Glass
Deltic00727/10/2013 20:09:00
131 forum posts
12 photos
Hi all
I need to procure some 0.8mm glass for my model cab windows,any ideas who sells it?
Thanks
Deltic 7
Saxalby27/10/2013 20:49:05
187 forum posts
33 photos
Hi Deltic,
Dont know what size cab windows you are glazing, but one source of thin glass is microscope slides. Slides come in sizes up to about 4 inches square and are normally 0.9 mm although you can get thinner.
Regards Barry
Deltic00727/10/2013 21:52:45
131 forum posts
12 photos
Thanks Barry
julian atkins28/10/2013 23:46:36
1285 forum posts
353 photos
try
v satisfied customer for the cab spectacle glasses for my 5"g STEPNEY loco
cheers,
julian
Ian S C29/10/2013 09:40:00
7468 forum posts
230 photos
For exhibition loco, glass. For general club use, plenty of hard work, maybe with many different drivers, is glass the answer, or is some sort of plastic a good idea. Ian S C
Deltic00729/10/2013 18:29:29
131 forum posts
12 photos
Dont understand your post Ian?
Cyril Bonnett29/10/2013 19:48:44
250 forum posts
I think Ian is referring to the practicalities of having glass in a working machine, health and safety and all that.
fizzy29/10/2013 20:18:03
1860 forum posts
121 photos
I dont think you should build a loco out of just glass, you might have problems getting the boiler tested.
Springbok29/10/2013 20:18:18
879 forum posts
34 photos
This subject has been going on for some years. Even had one chap ask me to send plastic samples never to be heard from again...
So moral is if it not spectacle glass forget it and try make your own,
Bob.
Springbok29/10/2013 20:19:53
879 forum posts
34 photos
Oh Fizzy can we all get a more uo to dat piccy of your little twinkle
Bob
Ian S C30/10/2013 09:49:09
7468 forum posts
230 photos
Julian's spectacle glass looks good, would be a bit stronger than microscope slides. Ian S C
Deltic00730/10/2013 10:07:09
131 forum posts
12 photos
Thanks for all your help but i still have not located anything that will fullfill the 45mm square that i need.
Please keep posting
Deltic 7
fizzy30/10/2013 19:50:59
1860 forum posts
121 photos
updated twinkle on its way!
Howard Lewis30/10/2013 21:01:34
7227 forum posts
21 photos
One possible source of thin glass IS Transparency Holders. 35 mm ones will probably be too small, but the glasses from two and quarter square (6 x 6) ones - if you can find them should be large enough to cut to size. DON'T get Anti Newton Ring ones, they are not plain glass, but minutely marbled like bathroom window glass.
Hope that this is some help
Weary30/10/2013 21:32:20
421 forum posts
I have used (nominal) 1mm thick 'Memory Glass', which is available in a variety of sizes, including 2" x 2", for locomotive cab windows.
It is sold in craft shops, here is an example, and is easily cut using a glass-cutter.
I have just checked the thickness and mine measures 1.1mm - so I don't know how crucial your thickness parameter is........
Phil
Deltic00731/10/2013 09:11:40
131 forum posts
12 photos
Just ordered some from **LINK**
Thanks for all the sensible postings
deltic 7
