Here is a list of all the postings Terry Blush has made in our forums. Click on a thread name to jump to the thread.
Thread: problem with pillar drill |
25/08/2014 23:20:24 |
Cheers again, I'll have a look for some 641 and hopefully that'll do the trick. |
24/08/2014 22:43:48 |
Oh joys lol I have some metal epoxy that I could use to stick it back in with. It's weird that it just started to vibrate loudly.
Thank you gents for your time and help.☺ |
24/08/2014 20:50:50 |
24/08/2014 20:49:40 |
Yep the grub screw is there and tight to the inner sleeve which is lined up to the flat spot. However that inner sleeve is what is sliding up
24/08/2014 18:10:56 |
I understand the square rod drives the chuck is meant to slide up and down inside the pulley now, but why would the front pulley lift up? It lifts a good 40mm or so while the machine is running |
24/08/2014 17:52:47 |
Edited By Terry Blush on 24/08/2014 18:09:02 |
24/08/2014 16:58:13 |
Evening all I'm new to this site as I have a problem.
Does anyone have a drill press and know the ins and outs with them?
I have a wee B&Q powerbase one and lately when I have it running its been vibtating badly. I have worked out that this is due tothe front pulleys that turn the chuck, is liftingon the square drive shaft. I push it back down with some force and all is well for a few minutes then it lifts again.
There is a set screw to hold the pulley to the inner sleeve that sits on the square drive shaft but I don't see any screw to bite the drive shaft..
Any ideas?
Many thanks in advance.
