A Continuous steering box- any still about?
Ady109/04/2014 10:03:41
6137 forum posts
893 photos
I read an interesting article from Jan 45, no 2281
To power a hand shaper they used a "continuous steering box" from a Trojan Utility vehicle which is a pinion inside an internally cut gearwheel
You can see the offset steering shaft into the circular box behind the clapper slide
This geared the lineshaft down by 4.5-1
Do any of you know of a current steering box type mechanism which uses the same principles and which could be useful for turning rotary into horizontal motion (old landrover mk1kinda thing)
Thanks for any replies
Michael Gilligan09/04/2014 10:20:20
23121 forum posts
1360 photos
Ady,
It doesn't quite answer your specific question, but; reading between the lines, I'm pretty sure you will find this worth reading.
P.S. ... That photo is amazing;
I particularly like the electrical switchgear at lower-left.
FMES09/04/2014 10:26:51
608 forum posts
Bit like one of these?
Honda industrial engine
Michael Gilligan09/04/2014 10:29:26
23121 forum posts
1360 photos
For anyone interested in the Steering Box that Ady mentioned ...
Here is an excellent article about the Trojan vehicle
Neil Wyatt09/04/2014 11:41:57
19226 forum posts
749 photos
86 articles
Not exactly the 'Sports Utility Vehicle' of its day - cheap as chips with tiny engine and pressed steel wheels. It was my favourite car in the Brooke Bond card collection!
Ian S C09/04/2014 13:00:28
7468 forum posts
230 photos
How about a lawn mower of the arm strong, push type there is a internal gear in each wheel, and the other gear is on the blade shaft, I'v got one in the shed, been wondering what to do with it for a few years now. Ian S C
Ian P09/04/2014 17:25:30
2747 forum posts
123 photos
Ady
Most current or recent vehicles have rack and pinion steering so I doubt you will find anything like you describe.
A pinion inside an internal gear does not have any special connection with converting rotary to linear motion. In your photograph that appears to be done with a crank and link.
Is your question aimed at the problem of trying to find a robust reduction gearbox? or are you trying to find a readily available linear (oscillating?) movement?
Pneumatics or hydraulics can be used to get straight line power.
Ian P
Ady110/04/2014 01:13:32
6137 forum posts
893 photos
Robust reduction is good... in the same plane
Edited By Ady1 on 10/04/2014 01:13:56
FMES10/04/2014 07:05:02
608 forum posts
As I pointed out before Ady, the reduction gearboxes on some of the Honda (GX160 type) engines are exactly the same as that you refer to.
It doesn't take much to knock up a drive arm as per the steering box.
Approx reduction 6:1
Michael Gilligan10/04/2014 07:57:08
23121 forum posts
1360 photos
Ady,
Going back to your oriiginal post, I see reference to a "continuous steering box" ... which begs the question: What other sort would you want? [discontinuous steering would seem to be a bad idea].
This may be a typo, or may be a jargon term of which I am unaware.
Can you enlighten me ?
P.S. Lofty's Honda unit looks ideal for the job.
Michael Gilligan10/04/2014 08:37:15
23121 forum posts
1360 photos
Posted by Neil Wyatt on 09/04/2014 11:41:57:
Interesting to see some of the later Trojan vehicles.
Neil Wyatt10/04/2014 09:57:46
19226 forum posts
749 photos
86 articles
Yes, and the Wikipedia article is a little more sanguine about the ride quality than the 'unbiased' Autocar review!
Michael Gilligan20/04/2014 08:20:08
23121 forum posts
1360 photos
Posted by Michael Gilligan on 10/04/2014 07:57:08:
Ady,
... Ady ?
Ady120/04/2014 08:32:38
6137 forum posts
893 photos
That was the the term in the original ME article so that was the one I stuck with
Seemed easier to say than "reduced gearing whirlygig thingummybob"
Michael Gilligan20/04/2014 08:41:28
23121 forum posts
1360 photos
Thanks
Ady120/04/2014 08:55:55
6137 forum posts
893 photos
I've just realised that I have an ancient push-mower which has been lying in the garage for decades
Will have a look at it
Thanks to all
John McNamara20/04/2014 14:11:03
1377 forum posts
133 photos
On Straight lines...
From memory The Peaucellier–Lipkin linkage is the best so far using a bar linkage.
Jonn
Michael Gilligan20/04/2014 14:47:29
23121 forum posts
1360 photos
John,
Did you see the link that I posted on 09 April ?
I think you will enjoy reading
John McNamara20/04/2014 15:18:11
1377 forum posts
133 photos
I suspect I missed It Michael
Michael Gilligan20/04/2014 15:41:35
23121 forum posts
1360 photos
Posted by Michael Gilligan on 20/04/2014 14:47:29:
John,
I should have been more specific ... the one at 10:20:20
