A 3" scale model of a 1913 Saunderson and Mills tractor powered by a 55cc SV twin cylinder "T" head water cooled engine.
Four stroke Fred | 31/05/2013 11:56:38 |
![]() 322 forum posts 305 photos | This is an unfinished 3" scale model of a Saunderson & Mills tractor (1913). The original was seen in a museum on the South Island of N.Z. (Geraldine). The engine has been designed but has yet to be made. All the work is carried out in a home workshop.
Edited By JasonB on 25/05/2014 13:29:39 |
JasonB | 31/05/2013 16:57:31 |
![]() 25215 forum posts 3105 photos 1 articles | That looks an interesting project George, whats the power source? I do have the drawings for an IHC Titan but they are not upto much but could be tempted if you write this one up for ME.
J Edited By Neil Wyatt on 25/05/2014 11:20:48 Edited By Neil Wyatt on 25/05/2014 11:29:04 |
Farmer Dave | 31/05/2013 22:53:25 |
33 forum posts 7 photos | Looking good George,post some photos as it progresses. Jason where did you find the drawings for the IHC Titan, I am looking for plans for a Waterloo Boy, any help much apprecated. Regards Farmer Dave Edited By Neil Wyatt on 25/05/2014 11:21:15 Edited By Neil Wyatt on 25/05/2014 11:29:11 |
JasonB | 01/06/2013 07:30:55 |
![]() 25215 forum posts 3105 photos 1 articles | Reeves sell them as well as a few basic castings. Having said that they are not the best drawings in the world and you would have to do quite a bit of research yourself to get a fully detailed engine. Though I have not seen the ME article so there may be more in there. I'm sure I have seen a model of a Waterloo Boy, give me a while and I may find it again. J Edited By Neil Wyatt on 25/05/2014 11:21:19 Edited By Neil Wyatt on 25/05/2014 11:29:17 |
JasonB | 01/06/2013 08:11:40 |
![]() 25215 forum posts 3105 photos 1 articles | Here you go, from Georges part of the world so he may know if details are available. Also worth asking on Smokstak forum. Edited By Neil Wyatt on 25/05/2014 11:21:24 Edited By Neil Wyatt on 25/05/2014 11:29:45 |
Stub Mandrel | 01/06/2013 10:05:37 |
![]() 4318 forum posts 291 photos 1 articles | IIRC the IH tractor was serialised in ME, the Author was Tony Webster. Neil Edited By Neil Wyatt on 25/05/2014 11:21:30 Edited By Neil Wyatt on 25/05/2014 11:29:49 |
Four stroke Fred | 10/02/2014 22:47:35 |
![]() 322 forum posts 305 photos | I have been working on this model for the past two years and now have the main chassis , differential and gearbox completed and am now working on the engine. The engine is a 180 degree twin with fixed head, water cooled and "T" valve placement. Over the last few weeks I have been making the patterns and core boxes for the cylinders - quite complex! The crankcase haves have been cast and machined and have the cam shaft gears fitted. The model is just over 700 mm long. Edited By JasonB on 25/05/2014 13:32:24 |
Phil P | 10/02/2014 22:56:13 |
851 forum posts 206 photos | That is rather nice. I don't suppose there will be any drawings available, do you have access to a full size prototype to measure up ? Phil |
Four stroke Fred | 11/02/2014 00:22:41 |
![]() 322 forum posts 305 photos | Good Day Phil, I first saw the full size engine in a museum in Geraldine on the South Island of New Zealand and spent a week taking photographs, measuring up and making many sketches. There are examples of this type of tractor in the UK but not many have the "T" head engine. I have made a full set of drawings for all the parts that I have made so far and hope at a later stage to write an article for the UK Model Engineer magazine. They have just finished the series on my Lister Diesel engine and I was asked if I would do one on the tractor only this time there will be more words! It will not be a construction series as such but have sufficient information for a competent modeller to at least make a start. George.
