Here is a list of all the postings jim' has made in our forums. Click on a thread name to jump to the thread.
Thread: free copy of Model Engineer? |
26/03/2016 18:29:41 |
I thought it was just a catalogue. I subscribed today. I finally got fed up with looking for WHS's latest location of the mag |
26/03/2016 15:15:46 |
just been to WHS and brought MEW, unusually it was in a sealed clear bag, with a current copy of Model Engineer magazine. but no mention of a "two" pack?
just curious if its a mistake? |
Thread: Spindexer/spin indexer |
20/03/2016 07:44:42 |
Thank you for all the comments. I think I will go with the Arceurotrade version. Some good points raised. Thanks again Jim
19/03/2016 07:41:33 |
Hi, Been thinking about getting spindex thing, (arceurotrade one).**LINK**
Are they solid enough to mill hexagons on bolts, or really just a simple drilling thing? I only ask because the locking pin does seam a good distance from the action! I have been using a hex ER collet block, but if these spindexers are ok, I'd be able to check for run out etc easily.
Thank you |
Thread: Arceurotrade 000 QCTP |
02/02/2016 20:45:04 |
250-200 would be nice! |
Thread: The Workshop Progress Thread (2016) |
02/02/2016 19:14:45 |
Posted by Roderick Jenkins on 02/02/2016 19:10:37:
Bandsaw update: Having proven the concept, I've made a better job of the clamp. The studs are 6mm and the slots in the bar were made with a 1/4" slot drill: Cheers, Rod excellent. one more for my todo list! |
02/02/2016 19:05:17 |
Treated meself to one of Arceurotrade's new 000 QCTP. These are the sliding wedge type. I bought mine for a Sieg C4, i'd had a mini lathe QCTP before, but, they are not very good!
Very impressed! Very precise location, far more positive and accurate than my "piston" type 2 on the Crusader! Only problem is, I now need to buy more holders....... |
Thread: replacement motor brushes WEISS mill (champion 20v) |
06/01/2016 17:04:46 |
Posted by Dave Daniels on 02/01/2016 10:55:30:
IF !! it's the same 600W motor as a Warco WM16 it's these :
I think Warco charge a fair bit more for what appear to be the same brushes.
Dave The new ARC brushes arrived today, fitted straight in.
Happy days.
A big thanks for the heads up on this.
Cheers Jim |
02/01/2016 11:04:45 |
Edited By Dave Daniels on 02/01/2016 10:56:43 Edited By Dave Daniels on 02/01/2016 10:57:52 Edited By Dave Daniels on 02/01/2016 10:58:13 Excellent!! They look just the job!! I was just about to order some from ebay!
Thank you for your help!! |
02/01/2016 10:44:50 |
I'll probably get some oversize ones off eBay. Thanks for advice |
02/01/2016 07:15:02 |
Just discovered my mill is dead. Its a WEISS mill, similar to Chester's "chapion 20v"
Took out brushes and blew out with air and she lives again.
One of the motor brushes is very short, I have looked and can't find the correct size. They measure 3.4mm wide, 10mm high and I'd guess around 15mm long when new.
Can anyone help, please Cheers Jim |
Thread: Insert |
01/01/2016 20:15:32 |
CCGT inserts are what you need. Ground inserts for ally/plastics etc |
Thread: A request |
16/12/2015 16:22:20 |
Posted by Bodger Brian on 16/12/2015 13:41:47:
"I'm can imagine" I see what you mean.................................... Edited By jim' on 16/12/2015 16:22:58 |
Thread: Gary Wooding and his Chester 12 x 36 Lathe |
05/12/2015 11:59:00 |
I also drilled and tapped the cross slide. 4 holes on the top and three on the side, (I made an "L" shape plate). I figured that if I had a crash, it would be better to damage a steel plate than break a cast iron cross slide! It also means that the load is spread over a far greater area |
Thread: M10 socket caps with 6mm Allen hole? |
25/11/2015 20:40:34 |
M10 button head capscrews are 6mm hex.
I have used "low head" cap screws, I think they were 7mm hex |
Thread: M1.7 - what is the history behind it? |
12/11/2015 05:43:14 |
all you need to know about metric threads |
Thread: Motorcycle General Discussion |
30/10/2015 17:13:41 |
Thread: ER 40 Lathe collet chuck |
12/09/2015 19:26:57 |
pleased to hear its worked ok.
I got similar results!
Thread: ER40 collet chuck |
10/09/2015 19:02:53 |
Posted by pgk pgk on 10/09/2015 18:33:53:
When the penny finally dropped in my brain and I realised that i could shove my mills ER32 MT3 collet holder into the 5-3MT adapter and shove that in my crusader lathe I've been using it quite a bit. The only downside to the MT holder system is limited insertion distance. I didn't know ER40 went as big as 1 and 1/2 inches? Can i also ask which collet chuck you sourced to fit the crusader? 1 1/2" is a bit big!! The job was some 30mm 304 stainless. I think i got the chuck from Gloster tooling on ebay. |
10/09/2015 16:37:46 |
The bearing type nut is excellent. **LINK**
I have not had to resort to using the spanner yet, even on 1 1/2" stainless bar.
So much better than three jaw |
