mike mcdermid | 31/12/2013 18:39:51 |
97 forum posts | Lathe has developed a habit of turning tapers smaller at headstock end ,it did always cut 1 thou or so over 6 inch but was never bothered ,this seems to have grown to about 5 thou now over 3inches
doesnt matter wether using tailstock or not taper is the same which rules out the tailstock, in fact i can get a good result by setting over the tailstock to eliminate the taper
however its not the best option
any ideas
no crashes or bangs and wallops of late |
Nobby | 31/12/2013 18:56:20 |
![]() 587 forum posts 113 photos | Hi Mike & Guys
Edited By Nobby on 31/12/2013 18:57:22 |
Thor 🇳🇴 | 31/12/2013 19:04:16 |
![]() 1766 forum posts 46 photos | Hi Mike, As Nobby says, has anything been done to the lathe? A wooden stand will not be as stable as a steel stand, what kind of stand do you have? Have you read Harold Hall's description on Lathe setup, turning paralell etc.? Regards Thor |
mechman48 | 31/12/2013 19:04:51 |
![]() 2947 forum posts 468 photos | Happy New Year to all the guys on the forum.
George |
mike mcdermid | 31/12/2013 19:40:02 |
97 forum posts | hi chaps its a boxford 280 industrial brand new d1-3 chuck to be honest i had not noticed problems as i was using a 4 jaw and clocking everything that got tiresome spindle taper clocks at 0 if i put my finest clock on it and i probably am not as good as the clock using a cheaper clock i get runout on diameter of the chuck is less than 1/2 a thou worst on face less than 1/2 a thou and if i put a piece of bar in the chuck is 2 thou concentricity anything tighter i switch to the 4 jaw
if i shift the tailstock i can get ban on diameter over the length of 3" even if i pu the old chuck on i get similar taper towards headstock |
Emgee | 31/12/2013 21:21:37 |
2610 forum posts 312 photos | HiMike Surprised you have that problem with such a lathe. Just ask if the taper on spindle and in chuck are absolutely clean, also of course the mating faces of chuck and spindle. Is it better by using a particular jaw for tightening ? Rgds, Emgee
S.D.L. | 31/12/2013 22:02:53 |
236 forum posts 37 photos | Posted by mike mcdermid on 31/12/2013 19:40:02:
hi chaps its a boxford 280 i get runout on diameter of the chuck is less than 1/2 a thou worst on face less than 1/2 a thou and if i put a piece of bar in the chuck is 2 thou concentricity anything tighter i switch to the 4 jaw
if i shift the tailstock i can get ban on diameter over the length of 3" even if i pu the old chuck on i get similar taper towards headstock What make chuck is it? if you put a true cylinder in the chuck (bit of silver steel) what is the runout along the bar to that you know is true? ie are the jaws eccentric to the body of the chuck?
Steve |
mike mcdermid | 31/12/2013 22:54:38 |
97 forum posts | It's a bison 125 mm The spindle is spotless as is the seat Concentricity on a ground 1 inch bar is about 2 thou over a foot Can't figure it as the headstock sits on a vee and the bolts are still tight Edited By mike mcdermid on 31/12/2013 22:55:28 |
blowlamp | 01/01/2014 00:24:47 |
![]() 1885 forum posts 111 photos | Is this with carbide tooling? If so, grind up a very sharp HSS tool and try that on some brass or aluminium.
Martin. |
Nobby | 01/01/2014 02:32:30 |
![]() 587 forum posts 113 photos | Hi Mike |
Ady1 | 01/01/2014 06:21:33 |
![]() 6137 forum posts 893 photos | Any play on the saddle etc ? Lock it to the carriage. Then try locking the carriage at various points along your bar |
