuck, is liftingon the square drive shaft. I push it back down with some force and all is well for a few minutes then it lifts again.
There is a set screw to hold the pulley to the inner sleeve that sits on the square drive shaft but I don't see any screw to bite the drive shaft..
Any ideas?
Many thanks in advance.
Gordon W | 24/08/2014 17:27:05 |
2011 forum posts | I've just been looking at my similar m/c, don't really know what you mean. The square shaft has to slide up and down as the chuck is lowered, is it stuck ? Would suggest taking off the pulley block and see whats going on , maybe just needs clean and oil ? Maybe a bearing come loose, will prob. be able to loctite back in if so, but just guessing. Thought- the belt is on the same grooves ? Let us know. |
Terry Blush | 24/08/2014 17:52:47 |
7 forum posts |
Edited By Terry Blush on 24/08/2014 18:09:02 |
Terry Blush | 24/08/2014 18:10:56 |
7 forum posts | I understand the square rod drives the chuck is meant to slide up and down inside the pulley now, but why would the front pulley lift up? It lifts a good 40mm or so while the machine is running |
John Bromley | 24/08/2014 19:53:23 |
84 forum posts | The pulley should be held in place by a grub screw, I have a Clarke version of the same drill. From memory it is in one of the pulley grooves. Tighten it up and all should be well. John |
Steven Vine | 24/08/2014 20:04:45 |
340 forum posts 30 photos | Yeah, what John said. Its a 3mm hex head, in the 2nd groove down on mine. Steve |
Terry Blush | 24/08/2014 20:49:40 |
7 forum posts | Yep the grub screw is there and tight to the inner sleeve which is lined up to the flat spot. However that inner sleeve is what is sliding up
Terry Blush | 24/08/2014 20:50:50 |
7 forum posts | |
Steven Vine | 24/08/2014 21:16:52 |
340 forum posts 30 photos | Crikey. That short shaft should not come out of the bearing. Here is a picture of the assembly from underneath (the quill assembly has been removed). This picture is a shot of the underside of the top bearing. The shaft may need to be modified and then pressed in again so it it a tight fit. It has to transfer a lot of torque. Some of the more knowledgeable chaps will provide solutions. Steve |
Michael Horner | 24/08/2014 21:20:37 |
229 forum posts 63 photos | Hi Terry Afraid I can't help with direct experience but I found a manual on the Grizzly Tools website which may give you some ideas **LINK** . On page 28 of the document 34 in the Adobe reader shows an exploded diagram. It seems to show some internal and external retaining clips. Best of luck. Michael. |
Michael Horner | 24/08/2014 21:44:25 |
229 forum posts 63 photos | Posted by Steven Vine on 24/08/2014 21:16:52:
Crikey. That short shaft should not come out of the bearing. Here is a picture of the assembly from underneath (the quill assembly has been removed). This picture is a shot of the underside of the top bearing. The shaft may need to be modified and then pressed in again so it it a tight fit. It has to transfer a lot of torque. Some of the more knowledgeable chaps will provide solutions. Steve Hi Steve Just guessing but I think the grub screw in the pulley transmit the torque into square tube then into the spindle. I think the pulley should be a press fit in the bearings, a bit of low strength loctite should hold it in place. Can't find the fingers crossed icon. Cheers Michael.
Steven Vine | 24/08/2014 22:08:59 |
340 forum posts 30 photos | Thanks Michael. That makes more sense than the conclusion I came to. It's worth trying the simple loctite solution first. I just had a walk round to the shops, and was thinking, there and back, about how easy it would be to make another shaft so that it was a tighter fit. Steve |
Terry Blush | 24/08/2014 22:43:48 |
7 forum posts | Oh joys lol I have some metal epoxy that I could use to stick it back in with. It's weird that it just started to vibrate loudly.
Thank you gents for your time and help.☺ |
Ian S C | 25/08/2014 12:32:24 |
![]() 7468 forum posts 230 photos | The best thing to stick it together would be Bearing Grade Loctite(can't remember the number), with that the bearing can be removed with a normal bearing puller, it will also fill quite a big gap. I used it on the top bearing of my Vertical Milling machine's top bearing, after it spun in it's housing. Ian S C |
roofer | 25/08/2014 21:06:07 |
21 forum posts | Do remember though its a ting tong special and ive had my fair share of far East precision and its merits of things not fitting. |
Michael Gilligan | 25/08/2014 21:31:39 |
![]() 23121 forum posts 1360 photos | Terry, I agree completely with Ian's approach 641 is probably the most suitable grade. MichaelG. |
Terry Blush | 25/08/2014 23:20:24 |
7 forum posts | Cheers again, I'll have a look for some 641 and hopefully that'll do the trick. |
