..........and using micrometer heads
Rik Shaw | 21/09/2013 19:24:00 |
![]() 1494 forum posts 403 photos | I am trying to avoid feelings of guilt about not working on the next model but as it will be installed on the left side of the carriage/apron the readings will be upside down. I have had a pretty good search but cannot find any supplier who sells these heads for the opposite "hand". Are the upsidedowners available? Rik |
mechman48 | 21/09/2013 19:52:34 |
![]() 2947 forum posts 468 photos | Rik I've just pm'd you my dwg for my carriage stop which uses a common hex head bolt, (if you must have a mic barrel, & have difficulty reading upside down), set your tool to the shoulder / depth you need, measure with a depth mic or vernier & lock the hex head bolt up in that position you should get repeatability at that... & save y'self a tenner plus. Cheers George Edited By mechman48 on 21/09/2013 19:53:22 |
NJH | 21/09/2013 20:52:09 |
![]() 2314 forum posts 139 photos | Somewhere, in the far off recesses of my aging brain I seem to recall micrometer heads engraved the other way around? Maybe from bits of apparatus in a research lab. Anyone remember? Norman |
Bazyle | 21/09/2013 23:02:59 |
![]() 6956 forum posts 229 photos | This micrometer is almost 'normal' right hand but if you click on the picture you get an enlargement that shows it has two sets of engravings. On that basis you could just get a standard one and re-engrave it yourself. I imagine the intention of having a micrometer, as is how I use my standard Boxford one, is to make a cut and then make an increment on that cut of a precise small amount for which a fixed screw stop is no use. It enables you to make accurate shoulders without using the topslide which can be left set over for threading. But you can also get ones that turn the other way Edited By Bazyle on 21/09/2013 23:06:34 |
NJH | 22/09/2013 00:01:51 |
![]() 2314 forum posts 139 photos | Thanks Bazyle You have accessed those parts of my brain unused for some time! Of course these micrometers were used primarily, not just for measurement, but to accurately position items on experimental rigs. I'll bet that they cost a bit more than the ARC offering that Rik has found though! Rik I don't know what lathe you have but you might try design based on THIS item supplied by Hemmingway for the Myford 7 N |
graham howe | 22/09/2013 02:04:36 |
16 forum posts | I have just added a new article to my web site about my take on lathe carriage stops. I have never been a great fan of using micrometer hard stops as it is too easy to damage the micrometer should the carriage make a heavy contact. Once a stop is initially set and locked I use the compound slide to make fine adjustments should that be necessary. The other thing I also wanted from a stop was the ability to use it with power feed operational, as in the case of screw cutting or even normal turning. My article describes a new simple attachment I have devised to do this which helps enormously when judging the correct instant to operate the GHT retracting screw cutting tool or in the case of normal turning under power feed to disengage the feed. link: http://www.homepages.mcb.net/howe/lathe%20stop.htm Graham |
Raymond Anderson | 22/09/2013 05:02:02 |
![]() 785 forum posts 152 photos | Mitutoyo do a few models with reverse reading if thats what you are after. Series 150 is a standard head available with reverse reading grads. Raymond. |
Rik Shaw | 22/09/2013 09:12:01 |
![]() 1494 forum posts 403 photos | Thanks everyone. Graham, the link does not work for me. Rik |
John McNamara | 22/09/2013 09:31:54 |
![]() 1377 forum posts 133 photos | Hi Rik I think do it yourself stop is a better choice, a micrometre is not strong enough. A high tensile cap screw with the end ground flat maybe set into preloadable half nuts to allow you to take up the slack and reduce the backlash similar to the way a micrometre works, or alternatively a simple lock nut to lock the setting. If you have a dividing head you can make up an engraved thimble. I have a VDF factory made stop for my VDF lathe it is just a well fitted screw and a lock nut with a graduated thimble. It clamps on the bed, One thing I would like to change is the method of holding it on the bed. I picked up a stop for another unknown lathe in an auction junk box. This stop has teeth, a short rack, that engage the bed rack that is used by the carriage drive. This would provide a rock solid mount there would be no possibility of slipping. If you marked the teeth where you placed it, it would go back in exactly the dame place each time. One day I will get around to making one............ Regards Edited By John McNamara on 22/09/2013 09:35:48 Edited By John McNamara on 22/09/2013 09:38:30 |
John Stevenson | 22/09/2013 11:16:29 |
![]() 5068 forum posts 3 photos | Sorry, I disagree with John's opening statement. I have a cheap Chinese micrometer head on my 7" centre height TOS lathe which is used daily in a jobbing shop operation so it does get some use.
I do have a clutch on the feed shaft but it's set quite high as 4 mm deep cuts under power at 1,000 revs are quite normal on this lathe. I've crashed it many times, bumped hard onto the stop and after about 10 / 12 years this is still working as it should. The work mine has done so far must equate to more than a lifetime in a home shop and small machines |
NJH | 22/09/2013 11:49:17 |
![]() 2314 forum posts 139 photos | Well John - the voice of experience! How though do you get over Rik's original problem of the micrometer readings being upsidedown if installed on the LHS of the saddle? N |
Nobby | 22/09/2013 12:02:21 |
![]() 587 forum posts 113 photos | Hi |
Bazyle | 22/09/2013 19:57:00 |
![]() 6956 forum posts 229 photos | Back to the start. As the ticks stay the same and only the digits have to change how about a thin brass sleeve to overlay the original numbers. If you can't engrave perhaps Letraset would do. Also the digits do not need to be absolutely precisely positioned (unlike the ticks) so various computer printing options are possible. |
Howard Lewis | 27/09/2013 21:46:31 |
7227 forum posts 21 photos | Moore and Wright used to make Imperial micrometer heads with "inverted" readings. I have one on the carriage stop that I made for my lathe (Engineers Tool Rooom BL12/24 - Warco BH600/ Chester Craftsman lookalike). The end thread, which secures it to the stop body is 1/8 BSP, if you manage to find one. Maybe they no longer manufacture such things. If you want to be really modern, you might be able to fit a digital depth gauge, and set the Zero at the one end, and then work off the Minus reading on the display? Although Murphy's law says that the display will still be upside down, unless you can find some means of using the other end of the probe against the saddle. But being ingenious is one of things that makes Engineering so special. Howard |
Speedy Builder5 | 30/09/2013 16:22:15 |
2878 forum posts 248 photos | is there such a thing as a left handed micrometer - Its probably what you want, then modify it. |
Speedy Builder5 | 30/09/2013 16:25:39 |
2878 forum posts 248 photos | Here is a left handed vernier
Stub Mandrel | 30/09/2013 16:59:42 |
![]() 4318 forum posts 291 photos 1 articles | I have a M&W internal micrometer that is 'left handed', at least if you mounted the bit with the fiducidial line to a stop, the bit the thimble moves in and out would be on the right. A range of 0.250" might be a bit limiting though. Neil
