am after some pointers on how i can precisely mount a large and long square bar in a lathe for turning?
TimS | 05/03/2014 15:06:42 |
20 forum posts | Hi, i am after some pointers on how i can precisely mount a large and long square bar in a lathe for turning? i have a 300mm length of 70mm square bar that needs a boss turning on one end, the boss needs to be very accurately centred and running parallel with all the sides. The only method i can think of (with the kit i have) is to use 2 independent 4 jaw chucks, one in the head stock and the other freely rotating in a very accurately aligned tail stock which would allow me to adjust both ends precisely is there another or better way of doing this? i dont have a tailstock chuck so will need to make that however i am sure there are other probably better ways of solving this problem thanks in advance |
JasonB | 05/03/2014 15:22:08 |
![]() 25215 forum posts 3105 photos 1 articles | Careful marking out or a DRO in the mill will mark the centre of one end to within 0.001", center drill that punch mark and support with a live ctr in the tailstock, drive the other end with the 4-JAw Can't see how you would turn a boss on the end if you are holding it with a rotating tailstock chuck J
Edited By JasonB on 05/03/2014 15:23:31 |
Roderick Jenkins | 05/03/2014 15:31:18 |
![]() 2376 forum posts 800 photos | The way I'd do it would be to make a flanged collar that is bored just big enough to take the square and then mount four screws to bear on each face of the square. The collar would then be mounted at one end and supported by a fixed steady. The other end would be set up true in the 4 jaw independent chuck. Using a DTI mounted on the saddle you should be able to set everything up using the screws and/or the steady supports to get it correct for turning and centering the boss. Rod |
Nobby | 05/03/2014 15:44:20 |
![]() 587 forum posts 113 photos | Hi As J B says |
JasonB | 05/03/2014 15:49:43 |
![]() 25215 forum posts 3105 photos 1 articles | Rod, I did think about a cats cradle but it would need a big fixed steady, that bar is going to be about 100 across the corners. J |
Brian Wood | 05/03/2014 17:17:44 |
2742 forum posts 39 photos | Hello Tim, Do you have a boring head and the ability to mount a suitable sized vice on a vertical slide? If so it would be feasible to turn the boss from the headstock end with the tool swung round the outside of the bar. Without a boring head it gets rather tedious but you could still index a boring bar held in a 4 jaw chuck to do the same job. Some far end support would be wise I think to mop up stray vibrations and stop the bar from being pushed away from the cut. Regards Brian |
Roderick Jenkins | 05/03/2014 17:18:43 |
![]() 2376 forum posts 800 photos | Posted by JasonB on 05/03/2014 15:49:43:
Rod, I did think about a cats cradle but it would need a big fixed steady, that bar is going to be about 100 across the corners. J Yeah, your right. Comes down to drilling an accurate centre hole then. Easy on my mill which, although quite small has a horizontal spindle so can be used as a jig borer. A similar set up could be done using a vertical slide in the lathe. Holding 300mm vertically and drilling is more of a challenge in a Model Engineer's workshop, headroom wise. Rod |
Nobby | 05/03/2014 17:33:01 |
![]() 587 forum posts 113 photos | Hi |
TimS | 06/03/2014 15:13:14 |
20 forum posts | Thanks for all the suggestions; i have just received my copy of "Workholding in The Lathe" so i will give that a read for some more ideas i dont have a DRO or a mill big enough to hold it for drilling i wonder if i swapped a flanged collar for a way to hold a smallish 4 jaw chuck in the fixed steady i would then be able to drill the centre with the tailstock for turning i might also do a few experiments to see how closely i can get a punched centre hole... my only worry is using that centre mark to drill a hole big enough for a dead centre... i might have to drill it by hand and generally i am utterly useless at getting them anything like square thanks again |
Gordon W | 06/03/2014 15:54:59 |
2011 forum posts | I think the only way I'd be able to do on my smallish lathe is mounted on the cross -slide and a boring tool or similar in the 4jaw. As others have said, mark out and drill a center hole, hand drilling is not too bad, Wonder if the bell shaped center drill would be better ? |
jason udall | 06/03/2014 19:31:01 |
