Ady Wilson | 08/03/2014 12:46:45 |
41 forum posts 14 photos | I need to drill two holes in digital caliper to mount it to a collar and rods I made for a cheap dro for my mill. I tried to drill a 4mm hole unsuccessfully. I guess caliper is about 5mm thick and all I managed was 2.5, wont go any deeper. I am going to get a couple more 4mm drill bits now but wondered if anyone had any tips for the operation before I butcher them lol. I was running about 600 rpm with the 4mm drill bit. cheers, Ady. |
jason udall | 08/03/2014 13:13:55 |
2032 forum posts 41 photos | Amongst other troubles with drilling stainless. .it workhardens like blases ..so keep cutting and quit when blunt and switch drill.. And repeat. ... Also for this very task I remember carbide drills being the choice. . (You arenot the first to need to drill calipers).. |
Michael Gilligan | 08/03/2014 13:21:38 |
![]() 23121 forum posts 1360 photos | Ady, Apologies: This doesn't answer your question; and I don't mean to hi-jack your thread Has anyone tried these "carbon composite" calipers ? ... they might be easier to modify. MichaelG. |
Keith Long | 08/03/2014 13:32:05 |
883 forum posts 11 photos | Again apologies to Ady and just to answer MichaelG. Yes I have got some of those, they only read to 0.1mm and accuracy is given as +/- 0.2mm. Also if you apply much pressure you can distort the jaws and get a false reading. The main shaft can also be flexed. So OK for a quick very rough check but not for anything requiring any degree of precision. They might just come in for using as a scale but again the relatively poor resolution and accuracy would go against them. Better units are available still for the right side of £10. Keith |
Mike | 08/03/2014 13:34:24 |
![]() 713 forum posts 6 photos | Yes - on some samples of stainless a high speed drill only has to skid one turn without cutting to create such work-hardening that further progress is all but impossible. Carbide works, but if you use your carbide drills for hammer-drilling concrete you will need to get yourself a green wheel for re-sharpening. |
Michael Gilligan | 08/03/2014 13:45:58 |
Thanks, ... Much as I feared ... I will save my £5.99 Strangely, the advert seems to quote resolution as But also says: "Minimum Scale to read is 0.1mm/0.1" So one of them "must be a typo" MichaelG. . Edited to clarify the claimed resolution. And again, to thank Keith !! Edited By Michael Gilligan on 08/03/2014 13:50:19 Edited By Michael Gilligan on 08/03/2014 13:54:09 |
Robbo | 08/03/2014 14:02:08 |
1504 forum posts 142 photos | Ady, I have used "glass drills", ie drills for drilling glass, which have a solid carbide spearpoint tip. They are also easy to sharpen up with a diamond slip. Start small, and change up to final size. Don't let them rub, be positive. Used them for the same job as you, drilling a digital caliper for a DRO on a drill.
Phil |
Keith Long | 08/03/2014 14:29:04 |
883 forum posts 11 photos | MichaelG PM sent Keith |
ega | 08/03/2014 14:41:49 |
2805 forum posts 219 photos | I have done this and seem to remember using a cobalt drill, probably with some Rocol RTD. You certainly could use a carbide drill; the Asbo brand, no longer advertised, worked well. |
David Jupp | 08/03/2014 14:43:52 |
978 forum posts 26 photos | 300 series stainless (austenitic) work hardens like crazy. Tends to gall easily so maybe not great for calipers. 400 series stainless (martensitic) may well be deliberately hardened from factory - I would guess this is more likely for calipers. Might drill, or grinding with a small point might work better. |
Les Jones 1 | 08/03/2014 14:52:44 |
2292 forum posts 159 photos | Hi Ady, Hi Michael, Edited By Les Jones 1 on 08/03/2014 14:54:01 |
Neil Wyatt | 08/03/2014 14:53:28 |
![]() 19226 forum posts 749 photos 86 articles | The secret for drilling stainless is lube, speed, never back off on the feed and bit of luck. I have an ancient and cheap pair of plastic digital calipers. They are ideal as a hack pair for keeping in a pocket to see if bootsale/scrap box bar is 10mm or 3/8", that sort of thing... Neil |
Richard Greening 2 | 08/03/2014 15:08:23 |
2 forum posts | Hi, saw this 40 years ago, but slow is good ( less heat ) HSS drill sharpened correctly, mix some Bi Carbonate of soda to make a mulch ( like butter ) gently drill with bi carb, it does work BUT DO NOT RUSH, but make it cut ! Rich |
Michael Gilligan | 08/03/2014 15:18:31 |
![]() 23121 forum posts 1360 photos | Keith & Les, Thanks for the updates. MichaelG.
Tomfilery | 08/03/2014 15:34:13 |
144 forum posts 4 photos | Ady, I had a similar problem, but needed to drill 4 holes (for M3 screws), to make a depth DRO for my Super7 tailstock. I managed to drill the holes in the "fixed" leg (i.e. the one which did not contain the electronics) but had the same trouble as you with the other two holes. My solution was to strip all the plastic parts off the caliper "carriage" , heat it bright red with my blowtorch and then anneal it, by quenching in water. I then had no trouble finishing off the part-drilled holes. Hope this helps. Regards Tom |
John Stevenson | 08/03/2014 15:59:32 |
![]() 5068 forum posts 3 photos | Posted by Michael Gilligan on 08/03/2014 13:45:58:
Strangely, the advert seems to quote resolution as But also says: "Minimum Scale to read is 0.1mm/0.1" So one of them "must be a typo" MichaelG. . It's called blue sky tolerancing which roughly means no matter what's posted no one gives a rats arse. |
Michael Gilligan | 08/03/2014 16:15:56 |
![]() 23121 forum posts 1360 photos | Posted by John Stevenson on 08/03/2014 15:59:32
It's called blue sky tolerancing which roughly means no matter what's posted no one gives a rats arse. . Thanks John ... very helpful |
John Stevenson | 08/03/2014 17:25:35 |
![]() 5068 forum posts 3 photos | Not a problem, like to help with practical answers. |
Speedy Builder5 | 08/03/2014 17:37:38 |
2878 forum posts 248 photos | I am suprised that Tom's method of softening SS worked. Shouldn't it be a very slow cooling with any alloy containing iron. As already stated, keep the pressure on, plenty of coolant, sharp drills. |
Jeff Dayman | 08/03/2014 19:02:01 |
2356 forum posts 47 photos | For drilling stainless or other hardish steel up to 65 Rc the drills at the link below work really well. I bought a 1/8" one and have used it to drill calipers for mounting (among other things). If the 1/8" hole size is used, a #4-40 UNC screw passes easily, and a 1/8" 'c' style roll pin fits with tension in the hole to locate the jaws to mounting brackets with zero backlash. http://www.maford.com/products/index.aspx?series=200 Good luck, JD PS you need PLENTY of drilling downforce to make these drills cut. Push them hard and they work great. |
