Poly V Belt Conversion
Styx11/12/2013 13:36:32
34 forum posts
42 photos
I have the drawings and Poly V belt from Hemingway Kits for the primary drive conversion for the Myford S7 and I was thinking of using aluminium for the conversion instead of buying the castings. Can anyone see any problems with using aluminium? ie belt grip or possible lack of flywheel effect from using lighter materials.
Any thoughts would be appreciated.
Steve....
Edited By Steve Sedgall on 11/12/2013 13:37:53
Ziggar11/12/2013 16:51:04
115 forum posts
i too have looked at this kit for quite some time now and wondered the same thing. Would it be possible to use ali instead of the cast iron suggested.
far easier to machine and obtain than the cast. also a bit cheaper. cleaner to machine. no dust to clean up.
So im watching this with more than a little interest. I hope there are some good answers to mull over
Z
NJH11/12/2013 17:59:55
2314 forum posts
139 photos
I 'm just wondering why you are seeking to change to poly V ?
If it is to obtain smoother running then have you investigated link belts? My S7 was rough and noisy in the high speed range so I replaced the primary belt with a link type. Super smooth and quiet at all speeds now. The secondary drive belt is still a traditional 'V' type at present but that too will be changed for the link type when the time comes.
The belt is shown here
Cheers
Norman
link belt 1
michael sansom11/12/2013 18:06:15
6 forum posts
Hi Steve I have not done the myford conversion but have done the poly belt conversion on the Warco VMC milling machine using aluminium for the pullies and have had no problems at all . MIKE SANSOM
oldvelo12/12/2013 18:57:39
297 forum posts
56 photos
Hi Steve
Go for it with "Poly Vee" belts and aluminium pulleys I can recommend them as all metal working machines in my workshop have them.
Instead of castings you can use ali discs 12 mm thick bolted together to flanged boss bored to fit the shaft size.
Looking at Normans excellent photo this seems to be a viable proposition.
EDIT Looking again at the photo Maybe the large pulley is to big to be turned on a "Myford" so a proportionate reduction in diameter may be used.
PJ  "Poly Vee" will run on a 20 mm pulley much tighter than a "Vee Belt".
Eric
Edited By oldvelo on 12/12/2013 19:05:45
Styx13/12/2013 10:22:13
34 forum posts
42 photos
Hi All,
Thanks for all the tips, I have started machining the motor pulley and hope to have that finished soon. I have the use of a Colchester lathe so machining the larger pulley shouldn't be to much of a problem. I will post some photos in my albums when it is done.
Steve....
Ziggar13/12/2013 19:47:10
115 forum posts
i didnt realise that the motor pulley was part of the deal, nor does it say anything about it on the hemingways website. unless you mean the countershaft pulley.
either way, im looking forward to regular updates from you on this. lots of photos and updates as you go along
good luck with it
Z
Steve Withnell13/12/2013 21:21:23
858 forum posts
215 photos
I used a Contitech "Poly V" belt for a mod to my lathe. PJ610/240. The grooves on the new pulleys were cut with a 5/8 BSW tap as a tip from John S. Following John's post there was a number of posts pointing out everything that was wrong in the match between the profile of the tap and specified profile of the Poly V belt.
Fact is, the grooves were a doddle to cut this way and the belt is still in good nick years later. Maybe a trick worth considering.
Steve
John Olsen16/12/2013 06:45:36
1294 forum posts
108 photos
I thought this was a conversion for the secondary drive, eg from the countershaft to the spindle. Anyway, for what it is worth, I have done the equivalent conversion on my ML7, so if anyone was wondering, it is possible, although it is a bit of a squeeze. (I did do four speed steps.) I did mine because I was tired of the pullies overheating and letting go on the spindle...the ordinary V belt gets very hot, which tells you that the drive is not very efficient.
Styx16/12/2013 09:26:54
34 forum posts
42 photos
Hi John,
The conversion I am doing is for the primary drive. Hemingway also do a final drive conversion as well.
