drill chuck
jonathon cary | 14/08/2014 15:38:50 |
44 forum posts | I m wonder if anyone knows where I might be able to find an MT0 arbor preferably with a drill chuck atached..I ts to use in a miniature lathe built by my Grandfather 60 years ago-I ve finally decided to make something on it!Thank you |
JasonB | 14/08/2014 15:45:52 |
![]() 25215 forum posts 3105 photos 1 articles | The Sherline lathes use that size, have a word with Millhill supplies |
Neil Wyatt | 14/08/2014 15:48:58 |
![]() 19226 forum posts 749 photos 86 articles | Sorry Jonathon - just re-read your post and realised the lathe was built by your grandfather, so my comment was pointless... Neil Edited By Neil Wyatt on 14/08/2014 15:50:47 |
jonathon cary | 14/08/2014 16:11:54 |
44 forum posts | Millhill-Sherline do im fact do a 0 mt arbor with a chuck..Unfortunately at 1/2 lb weight and ?67 in money it wasnt pointless, just a tad expensive..! |
JasonB | 14/08/2014 16:21:28 |
![]() 25215 forum posts 3105 photos 1 articles | We had the same subject come up on another forum, there is not that much choice though there is a link to an e-bay seller in the US for arbors so just add a chuck |
John Bromley | 14/08/2014 16:27:12 |
84 forum posts | Could that not be your 1st project? Make a 0MT to #JT arbor. John |
Roderick Jenkins | 14/08/2014 16:58:07 |
![]() 2376 forum posts 800 photos | There are some 0MT arbours/chucks about on the web. Most of the commercial small lathes that have 0MT use the short 0MT version, which is the smaller half. Full 0MT arbours and centres stick out too far for serious use. Might be worth checking the lathe to see if your grandfather followed this practise. HTH Rod |
jonathon cary | 14/08/2014 17:25:26 |
44 forum posts | It will be a short one thanks Rod..I ll have to keep looking..Someone s got one somewhere..I think my first project will be a little canon partly to practice tapers on..! |
Neil Wyatt | 14/08/2014 18:00:49 |
![]() 19226 forum posts 749 photos 86 articles | I have a 'Golden Goose' brand Jacobs chuck on a JT0/MT1 arbor that weigh just 100g, the size would suite MT0 nicely. It's nice and smooth and holds drills down to number 80. It's also very nicely finished. I recall that I got it from Arc Euro, but I could be wrong. They list chucks this size, but tehy may not be this brand. Neil |
jonathon cary | 14/08/2014 19:15:50 |
44 forum posts | Phew!RDG do them although they didnt know it when I phoned, 0 mt arbors with 3/8 x 24 or 14x1 and female threaded chucks to suit on amazon..trouble with rdg it was on their ebay site and I found it by chance online..Not sure how long it is though..!!Thanks for all your help.. |
alan-lloyd | 14/08/2014 19:21:32 |
![]() 183 forum posts | Cowells use them I believe |
Steve Withnell | 14/08/2014 19:46:47 |
![]() 858 forum posts 215 photos | I have an MT0 dead centre somewhere if that's useful to you - no use to me. Steve |
jonathon cary | 14/08/2014 19:55:53 |
44 forum posts | Yes please Steve..I ll pm you with address..how many?? |
UJ Newton | 16/12/2014 18:33:09 |
23 forum posts | I ve been told Sherline,Cowells and Unimat arent proper 0 mt..they ve been altered..I phoned the firms and they told me! I suppose it stops people buying cheaper ones from other firms just like camera firms uesd to do with films.. I wonder if I buy a dead centre , which is available, is it going to be possible to turn the end down on this mini mini lathe and use a die on it..It s tool steel? |
Lambton | 18/12/2014 11:41:24 |
![]() 694 forum posts 2 photos | I think you will find the only alteration these companies make to No 1 Morse taper arbors is to shorten them by cutting some off the small diameter end. If they altered the taper in anyway it would no longer be a No 0 Morse item. |
Robert Dodds | 18/12/2014 15:02:14 |
324 forum posts 63 photos | Jonathon, The RDG arbor is long, about 1 5/8". I am going through a similar exercise with a Super Adept and that has a short hole for a stubby centre in both tailstock and headstock and in my instance, although the taper is M0 the top dia is 0.25"and just about coincides with the bottom dia of the RDG arbor. The first job was to set up another machine, I have a little Zyto with offsetting tailstock, match up the taper with a dti and then turn down the top portion of the arbor till I got to the required 0.25 dia, cutting off the remnant after double checking I got the taper and dia right as there is no going back!! I was lucky to have rescued a suitable 0 -1/4" chuck from a dead pistol drill some time ago so I only spent money on the arbor. Edited By Robert Dodds on 18/12/2014 15:05:26 |
Neil Wyatt | 18/12/2014 15:43:06 |
![]() 19226 forum posts 749 photos 86 articles | The story is that Adept tapers are the small end of MT0. I have an MT0 centre and adept head and tailstocks here on the bench. It may well be the same tape, but the small end of the MT0 is till to big. I think the Adept taper is best thought of an an 'unofficial' MT00. Neil |
Roderick Jenkins | 18/12/2014 17:20:26 |
![]() 2376 forum posts 800 photos | My Flexispeed is definitely the small end of a 0MT which, sadly, means that cutting down a full 0MT arbour isn't an option. This is a full OMT centre sitting in the tailstock. All the full 0MT centres I've seen are hardened but as it's a good bet that they are carbon steel they should be fairly easy to soften. Rod |
Neil Wyatt | 18/12/2014 17:41:54 |
![]() 19226 forum posts 749 photos 86 articles | Hopefully this photo of a brutally abused Super Adept headstock can be the definitive proof that the spindle taper was NOT the small end of 0MT - unlike Rod's Flexspeed and no doubt several other small lathes.
Neil Edit: I was struck by the fact the 0MT centre is longer than the 1MT arbour. In fact, the specification is for the gauge depth of the 0MT to be just 1/8" less than 1MT, at exactly 2", and as centres have to stick out a bit further.... Edited By Neil Wyatt on 18/12/2014 17:46:14 |
Robert Dodds | 18/12/2014 19:35:32 |
A photo of my turned down, cut down RDG arbor ready to fit to the chuck Edited By Robert Dodds on 18/12/2014 19:39:23 |