Martin Cottrell | 12/02/2014 21:04:14 |
297 forum posts 18 photos | Hi George, Lovely work so far, it will be a splendid model when finished! I really admire the skills of those like you who can measure up the full sized item then scale it down and produce patterns and castings to make a faithful reproduction in miniature. I enjoyed your series on your Lister diesel and look forward to your tractor series in due course! Regards, Martin. |
Four stroke Fred | 01/03/2014 09:58:52 |
![]() 322 forum posts 305 photos | I have been working on the cylinders for this model tractor for the last five weeks- still not there yet but not far away now! Spent today making new core boxes for the inlet and exhaust ports. The manifolds are square in section so there is a transition in the ports from round to square. The sand cores that fit inside the cylinder are very fragile and have to be glued together before being inserted into the mould. The photo shows early flawed attempts that were cut up to check the inside. Back in the workshop tomorrow making more "sand castles". Temperature in Bundaberg a bit cooler thank goodness. Edited By Neil Wyatt on 25/05/2014 11:23:21 Edited By Neil Wyatt on 25/05/2014 11:29:53 |
Four stroke Fred | 02/03/2014 09:16:19 |
![]() 322 forum posts 305 photos | I did notice that there was a sub title relating to 3D printing. The core shape shown in the photograph is made from sand and was made in a composite core box. I am not sure that a 3D print would withstand the temperature of molten aluminium. Edited By Neil Wyatt on 25/05/2014 11:23:25 Edited By Neil Wyatt on 25/05/2014 11:30:00 |
Les Jones 1 | 02/03/2014 10:05:55 |
2292 forum posts 159 photos | Hi Fred, Les. Edited By Neil Wyatt on 25/05/2014 11:23:31 Edited By Neil Wyatt on 25/05/2014 11:30:36 |
JasonB | 02/03/2014 10:16:18 |
![]() 25215 forum posts 3105 photos 1 articles | Les it is possible to 3D print the corebox and use that to mould the core material in as its often gas set you don't need the printed part to be that strong as the forces when paking the sand are not so high J Edited By Neil Wyatt on 25/05/2014 11:23:37 Edited By Neil Wyatt on 25/05/2014 11:30:41 |
Four stroke Fred | 04/03/2014 09:17:22 |
![]() 322 forum posts 305 photos | I had a good day today and actually cast a cylinder with out any faults. It has taken many weeks and I was beginning to wonder if I would ever happened. I still have to cast one more and have the box ready packed and hope to cast it tomorrow. The photo shows the flask complete with all cores ready to have the top box fitted and then filled with the molten aluminium. Another busy day coming up! Edited By Neil Wyatt on 25/05/2014 11:24:05 Edited By Neil Wyatt on 25/05/2014 11:30:48 |
Four stroke Fred | 12/03/2014 09:25:13 |
![]() 322 forum posts 305 photos | Today I cast cylinder number 8 . I will eventually cast a perfect pair but this casting for the tractor is the most difficult that I have attempted, mainly due to the thin section of some of the internal parts. I did pour another one today - the outside looks good but tomorrow I will find out what's has happened inside. George. |
Ady1 | 12/03/2014 10:47:04 |
![]() 6137 forum posts 893 photos | Any chance you could put up a photo of the original in the museum?Cheers
JasonB | 12/03/2014 12:21:13 |
![]() 25215 forum posts 3105 photos 1 articles | |
Ian S C | 12/03/2014 13:11:54 |
![]() 7468 forum posts 230 photos | Fred, did you get to the vintage machinery auction at Geraldine the other week, a mate of mine bought two (more) open crank, hit and miss engines, and a few other bits and pieces. Ian S C |
Four stroke Fred | 12/03/2014 21:27:28 |
![]() 322 forum posts 305 photos | Thanks Ian and Jason for the information and photo of the Saunderson and Mills tractor. When I went to the museum it was very difficult to get a good view due to the close proximity of other tractors so I will add this one to the collection of information that I have been able to gather. It would have been good to go to the auction but I live in Queensland, Australia and Geraldine is across the pond in NZ. I was asked if I was going to produce any drawings - well so far I have accumulated 249 A 4 sheets and I still have more to come. This model is certainly testing my patience and skill level but that is what this hobby is all about . |
