Here is a list of all the postings Deltic007 has made in our forums. Click on a thread name to jump to the thread.
Thread: injector drawings |
19/10/2018 23:00:54 |
Having recently made some ejectors from an ME drawing that work well I now would like to make an injector Is there any drawings someone can point me at?
Thread: Newall Spherosyn Repair |
16/04/2017 17:34:00 |
Thanks
16/04/2017 16:29:03 |
HI,
I need a new 7 pin plug putting on one of my reader heads,is it possible to do yourself and if so where do you buy the plugs |
Thread: Steam pump |
30/03/2017 15:25:23 |
Chris, All lines are clear,i am trying it again tomorrow so will report back.
cheers |
30/03/2017 13:23:10 |
30/03/2017 13:22:59 |
Hi Julian, Drawings were from Allen models in the US No idea if it works with the water side disconnected and connected to pressure vessel(Good point and would answer your next question). IT does work under steam all connected but only pumps a couple of times stops and after a minute restarts only to stop and the cycle goes on. Pump is at the front of the loco about 14" from the steam valve Steam cylinder bore is 1" water is 5/8 Cannot see the exhaust as it is piped into the smokebox.
Hope this helps and thanks for taking time to help me.
30/03/2017 07:52:02 |
Ah yes There are no drain cocks at all in this design.
cheers |
29/03/2017 22:17:39 |
No checked the clacks and pipework blockages,Glands were leaking so repacked them ,just need to test again.
When i tried it last week it would pump twice then stop,wait a minute or two and it would start n stop again,strange.
29/03/2017 20:11:30 |
Hi all,
I have just made a worthington single type steam water feed pump and it works a treat until it goes under pressure when on the loco.Any ideas what the problem could be?
Cheers |
Thread: Ejectors Help Needed |
20/03/2016 22:10:32 |
You really expect me to furnish that with something sensible?
20/03/2016 19:39:52 |
Hi,
I need to fit an ejector to my 71/4 model,does anyone have a drawing they could let me have or is there an article in one of the magazines?
Cheers n thanks |
Thread: Vacuum Brakes |
14/03/2016 22:36:35 |
Hi
I am looking at fitting brakes to my new 71/4 loco,the diaphragms that i see for sale on the net seem to be very expensive £37.50 plus,anyone got any ideas or experiences to help me save some wonga? as i need 2 plus reservoir and brake shoes. |
Thread: O rings |
24/01/2016 17:00:50 |
Hi anyone ever joined a SILICONE O ring what did you use?
Cheers |
Thread: Superheater elements |
08/01/2016 20:02:45 |
cheers
Hi all
Is it possible to buy elements(2tubes welded together) professionally? If so where from?
Thread: Boiler Bushes,Headers Etc |
03/01/2016 17:37:12 |
Hi all, |
Thread: Fusible Plugs |
30/12/2015 18:54:10 |
What material would you recommend? Drawing actually says soft solder.
30/12/2015 18:24:52 |
The reason i originally posted was because i am building a New Zealand designed loco and it has one fitted.I will have to consult our boiler inspector to see if it is OK to omit it. |
30/12/2015 18:18:51 |
Why would you do that Mark?
29/12/2015 10:03:36 |
Any reason Jason
29/12/2015 09:58:13 |
Got to make one of these for my next project,is normal soft solder Ok or am i better with white metal or lead?
