Here is a list of all the postings Richard Greening 2 has made in our forums. Click on a thread name to jump to the thread.
Thread: hardened Stainless help |
08/03/2014 15:08:23 |
Hi, saw this 40 years ago, but slow is good ( less heat ) HSS drill sharpened correctly, mix some Bi Carbonate of soda to make a mulch ( like butter ) gently drill with bi carb, it does work BUT DO NOT RUSH, but make it cut ! Rich |
Thread: Cross slide feed nut slop problem |
08/03/2014 12:58:31 |
Hi all, just looking at subscribing, I could not help but see this problem "Backlash" !! I have only ever seen it cured on CNC machines with recirculating balls and adjusted finely, they work very well ! A lathe , Miller, no nut split or otherwise will ever eliminate this, you can only take out the backlash by screwing back prior to putting a cut on ! thanks for listening MY opinion only Rich |