2032 forum posts 41 photos | Lets assume bar is square ( some times it is). Take piece of stock say 5 mm bigger than across corners size.. bore the stock to fit bar. Mark jaw one ( say) against "bush".. Remove and split ( saw) choose position between jaws Return to chuck..fit bar and close chuck. .. But if you need to work at 300 mm from chuck.. Do the same but use steady on od of un split bush.... |
jason udall | 06/03/2014 19:32:21 |
2032 forum posts 41 photos | Or use face plate mounted tool and square bar on cross slide.. |
jason udall | 06/03/2014 19:57:25 |
2032 forum posts 41 photos | If the challenge is marking center...why not us center finder square thingy ( if you have one)..the ones on combination squares..included angle is 90 degrees. .thus line will fall diag to diag..do this from all four cornes and if all well you get what looks like two lines ( or at least very close depending on how regular a square the bar is) which cross.. |
jason udall | 06/03/2014 19:59:44 |
2032 forum posts 41 photos | Or failing all that. .surface plate / height gauge.. |
Andy Ash | 06/03/2014 20:03:30 |
159 forum posts 36 photos | Posted by Gordon W on 06/03/2014 15:54:59:
I think the only way I'd be able to do on my smallish lathe is mounted on the cross -slide and a boring tool or similar in the 4jaw. As others have said, mark out and drill a center hole, hand drilling is not too bad, Wonder if the bell shaped center drill would be better ? You could flycut the end square, then drill and ream a hole. If you then made a separate barrel with a peg on the end you could bolt, weld (or both) the end on. I don't thank I'd have the patience to keep stopping the lathe to keep adjusting the tool. I have a feeling you can get an automatic boring head, but I've never understood how those work. |
jason udall | 06/03/2014 20:03:45 |
2032 forum posts 41 photos | As to center hole. . Start small..say 1mm by 1mm deep.check then enlarge. .say 3 mm..etc |
Ady1 | 07/03/2014 08:10:16 |
![]() 6137 forum posts 893 photos | Doing a good between centres job on a round bar is a big challenge Doing a good between centres job on a SQUARE bar is a heck of a challenge I've never seen one done before in anything I've ever read
Workholding would be made a lot easier with a longer than required square bar Turn each end into roundbar and hold between centres with two four jaw chucks? Each chuck jaw should be parallel with one side of the square bar None of the Above can happen until you get a spot-on centre hole at BOTH ends, or disaster will happen, the sides of the square bar will be misaligned when its on the lathe Truly accurate 2nd operation jobs are a PITA Bear in mind that you can also combine Two bespoke dead centres with the 4 jaw chucks, since they will fit down the centre of each chuck into the mandrel taper, this may help.... A heck of a challenge IMO GL
Edited By Ady1 on 07/03/2014 08:43:59 |
Michael Gilligan | 07/03/2014 08:50:03 |
![]() 23121 forum posts 1360 photos | Posted by TimS on 05/03/2014 15:06:42:
... i have a 300mm length of 70mm square bar that needs a boss turning on one end, the boss needs to be very accurately centred and running parallel with all the sides. . Tim, There have been some good suggestions so far, and [aside from the labour involved] I don't think there was much wrong with your original suggestion. Before we try go any further, it would be worth knowing: How accurate is the square bar that you are using?
... and, incidentally, what diameter is the proposed boss ? I ask these questions not for the sake of pedantry but, simply to better understand the scale of the problem ... you say "the boss needs to be very accurately centred and running parallel with all the sides." but responders can only guess what you mean by that. MichaelG. |
Ady1 | 07/03/2014 08:58:18 |
![]() 6137 forum posts 893 photos | Once the bar is mounted between centres fit a DTI to the cross slide, set it against one end at (say) 2.0 and run it along the length of the bar Flip bar 90 degrees without moving the DTIs position and do the same again, it needs to be at 2.0, as do the other 2 remaining sides The DTI will need to be set at 90 degrees to the centreline of the square bar or you will get goofy readings lol, good luck Edited By Ady1 on 07/03/2014 09:03:28 |
Michael Gilligan | 07/03/2014 09:11:03 |
![]() 23121 forum posts 1360 photos | Posted by Michael Gilligan on 07/03/2014 08:50:03:
... i have a 300mm length of 70mm square bar that needs a boss turning on one end, the boss needs to be very accurately centred and running parallel with all the sides. . and [aside from the labour involved] I don't think there was much wrong with your original suggestion. . Sorry, Tim, I had better withdraw that comment MichaelG.