Hi Ziggar,
You need to machine a new motor pulley and modify the clutch pulley. Hemingway supply castings for these but I am making them from aluminium.
Hi Steve,
Thanks for the tip about using a tap to cut the grooves but I have ground up a carbide grooving tool with the 40 degree angle.
Pictures will be posted in my albums when I start machining.
Steve....
Ziggar16/12/2013 11:04:01
115 forum posts
do you have a link to the kit you are referring to because all i can find is the kit for the main 4 step pulley arrangement between the countershaft and the mandrel
Thanks
Z
Styx16/12/2013 11:09:27
34 forum posts
42 photos
Hi Ziggar,
If you go to the Hemingway web site and download their latest workshop catalogue, W180, you will find the Poly V conversion on page 36.
Steve....
Ziggar16/12/2013 11:12:09
115 forum posts
thanks for that
i always thought that the catalogues would simply reflect the website contents
seems i was wrong
off to hemingways site i go
Z
oldvelo16/12/2013 16:40:40
297 forum posts
56 photos
Hi Steve
Following your posting with interest being a "Poly Vee" fanatic
Pleased to see "Thanks for the tip about using a tap to cut the grooves but I have ground up a carbide grooving tool with the 40 degree angle.
Near enough good enough not for me. The enemy of the best is not the worst but the good enough.
Eric
Steve Withnell16/12/2013 18:08:35
858 forum posts
215 photos
For me I'm afraid, Pareto always wins.
The belt has been in service for over five years without issue, never slipped, spun off.
However, I'd agree that the good enough that's not is a problem.
The irony is, in another forum I've just been accused of being a perfectionist...
Steve
Ziggar16/12/2013 18:12:42
115 forum posts
unfortunately i only have the one lathe available [the S7] so wouldn't be able to do this conversion
although the other one is still a likely candidate at some time in the future
it would be a nice touch if hemingways were to offer a pre machined pulley if wanted/needed
perhaps something for them to think about ?
Z
Edited By Ziggar on 16/12/2013 18:13:43
NJH16/12/2013 18:38:51
2314 forum posts
139 photos
Hi Guys
Further to my previous post can someone please tell me the advantages of poly V belts? I've had a look at the Hemmingway site which lists the conversion kit but just what advantages do these belts have? What problems do you have at present with the conventional set up? ( I'm always looking for presents for my wife to get me!)
Norman
Michael Gilligan16/12/2013 19:40:08
23121 forum posts
1360 photos
Norman,
Regarding the advantages ...
I was going to refer you to this thread ... but I see that you were a contributor!
If you care to follow some of the references, then I'm sure you will become a convert.
Edit: Inserted the opening line
Edited By Michael Gilligan on 16/12/2013 19:42:09
Edit: Corrected typo.
Edited By Michael Gilligan on 16/12/2013 19:44:48
NJH16/12/2013 20:23:03
2314 forum posts
139 photos
Thanks Michael
I'd quite forgotten that ! However, whilst I. Can see an obvious advantage for a flat belt drive lathe like the ML4 I'm at a bit of a loss to see the advantage for a V belt drive like the Super7. The only problem I've had with mine is noise and vibration in the high speed range but this was cured by a belt change as shown above.
Norman
Michael Gilligan16/12/2013 20:36:44
23121 forum posts
1360 photos
Norman,
I suppose the best summary is that, by design, the Poly Vee acts exactly like a set of matched Vee belts of very small section. This means that the efficiency of the drive is massively improved, because the "contact patch" is bigger, and the bending stiffness is much lower than an equivalent single Vee Belt.
The concept was derived from the use of multiple Vee Belts to drive high power compressors, etc.
... Most definitely worth exploring.
Edit:  Here is a classic use of multiple single Vee Belts
Edited By Michael Gilligan on 16/12/2013 20:41:04
