AndyP | 02/04/2014 00:23:27 |
189 forum posts 30 photos | I have resurrected the cnc conversion of my x1 mill and want to turn down the end of some nema 23 stepper motor shafts from 8mm to 6mm and thread it for the handwheel - double ended motors you see. I had in mind just to chuck the other end of the shaft in the lathe and keep the motor casing still but will this kill the motor? I've cut the keyways already. Cheers Andy |
Les Jones 1 | 02/04/2014 08:42:12 |
2292 forum posts 159 photos | Hi Andy, Les. |
Douglas Johnston | 02/04/2014 09:00:57 |
![]() 814 forum posts 36 photos | Might be easier to keep the 8mm diameter and modify the handwheel, although that may not always be possible. Doug |
Russell Eberhardt | 02/04/2014 09:33:53 |
![]() 2785 forum posts 87 photos | Posted by Douglas Johnston on 02/04/2014 09:00:57:
Might be easier to keep the 8mm diameter and modify the handwheel, although that may not always be possible. Doug Or even make a new handwheel? Russell. |
Michael Gilligan | 02/04/2014 10:49:53 |
![]() 23121 forum posts 1360 photos | Posted by Russell Eberhardt on 02/04/2014 09:33:53:
Might be easier to keep the 8mm diameter and modify the handwheel, although that may not always be possible. Doug Or even make a new handwheel? Russell. . Or, better yet ... use these They are flexible in bending, but stiff in torsion. MichaelG.
AndyP | 02/04/2014 19:25:23 |
189 forum posts 30 photos | Thanks for all the good ideas guys, turned down no problem, tailstock support and motor lightly held in the fixed steady, 200rpm on the Boxford and a sharp hss tool. I had thought of but discounted an adapter because the damn things are going to stick out an awfully long way anyway but John's advice to "modify the cheapest bit" makes excellent sense - I must try and remember that bit. Andy |
jason udall | 02/04/2014 19:48:14 |
2032 forum posts 41 photos | A thought. Have a care with the wires of the stepper... The motor will (if a hybrid stepper)..generate quite large voltages... Don't short them as this will cause the motor body try to turn with shaft ..ideally add resistors..or low wattage light bulbs ..or better still neons .. "shorting" the coils. .the motor will still try to turn with the shaft but the voltage won't get chance to flash over the coils. Well that's what I would do.. |
John Haine | 02/04/2014 21:45:07 |
5563 forum posts 322 photos | If you have the motor connected to a driver, even if the power is off it will be quite hard to turn the handwheel as the stepper charges capacitors in the driver. If you want manual control best unplug from the driver. Even better, use a manual pulse generator (MPG) to drive the stepper via Mach 3. I'm looking at "stepperature" which uses small steppers as encoders for just this. |
Michael Gilligan | 02/04/2014 21:58:47 |
![]() 23121 forum posts 1360 photos | John, Thanks for your lead to stepperature ... I was unaware of it ... Looks very promising!! MichaelG. |
Douglas Johnston | 03/04/2014 09:53:56 |
![]() 814 forum posts 36 photos | I have a stepper motor drive connected to the right hand end of the leadscrew of my Myford speed 10 lathe and use the enable input of the driver to disable the motor when it is not running.This arrangement has worked fine for some time but I do sometimes feel uneasy when I use my mandrel handle for screwcutting. The turning of the mandrel handle rotates the stepper motor (incidently there is very little resistance caused by the motor  Doug
Ian P | 04/04/2014 21:20:21 |
![]() 2747 forum posts 123 photos | Posted by Michael Gilligan on 02/04/2014 21:58:47:
John, Thanks for your lead to stepperature ... I was unaware of it ... Looks very promising!! MichaelG. I wonder why the designer used a stepper motor for the basis of his design, he admits it can miss pulses at slow speed. Surely it would be better to use an optical encoder from an old computer mouse (or even an optical mouse)? The only thing I can see the stepper being used for here is to provide a well engineered spindle with some detent action. Ian P |
Michael Gilligan | 04/04/2014 21:28:48 |
![]() 23121 forum posts 1360 photos | Ian, Yes, on further consideration I'm inclined to agree. MichaelG. |
