Mark P. | 29/11/2013 12:35:52 |
![]() 634 forum posts 9 photos | I have aquired some M6 taps from the Tap and Die Co. They are marked up HQS, I assume that it refers to the steel they are made from but what is it? To be honest they look quite poor quality, they were bought to replace a set of M6 Sherwood taps which got lost when I moved house.Does the team think that I will get the same amount of use from them (I had the Sherwoods for over 15 years) they were used very frequently in steel/stainless steel ally etc. Mark P. |
Mike Poole | 29/11/2013 14:03:21 |
![]() 3676 forum posts 82 photos | I think they are a high carbon steel, a quick touch on the grinder to perform a spark test should give an indication of what the material is. The non business end of a tap will do if losing the centre is not a problem. Mike |
Mark P. | 29/11/2013 16:00:15 |
![]() 634 forum posts 9 photos | Thanks for the reply, thought as much as I said they look "cheap" Regards Mark P. |
Raymond Griffin | 29/11/2013 17:05:19 |
65 forum posts 48 photos | Have a look at the Tap and Die company website. They refer to HQS as Highest Quality Steel, considered a tougher and better alternative to HSS: cut even stainless steel. I’ve had some taps from them in the past and was happy with them. They are not certainly cheap: take look at the prices. Ray G |
Stub Mandrel | 29/11/2013 18:33:51 |
![]() 4318 forum posts 291 photos 1 articles | As Ray says, I have heard of HQSS taps as a step up from HSS. Neil |
John Stevenson | 29/11/2013 19:23:13 |
![]() 5068 forum posts 3 photos | Advertising hype other wise you would be able to find more references for it.
Popular sizes are Ok on price but anything special is obscene. 1 1/8" Whit, normally £170 08 reduced to £105.51
Even J&L can't get anywhere near that and they do HSS not monkey metal. |
Steve Withnell | 29/11/2013 19:33:50 |
![]() 858 forum posts 215 photos | I can't look at the Tap&Die site, it makes my eyes smart. |
jim' | 29/11/2013 20:41:05 |
72 forum posts 6 photos | hsco= good hss-e=good hqs=never heard of it outside their site.......... |
Jeff Dayman | 29/11/2013 20:43:38 |
2356 forum posts 47 photos | Maybe it's "Highly Questionable Substances" ? or "Hasty Quick Salesmen" or "Hardware Quackery Supplies" Just sayin..... JD |
mechman48 | 30/11/2013 11:07:34 |
![]() 2947 forum posts 468 photos | I generally take HQS as Asian speak for ordinary HSS, the next grade up for me would be Cobalt, but never having tried any...? George |
